TonkaGR.1
1/144 Revell MiG-25 Foxbat
When you have multiple projects in finalization phase, it is best to start a new one ;)
This kit is pretty basic (and based on what I gather, shape wise not entirely accurate), so there will be plenty of opportunities for improvement and scratch building.
Starting with air intakes which were sanded down a bit:
Cockpit will be scratch built, starting with this opening ;)
Nose gear bay will be rebuilt:
As well as main gear bays:
Biggest disappointment were decals, at least with my sample they're full of tiny gaps and will not be used. BTW are there any sets for 1/144 Foxbats?
Some progress made. Removed details of bleed air doors - on aircraft they were inset:
As the fuselage is about 3 mm too short, I've added plastic blocks at the end:
And sanded them to rough shape:
Vertical stabilizers are too small so that needs fixing:
Ailerons are of completely wrong shape:
Wings seem to short - and they're positioned too aft:
And nose radar will have to be reshaped as well:
That's all for now ;)
Edited by TonkaGR.1
Submitted post too early.
Small update, nose section was cut in 3 pieces:
Mid section was then expanded and sanded off:
Whereas radome will have to be rounded:
Basic shape of elevators is now done, whole surface will have to be sanded off and engraved from scratch:
Additionally, fan blades will be (hopefully) created from scratch:
That's all for now :)
Jings! A lot of work required in a small space but I've a feeling this is one worth watching.
  Very cool Tonka.  I have the Minicraft version on my shelf of doom.   That beastie looks like a completely different kit to this, I was under the impression they where the same.  I have no idea where I got that from?! Looking forward to seeing how you rebuild the landing gear bays. :)
  Kind Regards,
  Dazz
Hi guys! Thanks for your comments, much appreciated :)
It's been a busy month, hence very little progress has been made on MiG.
Wings were cut off the fuselage in order to extend them accordingly:
Each wing was then extended, all panels will have to be re-scribed:
Vertical stabilizers were extended as well:
Intakes need some reshaping:
Main undercarriage tires are of correct size, but too thin:
Therefore, some tires from old Airbus A340 kit will be used instead (of course shaped to correct dimensions ;))
Oh, BTW: in case you haven't seen footage of low level flying with MiG-25:
Very interesting. Would be nice to see a side-to-side-comparison between the original kit and your improved MiG!
Alex
