Welcome back,
The last couple of weeks have been a bit of a mish mash. I have done a lot of little things but not much to show for it.  I started on the MLG bays, cementing the kit pieces into the upper wing section and adding the PE. The PE instructions are a little ambiguous as far as the two strengthening strips on the inside. They show to just add the PE over the top of the moulded detail but looking at the cut outs on the wheel bay pieces, this would mean they interfere with the fit. My recommendation would be to sand the moulded detail off, fit the two inserts and then using the cut outs, slide the PE pieces into position and fix them in place. I say this as I didn't do it that way and had to remove the moulded detail after I had cemented the inserts. In the end you get something that should look like this:
491020C6-B077-48A3-830A-650C359DBD25_zps
0E23EF27-0C94-43C8-B7E9-ED851EF2CCEB_zps
ED166AAC-0CFD-4405-82FE-7B4A820A10BD_zps
The wing uppers have also been fixed in place here. What I have also done, but not yet photographed, is attach all the trailing edge pieces as well. I wanted the flaps level and Eduard has cast them with a downwards angle by default, so I had to remove the tabs from the front and just cement them in place with TXT. Essentially the construction of the wings is complete as I have also painted the MLG bays and radiator inner surfaces RLM 02 as well as the lower wing interior upper surface "just in case":
04F25156-6E6A-499B-979C-D1DB9F9BBED2_zps
5FF413CA-BC5B-4647-ACFC-1C232B896E7F_zps
8B3BA7F0-012F-4A1F-9D13-F31D454F177C_zps
Regards,
Welcome back,
More small progress, I have added the PE mesh pieces and radiator covers after removing the rear flaps of same in preparation of the PE replacements:
D71EE5B1-9321-42DA-824A-FF6E186AC26F_zps
EC8BDFB2-0F28-4313-A189-3982739EB720_zps
I found the rear pieces to be about two rows too tall so they were shortened appropriately. The forward PE mesh fit well:
C3172652-3590-4681-B7D3-0429A28F1E7C_zps
I have removed the Fine Molds harnesses from their sprues, cleaned them up, test fitted the upper harnesses and attached the lower belts in place using TXT. These now need to be carefully shaped with a heat source and then painted:
A2C600D7-CEB3-47FC-8C84-F820F7F66717_zps
I have started detail painting the cockpit sidewalls. The oil cooler innards was masked and undercoated the areas that will eventually be yellow around the nose area and with Tamiya Flat White as well as the theatre recognition strip around fuselage which will be masked as it remains white:
39217EC7-ABB0-4309-B290-CADC888BD097_zps
C76E6DFE-8426-4DEA-A739-1E73E840BEA5_zps
Regards,
Welcome back and thanks for the comments.
I progressed a little, working on the details on the cockpit sidewalls, floor and seat harnesses to apply base colours. Next is gloss coat, washes and some Airscale placards:
8E168DF4-AC20-48EE-A30B-45ADAA07D71F_zps
AA9BD6E4-1090-45D7-92EE-1543F984BD09_zps
14901C87-9A59-463A-AA6B-7ABA0709DAA9_zps
6A82EC9E-55F0-400B-90DD-55D4A62B7CB5_zps
AF824A04-1B23-4EA7-AA53-BCBD63A0A5B1_zps
DE38FF80-8D84-4CAF-9789-A9CC5CDB8517_zps
E0A4A8AC-4254-48CF-8B44-25FB6B84B4A6_zps
9A8DB3E8-E651-4B45-BD04-474C6D3D49AD_zps
I was going to bend them first then paint but I got carried away and now they have their base colours on. I am experimenting on some scrap to get the method down of bending without melting. I may wait until after the gloss coat to provide a little protection. Anyway, the resin sections of the MG17's have been painted. The blued sections need a little touch up in the cooling jackets:
C89F5D7E-E494-44EE-8C61-E75E4745AE50_zps
DAEA3B52-44E8-43E8-A7E5-3DFC16A7B26E_zps
Those previously white sections have had their coats of Aeromaster RLM04 including the PE air filter. The oversized rudder linkage attachment points were also removed and the PE replacements prepped:
F246153C-54DB-4D4E-AD59-E196E10651FE_zps
5BE5B117-CD7B-463A-8A75-256206173C82_zps
27D72F61-DDF1-4917-BFCE-02F73DC68DB8_zps
FC53741B-99CB-42E1-9451-D7A603E70711_zps
I am in a quandary as to the actual construction of the filter under the meshed areas. Eduard have given a solid piece with the two end pieces standing proud and the PE wraps around to form the exterior of three sides. Should I remove the majority of the solid plastic, leaving just the back face, effectively leaving the area under the mesh hollow? I shall have to have a closer look through my references but at first glance they provide no answer.
Regards,
Welcome back. The Finemolds harnesses performed well but not entirely as I had hoped. Being ABS plastic, directed heat in the form of a carefully applied heat gun tends to cause them to contract a little. It makes them pliable but they lose that nice detail. Radiant heat from a soldering iron is just hard to not let other parts such as the seat take injury. My first plan was to have only one shoulder harness folded back upon itself and the other resting outside on the fuselage. It soon became obvious that would not fly so both went up onto the rear deck:
3EA4E6A7-22B5-47AF-BDA5-BECA7AAB290E_zps
Work on the cockpit continues with Airscale LW cockpit placards, AK Neutral Grey wash and some highlights. The E-7 was the first of the Bf 109 lineage to have the fuel observation line running through the cockpit as it was the first to be plumbed for the 300l external fuel tank. The line became standard on the subsequent F, G and K series. The aircraft used the fuel from the external tank first and when dry, as observed by the pilot in the clear empty section of the tubing, it could be jettisoned. Damn clever those Germans! It isn't included in the kit so I made my own from clear stretched sprue, painted yellow and some BMF for the joins:
7D53D1EE-1506-47F9-AEA0-63C9CE023B4A_zps
696F482B-2F14-4FC7-A86A-1C41FA04A1BD_zps
0C55221C-C665-4CA4-A2B5-BA69D9467CED_zps
016CF668-0699-48A9-B554-562CB1B18104_zps
I have removed some of the forward edgedetail on the port cockpit panel as it fouled the forward join:
AB82941A-2E5B-4756-840E-40590D050FCD_zps
8958F887-F939-40DE-A107-40F8ACEDCE29_zps
77448AE4-1F31-40F8-A147-3DEC04B80A30_zps
89CEC8B6-00F1-490C-8DD0-4DA8EA8C4E17_zps
04B13A6E-1E87-42B6-A2B5-7685329E6316_zps
Elsewhere I have removed the plastic detail from the external fuel tank in preparation for the PE replacement and removed the forward half moon edge of the engine bay assembly. I was however a little over vigorous on the port side so that will need fixing:
B59F528D-89BA-4211-9B9D-99161328BA15_zps
249DA527-EA52-4611-AD77-EFB1DE8CC03C_zps
8A802978-EAB7-488F-AFB4-CBF71E3B269A_zps
The MLG internal covers have also been painted and set in place along with the external tank mounting hardware:
D6544B43-BABA-4ACA-B387-0A821DA330E4_zps
70DE0D25-ED35-4261-B498-0B7270860852_zps
Next up is finishing the cockpit construction with flat coat and installation of the PE instrument panels. Once that is done and the cockpit assembly installed, I intend to attach the completed wing assembly to the fuselage. This should allow me to paint the undersides and fuselage sides in RLM78.
Regards,
Thanks Stix and Rob,
Instrument panels. The PE panels from the E-7 kit are different to those in the Brassin cockpit set, being about a millimetre too wide for the resin they are to be attached to. You can just see the difference on the right side of the first picture with the E-7 underneath the Brassin:
298C8075-BDBC-498B-8A66-5C9B12634697_zps
EAB587D3-973A-45B6-84FF-6629FB0892F4_zps
The Brassin set does not have the additional panel for bomb/ fuel tank release. Minor surgery to graft from one to the other:
61B5A818-7157-453F-8AB9-CA4773877A1C_zps
Various handles and bits added. Revi C12 from MDC had a lead wire power cable installed and plumbed to the appropriate port on the upper panel:
C06023B5-2206-4280-9CB2-CEFAF2046EF4_zps
B8957AF9-6E66-43F8-B566-4F9E227C7EAA_zps
F264DEC3-3817-4DD5-9B9D-8B48823A700A_zps
625A3FD9-2626-41EC-8254-A93E2326B1C5_zps
All laid out for inspection. Flat coat and then installations come next:
854E91CF-060B-49C2-87AB-D15B2CD27DF5_zps
Regards,
Welcome back,
A  few days ago, I completed the cockpit assembly as per instruction and fitted it through the lower opening into position within the fuselage. I had progressed to the point where the cockpit and gun deck assemblies were installed:
737A2762-E5C4-497D-813B-CDFC42290AD8_zps
E7FB5925-B8CA-4793-8E0C-028FDC9D6F6B_zps
C90167CC-2FF0-4D38-B56F-58C5D0780027_zps
4ED6AB08-BB4D-469D-ABC8-40D4D7C73327_zps
Well, I thought, that's that and got ready to move forward.
BUT.....You know sometimes the longer you try and ignore something, the more it plays on your mind until eventually it becomes the most prominent thing on your mind? Yeah those gaps around the cockpit tub. Thankfully the properties of CA allowed me to take the tub itself out. I then realigned the sidewalls to close the gaps. Not entirely successful, so I glued some 0.5 styrene strips to close the gaps on each side of the rear deck, followed by some 0.5 x 1mm strips along the top. I will sand these back flush but already happier:
6311A6E9-1C0A-4B42-9FBD-D67FDD5BE2F5_zps
061F0923-0DC9-4698-88B9-F1FF67D4E4EB_zps
8ACEA57F-5C9F-4D2D-A0F2-2A34B6BFAFFA_zps
BF7A71D7-1192-4D9D-9319-B32DE0AFA1FC_zps
Some 0.5 x 1mm along the gun bay sides will need sanding but should address the gaps too. I may need a spacer to widen the lower fuselage to wing join as at the moment dry fitting has a small gap or it may be solved with dihedral:
36444782-A468-487C-AD3A-6F669AC56491_zps
D9526A33-627C-421C-8BD0-E8C166855E5C_zps
E3D5008A-D675-43A8-A62E-4E1DCBE3B98E_zps
D5BA119B-9715-4991-A777-BDA371C8FD3A_zps
So, it would appear I had fallen foul of the alignment gods. Next time I will probably change the assembly so the sidewalls are attached to the fuselage sides first, something I couldn't do this time as the fuselage halves were joined. Or possibly I may take more time in my alignment of the resin tub parts because looking back, they were out of kilter slightly prior to my attempt to install.
Stay tuned!
Welcome back,
Remedial work on the cockpit coatings continued. The areas were sanded down and repainted RLM 02. I could then fit the fuselage gun deck into position:
EDFCF25D-5246-4902-9B09-84972287B764_zps
3AF8AF92-90A4-472D-A315-62B9EDA440AA_zps
C62A6C73-AFD3-4B35-B130-EA7FC93B24F8_zps
1679910C-E584-4ADE-8DD7-DC12712D79FE_zps
There are still some minor touch ups to follow up on. I then cemented the lower sections of the wing assembly to the fuselage and let them set overnight. This morning I joined the upper wings to the fuselage, one at a time and allowing time for the seams to set up befo.re continuing to the second wing. I then taped the wings to set dihedral and allow the joints to set up properly:
70B87353-FDFF-4AB2-B50C-94A5D8579C2C_zps
0A500525-F36F-4C9C-999F-1F043029B1B8_zps
63A4BAA2-29CC-4110-8A9E-7A5DC0A6A1F2_zps
It looks a bit severe in this head on shot but after removing the tape, the wings have settled to a better angle:
53B8B94D-B533-4F79-9692-8309DA115989_zps
563299F4-EB19-487D-8CB0-082703F83B8E_zps
I have also masked the lower engine and white theatre recognition band on the fuselage in preparation for further painting. I intend (at this stage) to complete the remainder of the build and then come back and do the engine as a final assembly:
DEDC51DF-C94C-4C7F-AA56-05B4C8E2127D_zps
93197F66-2C29-4784-BAA1-40C8DD3B1685_zps
Whilst waiting for the wings to settle, I attached the PE harness to the external fuel tank. I had to enlarge and square off the fuselage attachment point for the PE to allow the PE and tank to sit correctly:
FBBC7010-BBC0-4F32-B82F-C9011A5489C7_zps
A4BCB344-8876-4655-A40A-1CDBFD849EC6_zps
Regards,
8 hours ago, vppelt68 said:
:wow: But aren´t there some cockpit side sill parts in the PE set too, to cover that gap? It´s better anyway to have that built solid, so well done! V-P
Thanks V-P,
I read your post and immediately thought "had I missed something ?". So I went and checked and there is PE sills in any of the PE sets. I think it was purely me rushing and ignoring a misalignment issue earlier on.
Regards,
  • 3 weeks later...
Welcome back,
It has been almost a month since the last post but not really much to show for it. The cockpit has been finished and the fore and aft canopies attached, having been partially masked and sprayed RLM 02 beforehand. The Revi gunsight has been attached an initially fouled the front canopy. A small adjustment downwards of the sight and some material removed from the front canopy underside and all is good:
565B34F6-7B44-4427-AA83-BAF41BFD0752_zps
0A930F7D-380F-4145-89E0-D787E34AB8C3_zps
I have also increased the slat fixing points by opening them up to their full length. This is more correct and I can now temporarily fix the slats for painting, removing and repositioning them later:
F35D6444-1EDE-42A3-817C-EBED3B9B8D1D_zps
The tail wheel broke but it is a blessing, as I have drilled the oleo and inserted a metal pin, with mounting drilled to accept it later:
230F2107-7718-4885-A436-D0C095BCF6DA_zps
Hopefully some paint soon.
Regards,
Progress at last! MM RLM 78 on the undersides and various bits and pieces. The wheel bays and radiators were masked with damp tissue and tape:
63D5F230-11E6-4B7B-8B5B-1A0A3B714721_zps
3193A9AA-80E2-4E46-80E8-0D3A831503AA_zps
8D8B1836-6262-4F95-B2D8-28460D0C61E1_zps
AF134C57-9305-4F17-BADA-9ED89DC91058_zps
877AF7AB-26F0-43E7-AB4A-633A5C391AF7_zps
The RLM 78 extends high up the fuselage sides. The slats have been temporarily attached for painting and will be removed and repositioned at a later time:
462AA64D-CD40-4641-8B2E-63D5EA40650F_zps
EFC0BEA6-1C32-4163-8225-FAC628B933C2_zps
MLG have had thin wire to replace the oversized Eduard pieces, BMF tapes to secure them and painted RLM 02:
B302B311-F1BE-4EF2-AFAF-B8F99BF16506_zps
A start on the engine and wheels with Tamiya gloss black.
8B2D7B04-E514-4A44-BF75-68E6FC6986E0_zps
Next the RLM 79 followed by the RLM 80 splotches and some more plastic sticking!
Regards,
Welcome back,
After a couple of stinking hot days with no chance to hit the bench, I got down adding a little more paint. Aeromaster Warbirds RLM 79 masked, sprayed and uncovered!:
3012388F-0184-4101-A67C-650CFDAF7CBF_zps
9F99FF18-2B7A-442A-BED2-E57D3EB4760E_zps
C520889F-4387-426B-9899-8A9E829D4F6E_zps
8641C1DE-6A5D-4212-824B-2DC03C75155F_zps
C4614A39-8BE9-4AB5-954F-D1005C81D27D_zps
ED81F5C2-2603-4516-8CF8-43A380CE11FF_zps
4CF10090-B995-41A1-8415-562AFBC53B99_zps
C73D73CC-5797-4DFE-AD43-79BD327CE101_zps
5BBECD23-BE5D-49FF-923E-39DD3A764F4B_zps
The rudder and cowling are just sat in place:
861405CC-8642-4657-B271-14F6E3265D95_zps
0F0AE4CD-BE82-4A7B-9893-E052E463CB72_zps
BA17AF74-AB11-41AB-9CD2-C8614D0C4711_zps
517FFA43-E9DC-4925-B74E-6C9AEC1A070A_zps
FCE77CB3-3476-46EE-B697-7F24FCAAADEC_zps
EC4A793A-231D-4F87-BEE0-8AB86E6D8B5B_zps
The tail wheel pinned and masked with liquid and tape:
EC3251A2-1695-4E91-8C38-9867D6A7B102_zps
12A5EAC5-2EB9-4C84-A179-635B5D869A06_zps
I can see from the pictures there is a little remedial work on the lower front canopy to fuselage join (particularly the port side) and some re riveting to be tidied up on the starboard side. Next is the RLM 80 splotches followed by gloss coat, decals etc. I hope to have the main construction and painting, decaling etc. finished early next week, before continuing on with the engine area as a final assembly.
Regards,
Thanks lads,
I have added the RLM 80 splotches using Aeromaster Warbirds enamels, well thinned and sprayed. I am really happy with the hirizontal stabilises and wings, the fuselage is a bit out of kilter. I think I got a bit tired and rushed it. However, it will do for this run:
8B746FAB-FF1C-49FB-9BBF-B03D49A589FC_zps
495506FC-A0E9-4DE2-9278-20ADB446A491_zps
578DB547-9604-4ADB-A4C9-DC565E28F367_zps
E332446E-35C5-42F6-9C2B-FBB78EEFBBB2_zps
Regards,
Two steps forward, one step back. The MLG and tail wheel are on:
80F232F0-D903-47DC-97E6-9A0F92CF4D69_zps
C190DF08-A9C6-4017-BD95-2EA8641CADB3_zps
7034B2DF-DF91-4DEE-9BB9-A5E0CE723B5D_zps
The fuselage camouflage wasn't sitting right with me so I resprayed and masked the RLM 78 and 79. I alluded to using tape to mask the markings. These pieces are more of a "rough guide" just to give me a reference when I re-shoot the RLM 80:
5E607F8D-2A9F-45A8-A10C-0E2F4EAC0407_zps
9F452070-FA9D-4CA1-91A3-62C081170C0E_zps
The prop is completed as are the MLG wheels. The slats have been repositioned to their final resting places:
93DFED41-8075-45F1-8740-C5FB21559A9C_zps
1992B470-EAFC-4C39-9ACB-95422834EEF8_zps
4BA451C2-631E-4354-A09E-67BCB7232BAA_zps
F09DFE05-2F61-400C-AD59-1A975F01BFF1_zps
I have also also repaired the tail antenna mast which was damaged somewhere along the way:
54F0CBB5-EBA6-4143-879F-C241F1130F3C_zps
86F0964C-88F4-4DAA-91BA-2CDFC1BAA3C4_zps
Once I am happy with the RLM 80, everything including sub assemblies will get a gloss coat for decals and washes. This outburst of OCD probably means I will miss the end date for the GB, as I honestly don't see much benchtime in the next 48 hours, being Christmas and all. Probably the only real hope I have is if the mods declare an extension.  🙏 We shall see!
Regards,
Really enjoyed reading your build Kent. I've had my eye on this particular kit for some time and finally pulled the trigger yesterday. The E-7 trop is my favourite 109. Will be using your build as a guide for mine. Well done!
