perdu
Navy-ation - Wasp The last post
Not to mention the nitro mgf too Debs
Obviously hard work pays
That appeals more to me and my bizarre ways than a completely original one stored in a cocoon from new, actually :)
Mine is nothing great - it was acquired from a lady who's husband had (literally) run away and the car sat languishing for 3 years following an MOT failure for a brake pipe leak and a little hole beside the driver's seat belt anchor. We got it running and it made its own weather although oil pressure is excellent. I stripped the head, did a little porting using Vizard's book and replaced the rattly valve guides. I used a local machine shop to skim the head, fit hardened inserts and recut the seats for new valves. The SUs are neglected and need rebuilt. Both master cylinders are kaput, and when I stripped the interior out to get to the MOT failure rust hole I found new floors and inner and outer sills, and the whole was behind the driver's seat in the corner next to the inner sill. That's sorted, but the noses of the box sections over the back axle and into the boot weren't too clever and needed replaced. I've done the driver's side and have the passenger side still to do. I haven't worked on it much because there's a rusty MX-5 in my garage too which belongs to my dad that's been getting all the attention for the last 12 months.
I'm sure I'll want (much) more power as soon as I've had it out on the road!
Round arches loads of room for 165 13s
Yummy
Mine has a 1293 A series with MG Metro head, dizzy and  single HIF44 carb also ex-MG Metro
Spridgebits fast rod cam and Ford type 9 gearbox
Happy as Larry at 110mph maxed at 113 uphill on the main runway at RAF Marham track day a couple of years ago
Its taken me ten blooming minutes to write then correct this
I detest predictive text...
Its coming off the prefs
I should point out, in proximity to Debs's 150bhp that SHE builds racing engines for A serieses and more than the occasional Coventry Climax whizzers for race cars
I don't but my mate and I (he used to knock together Racing Engines for Minis) put together a car designed to make the best of the Little British Sports Car on proper roads, legitimately
I'd love 150bhp but after the tender ministrations of Peter Burgess I have a car that was measured on his rolling road (boy, that was a scary afternoon) as giving 90bhp at the flywheel
I have better suspension and fibreglass front panels to maximise the beautiful whoosh when the throttle slams open
Best fun ever that isnt either making lurrrve or models  :)
As is often the way on a build wot I do, a small update
I made the main engine body t'other day, as ye saw and today and yesterday I have been bending 3/16ths plastic tube in the hope of getting two reverse bent exhaust pipes
I knew from bitter/interesting experience that these wouldn't just throw their hands up and come along easily and I was right
The pipe comes off the impeller end with a short straight then starts to rise and bend away immediately, not a task I want to perform often in future
Still I think I got close enough for Bristol Siddeley work
Also been trying to get a definite shape and size for the transferring gearbox under the pipes
You know what?
I can't find a single shot of the Nimbus's output shaft that enters the gearbox presumably under the Vee of the tailpipes so its all guesswork here
Here's the basic gearbox bits before I add the front machinery and the brake calipers and disk and fill between the rounded sections where the gears live inside
For relevance here's where they will all fit together before I mount then and discover they are overscale
OK OK I don't actually expect that but...
I have also been modifying the Scout to make its fuselage more Wasp
The ribs have been removed from the under-engine tapered body and the horizontal ribs along the fore part are being modified to suit a missile capable fuselage
(An extra horizontal rib shoehorned in at the bottom to act as stiffeners before the missile assembly can be added)
The ribs are too thick anyway and will be substituted  with Slater's Plastic strip of which I hope I have a few left over from the 'Cab, Hansom'
Also trimmed the tail of the fuselage to suit its new, slightly smaller size and location
Inside is getting attention too, here's the cross beam that sits beneath the seats ready to link up with the vertical members at the door frames
  And for fun
Here's another
"Can you see what it is..yet?"
This was a long defunct model which I dumped in the 85 purge
Does anyone have any pictures of the place where the gearbox takes its output from the turboshaft?
I'm probably too late to change anything now but its very nice to see and understand
Edited by perdu
In yet another small upsurge of inertial whoosh I embelished the transmission with the bits on the front
(I dunno wot they are but they look like this, right)
And the transmission brake disc, calliper and output shaft
from another direction
They look OK to me, any one with any advice? I'd appreciate some input on this
the above is the front view of the transmission box, there's lots more gubbinses and macguffins but frankly if I try to put them in a casting its never going to work so I'll leave that to the final build process
I have added the jet pipe thermocouples too, same rider as before, I am unsure if  that's what they are but it seems likely to me so I'll bung a label on 'em
I'll trim the little nubbinses to length later when the Green Top has completely dried away
I know that Airwaves moulded a version of this engine all in one piece but I'm not sure if I'd get away with it so plan A is to cast all three items in resin then bung 'em together laters
I also know that Freightdog has their engine in one piece so I'm kinda torn about it
Can we use the 'conflicted' word in here I wonder, 'cos I am
I also plan to cast a revised version of the canopy buck that I'll be trying to cast a little more detail for the rear view windows when I mould the screen and roof
I'm quite getting into the swing again, might make a start on the Frog Bucc which is getting the resin Gyron J intakes I scored on the  'bay
I need to put some stuff into the wheel bays, the absence of engines does show up quite prominently after all...
Thanks Debs
Wish I'd known you were likely to be able to get intimate with the Nimbus's nether regions  :unsure:
I'd have asked you to do a little clandestine delving between the undersides of the jet pipes
Ho hum never mind
I think I'm close enough for now
Still wondering whether to try a cast of it as a single unit or stick three bits together
Edited by perdu
Lovely offer Debs but I think I'm going to stick at this ta
Very kind offer thank you
b
Exciting times. Looks like you could do with a Warpaint book on the Scout & Wasp with all the detail pics you need.....If you can wait til Telford?;)
You could be right, I'll see what the Governess allows me for the weekend
Always happy to review literature for technical authors you know. ;)
Anyway, I'll look out for it.
B
Exquisite - if not downright inspirational - work on the mechanicals Bill.
:thumbsup2: Tony
I can't be of any help Bill, seeing as I know nowt about the Nimbus - but I can and will offer encouragement.
Here goes: Looks bloomin marvellous.  Hope that helps :)
If you're gonna cast it I can't see any down side in doing it in separate bits.  It's likely to make the casting easier isn't it?
And after all - gluing bits of plastic/resin together is what we do isn't it.....
Amazing attention to detail, on some very small fiddly bits.
Have a few pics of Wasp details, but none of the shaft area.
No worries thanks James, I'm a bit happier with the pieces now after a light misting of Tamiya Fine Primer
How does it look now?
Ready for mouldmaking I reckon
I echo what Steve said - I don't see any issues with casting in 3 sections. There's no point in making things difficult just for  difficulties sake
I likes it Bill. The gubbinses and macguffins and engine stuff loike is looking the business.
"...which I dumped in the 85 purge" Mmm that sounds a little Stalinist for you Bill. I mean it's the sort of thing Hollywood may make a movie about sometime: "The Infamous Purdu Purge of 85"
Does the fact that you're going to cast it hint that there may be more of this inspiring whirly-wing stuff in the not-so-distant future? The master certainly looks damn good!
Ian
There's a chance of a later, to-be-arranged Rippling Raspberry if I find another cheapo Airfix so making this again enters the pain not pleasure category!
 Or a certain entrepreneur might get his cast master to sort out the bits he needs and mine can retire
Plus promises made in the heat…
The engine bits look great! I  can see no reason to cast it  in one piece either
  Roger
your a clever dickie Bill!;)....I used to crew the scout...Army style many moons ago!...hence my avatar!
Not really clever enough Fozzy
I do these daft things don't I.
I may get an update in laters but for now the parts are sat in a pretty pink bath hoping the stuff will set without going melty blob
