Sign in to follow this
Shar2
HMS Hood. 1:200
HMS Hood
Trumpeter 1:200
HMS Hood (pennant number 51) was the last battlecruiser built for the Royal Navy. Commissioned in 1920, she was named after the 18th-century Admiral Samuel Hood. One of four Admiral-class battlecruisers ordered in mid-1916, Hood had serious design limitations, though her design was drastically revised after the Battle of Jutland and improved while she was under construction. For this reason she was the only ship of her class to be completed. As one of the largest and, ostensibly, the most powerful warships in the world, Hood was the pride of the Royal Navy and, carrying immense prestige, was known as ‘The Mighty Hood’.
She was involved in several showing the flag exercises between her commissioning in 1920 and the outbreak of war in 1939, including training exercises in the Mediterranean Sea and a circumnavigation of the globe with the Special Service Squadron in 1923 and 1924. She was attached to the Mediterranean Fleet following the outbreak of the Second Italo-Abyssinian War. When the Spanish Civil War broke out, Hood was officially assigned to the Mediterranean Fleet until she had to return to Britain in 1939 for an overhaul. By this time, advances in naval gunnery had reduced Hood's usefulness. She was scheduled to undergo a major rebuild in 1941 to correct these issues, but the outbreak of World War II in September 1939 forced the ship into service without the upgrades.
When war with Germany was declared, Hood was operating in the area around Iceland, and she spent the next several months hunting between Iceland and the Norwegian Sea for German commerce raiders and blockade runners. After a brief overhaul of her propulsion system, she sailed as the flagship of Force H, and participated in the destruction of the French Fleet at Mers-el-Kebir. Relieved as flagship of Force H, Hood was dispatched to Scapa Flow, and operated in the area as a convoy escort and later as a defence against a potential German invasion fleet.
In May 1941, she and the battleship Prince of Wales were ordered to intercept the German battleship Bismarck and the heavy cruiser Prinz Eugen, which were en route to the Atlantic where they were to attack convoys. On 24 May 1941, early in the Battle of the Denmark Strait, Hood was struck by several German shells, exploded and sank. Due to her perceived invincibility, the loss had a profound effect on the British people.
The Royal Navy conducted two inquiries into the reasons for the ship's quick demise. The first, held very quickly after the ship's loss, concluded that Hood's aft magazine had exploded after one of Bismarck's shells penetrated the ship's armour. A second inquiry was held after complaints that the first board had failed to consider alternative explanations, such as an explosion of the ship's torpedoes. It was more thorough than the first board and concurred with the first board's conclusion.
Despite the official explanation, some historians continued to believe that the torpedoes caused the ship's loss, while others proposed an accidental explosion inside one of the ship's gun turrets that reached down into the magazine. Other historians have concentrated on the cause of the magazine explosion. The discovery of the ship's wreck in 2001 confirmed the conclusion of both boards, although the exact reason the magazines detonated will always be a mystery since that area of the ship was entirely destroyed in the explosion.
The Model
I think I’m right in saying this is one release that maritime modellers have been really looking forward to. Since Trumpeter started their 1:200 scale product line, the Hood was one ship that was always mooted to be included. Well, here she is in her beautiful, enormous glory. Arriving in a huge box with a great painting of the mighty Hood at sea on the front the sheer size of the box gives a hint at what is inside. Once the lid has been prized away the modeller is confronted with three smaller boxes and a flapped area which covers the single piece hull, the mould for which must be amazing to see.
The hull is well protected by two cardboard supports and foam pieces at each end to ensure the delicate bow and stern aren’t subject to transportation damage. Inside the other three boxes are four separate deck sections, three for the main deck and one for the shelter deck, twenty sprues, eight separate superstructures/deckhouses and four separate propellers, all in a grey styrene. There are also seven sheets of etched brass, four metal rods, a length of chain, and a smallish decal sheet. As with most Trumpeter kits the moulding of all the parts is superb, with no signs of flash or other imperfections, which is quite amazing considering the size of some of the parts, although there are quite a few moulding pips which will require extra cleaning up and the propeller blades have a slightly annoying tag on their outer edges, as you will see in the accompanying photographs.
Unfortunately, also as with a lot of Trumpeter kits there are some really annoying inaccuracies, which is strange, since they did so well with their 1:350 scale kit. Whilst some are easily handled, like the rubbing down of the rather too prominent hull plates, although the hull itself is generally correct, there are also those which are a bit more difficult to rectify, namely the different sized funnels where they should be the same. Hopefully someone will release a fix for this, or it may be time to try some scratch-building. Over it is pretty accurate though, with a few minor problems, which are best noted in the excellent review by the HMS Hood association, HERE
Construction begins with the fitting of the six strengthening braces into the hull; topped off with the fore deck, centre deck and quarterdeck. On the underside the propeller shaft exit glands are attached, followed by the metal shafts, A frames, propellers, ensuring you have the correct propellers on each side as they are handed, and the single rudder. Turing the hull the right side up, six parts of the rear superstructure are attached to the rear of the centre deck, along with four cable reels which are a combination of PE and plastic, followed by a selection of vents, hatches and upper deck supports. The large, single piece shelter deck is then fitted atop of the superstructure parts, also covering the join between the foredeck and centre deck.
The lower bridge structure is fitted with bottom sections of the mast supports, a pair of three piece paravanes, six boat booms, four Carley floats and some small platforms, before being glued into position. The shelter deck is then fitted out with numerous ventilator mushrooms, inclined ladders, and derricks, whilst a large boat boom is fitted to either side of the hull amidships. The cradles for the ships boats are then added to the shelter deck, followed by yet more ventilators, chimneys and a pair of large ammunition hatches. The sixteen small ready use lockers and seventeen cable reels are then assembled and glued into position, followed by the thirty five large ready use lockers.
On the foredeck, the anchor chain windlasses, four smaller windlasses, and main breakwater are attached, along with the breakwaters either side of B turret. Then more mushroom vents, windlass, lockers and chain pipes are fitted, followed by the large vents around both B turret barbette and the armoured control tower base, which also has three winches fitted to the deck around it. The four piece anchors are then assembled and fitted to the hawse pipes, followed by two lengths of chain and two deckhouses attached to the rear of the main breakwater. The quarterdeck is similarly fitted out with mushroom vents, although not quite so many, winches, large vents around X turret barbette and the prominent inclined ladders either side of the rear superstructure, as well as the square scuttles sited nearby. Back on the foredeck there are several derricks fitted, along with the Jackstaff, cleats, and bollards. Similar fittings are attached to the quarter deck, along with the Ensign staff, as you can see the instructions bounce around a little.
The build then moves onto the superstructure, with the assembly of the sundry parts fitted to the rear funnel base, as well as Carley floats, winches and two of the smaller ships boats, a smaller tower structure is attached, and fitted with two, two piece wireless arms. The after tower structure at the end of the shelter deck is a single piece item and is fitted with a number of platforms and their associated supports, the after main armament director, made up from nine parts, two large intakes, two six piece searchlights and one of three, eleven piece AA directors, one large and two small Carley floats. The two structures are then glued to their respective positions. The shelter deck is then fitted with more hatches, intakes and five deckhouses. The four searchlight platforms, two either side of the aft tower and two alongside the aft funnel are fitted along with their searchlights, whilst the aft PomPom platform and two quad machine gun platforms along with their seven piece mounts are glued into position.
The base of the bridge tower is attached to the tops of three deckhouses, behind which the four flag lockers are fitted on either side of the forward shelter deck there are two observers binoculars, and aldis lamp, a large signal lamps, a semaphore pole and a quad machine gun mount. Two large and two small directors/rangefinders are also fitted near the signal lamps. The armoured tower and deck structure are then glued into position, followed by the tower roof and the large six piece director/rangefinder. Onto the deck, three deckhouses are fitted, along with four inclined ladders and a vertical ladder. The bridge itself is a single piece part, and is fitted out with sixteen observers binoculars, two AA directors, two searchlights, three further decks the lower mast supports, foremast, the complex PE foremast starfish structure, top mast, lower yardarm, inclined ladders, vertical ladders, and main armament director.
The funnels are next on the assembly line, and whilst the rear funnel is the wrong size, most modellers will probably overlook this and build the kit straight out of the box. Each funnel is in two halves, which are then glued to the base, and fitted out with PE hand/foot rails, internal platform, spacers funnel cap and grilles, followed by the numerous uptakes fitted to the outside of each funnel. The main mast is next up and whilst the mast itself is a relatively simple build, the various fittings for the boat crane are PE parts, as is the complex starfish platform. The upper mast is attached to the platform and topped off with the Type 281 radar array. The crane is a single piece jib, PE hook assembly and PE cable assembly. Once complete the funnels, foremast and mainmast assemblies are glued to their respective positions, as are two smaller boat cranes fitted one each side of the rear funnel.
There are thirteen large ships boats provided in the kit, a mixture of cutters and motor boats and each is made up from multiple parts, including propellers, propeller shafts, rudders, etc, but strangely the rowing boats are not provided with any oars. They may have been stored elsewhere when cruising, but it would have been nice to have some for interest. The completed boats are then attached to their respective cradles.
Finally we come to the armament. There are four, six piece UP mountings, with the option of using PE or plastic parts to build them, six, seven piece four inch secondary turrets, and three, eighteen piece octuple 2pdr PomPoms. The main turrets are very nicely moulded, although perhaps a little deep. Each turret is made up from the turret, turret base, trunnion mounts, and two slide moulded gun barrels. Each turret is then fitted with a four piece rangefinder mounted to the rear, but only B turret is then fitted with a UP mounting platform that sits astride the rangefinder and X turret is fitted with two platforms that are attached to the starboard side of the turret roof. The completed armament is then fitted to the model.
To complete the model, a full ships worth of railings is provided in PE, as well as four accommodation ladders, four Jacobs ladders and a pair of lifering quick release racks. Oh and of course the rigging and painting to the modellers taste.
Decals
For the size of the model, the decal sheet is actually quite small and contains only the ships two nameplates for the rear quarters and a selection of Union Jacks and White Ensigns in different sizes and in straight or wavy form along with two Vice Admiral’s pennants. They are nicely produced and appear to have a nice thin carrier film and to be in register.
Conclusion
It’s been a little while since this kit has been released, and its popularity has meant that we have only now been able to get hold of it. Overall impressions are very good, with the hull and most of the structure being pretty accurate overall. It’s just a shame that Trumpeter, once again, have snatched defeat from what would have been a great victory with the difference in funnel sizes even without the smaller discrepancies. It’s still a wonderful kit and with a super detail set from the likes of Pontos, who look like they are including a new resin funnel, and Mk1 Designs you can relatively easily produce an amazing, museum standard model.
Review sample courtesy of
The forthcoming Pontos Model set features a solution for the unequal sized funnel problem, as well as numerous other errors in splinter shields and superstructure shapes. Technically it's the aft funnel that's too narrow longitudinally.
I'm confident the aftermarket community will resolve this in different ways for different folks.
