Tu-144 question
stevej60
Hi folks,I'm at the decalling stage on Revell/ICM's Tu-144,two types of burner can were supplied I used the traditional(looks
like a Phantom's) rather than the smooth with a large bulbous centre fitted,Trawling round the web I cant find which serials
matched the ones I,ve used! It looks like possibly Revels choices of serials differs from ICM's as a build on finescale has
codes not on the Revell sheet with the cans I used,any help would by appreciated.
The one "with" cones is Tu-144D, The first Tu-144D wore CCCP-77111, i.e. you can use 77101 to 77110 except 77105 that was converted to "D" specification.
77109 and 77110 were the only ones that flew with PAX
There were no 77104 as it was registered as 77144
By series:
01-1 - 77101
01-2 - 77102
02-1 - 77103
02-2 - 77144
03-1 - 77105 converted to "D"
04-1 - 77106
04-2 - 77108
05-1 - 77107
05-2 - 77109
06-1 - 77110
All these planes were slightly different, probably the most prominent difference being the lack of wing tips on some machines - I don't remember the story, can verify, if needed
Wingtips
77101, 77102 - with wingtips
<Airliners.net pic removed - please read the reason here.>
77103 - 77110 - no wingtips
Wingtips were back on "D" version
Edited by Mike
Removing Airliners.net picture.
Many Thanks Alexey,I can make the codes from those supplied,despite a lot of folk treating the kit with trepidation so far I've found it very enjoyable
here's where I am with her now.
With this style of the cheatline you cannot do 77101, 77102 and 77103 as they carried the tail flag in a different position and had red "Ty" logo and door outlines
You can do 77144-77110 but you need to make sure your wingtip configuration is correct
Aeroflot%20Tu-144%20CCCP-77144%20(74)(Gr
  • 2 years later...
By series:
01-1 - 77101
01-2 - 77102
02-1 - 77103
02-2 - 77144
04-1 - 77106
04-2 - 77108
05-1 - 77107
05-2 - 77109
06-1 - 77110
Does anyone know if both wingtip types are included in the kit, and if so, what parts should be used for which version?
  • 2 years later...
Just got myself an ICM Tu-144D (14402) and I'm planning to build OOB as 77112 (I must be ill, OOB and non whif?, that's not me!?) as I have a hankering for something with bare metal engines.
My question is, does anybody know if the Bra.Z Kolesov RD36-51A exhaust nozzles have hollow centre cones or is it solid like the kit parts?
Hollow, as I remember. Can take a look, they are lurking somewhere in the spare box
10 hours ago, Abandoned Project said:
Just a thought, are they worth buying? Seeing as you have a set lurking in the spares box?
I did not buy them separately, long before ICM Ivo from BraZ has released full resin kit that contained exhausts for both A and D versions
