lesthegringo Posted August 30, 2016 Share Posted August 30, 2016 (edited) Gents, my son is building a KV2 tank, and it calls out Gunze 135 flat russian green, however the only local seller has just closed, and the online seller does not have any stock. I would normally resort to seeing what is the closest alternative MM, Humbrol or Tamiya colour, but as I don't have the jar to compare I'm stuck. Can you suggest a similar colour from those ranges mentioned? Super accuracy not essential, but a reasonable match would be good - weathering will hide any slight errors! Thanks guys Les Edited August 30, 2016 by lesthegringo Link to comment Share on other sites More sharing options...
demiles Posted August 30, 2016 Share Posted August 30, 2016 Hi Les, For me finding Gunze Mr. Color equivalents has been difficult. Next try to get a good colour match for Russian 4BO is the same as IDF sand grey or WW2 German Dark Yellow; however, from everything that I have found a good match green is either FS35096 mixing Tamiya as follows: 34098 -- Cougar/Grizzly/Husky -- XF67 NATO Green:3 parts + XF59 Dessert Yellow:2 parts. 34096 -- Dark Green XF61 Dark Green:4 parts + XF2 White:1 part. I feel that FS 34098 may be closer to the colour but I’m happy to be mocked. Alternates are for 34096:Humbrol 30, Lifecolor UA054 or Model Master 1786; Alternates are for 34098:Lifecolor UA138 Hope this helps. David Link to comment Share on other sites More sharing options...
lesthegringo Posted August 30, 2016 Author Share Posted August 30, 2016 (edited) Thanks, got plenty of Humbrol 30, will use that Cheers Les Edited September 1, 2016 by lesthegringo Link to comment Share on other sites More sharing options...
Aardvark Posted December 24, 2018 Share Posted December 24, 2018 On 8/30/2016 at 6:46 AM, lesthegringo said: Gents, my son is building a KV2 tank, and it calls out Gunze 135 flat russian green, however the only local seller has just closed, and the online seller does not have any stock. I would normally resort to seeing what is the closest alternative MM, Humbrol or Tamiya colour, but as I don't have the jar to compare I'm stuck. Can you suggest a similar colour from those ranges mentioned? Sorry I'm writing now, but I just read this topic yesterday. Here is the color Gunze 135 in the bottle: This enamel did not open from the model shop and dried two years after the date of purchase. Yes, I have a special liquid to restore the dried enamels. But nonetheless. As for the equivalent, I do not know yet. I will try to see what colors can be close, but it seems to me that this is not a Russian tank color. Yes, the color of many tanks of monuments on pedestals is similar to this, perhaps there are some modern tanks in such colors, but I think this color is too bright. As for my, this colour close to Russian aircraft radome green... I hope this will help those who will have similar questions on Gunze 135! B.R. Serge P.S. For Russian tanks Gunze maked special enamel 4BO two version's: Link to comment Share on other sites More sharing options...
