FW190 A-8 'Brown 6'
WNr 175140, JG26, Melsbroek, Belgium, July 1944
Kit: 1/72 Airfix Starter Set
Extras: Tamiya tape seatbelts and EZ-Line aerial wire
Paints: Humbrol, Revell and Citadel acrylics all applied by brush
WIP: Here
This was my build for the FW190 GB and was in in fact my first build of a German aircraft. I mostly enjoyed the build although the kit itself did try to fight back at times. The fit is not great in places and I think that it really couldn't be considered a 'Starter Set'...........I think if this had been the first kit I had ever attempted it would probably have been my last. Full details of the issues I had can be found in my WIP here. I also had some issues with the paints I used - I tried Humbrol's RLM range for the first time but found them a little difficult to use compared to the other Humbrol paints I have used before.
I also took a lot more photos on my Spitfire display shelf:
......and a few of the above photos in B&W:
Finally a big thank you to all the people who contributed to my build thread - especially Troy Smith who found me photos of the actual aircraft and offered advice about the necessary paints.........thank you Troy.
Kind regards,
Stix
EDIT: 22/08/16 Troy Smith spotted in my earlier photos that there was a problem with the gear doors - I had shortened the legs a touch but hadn't altered the doors. I have now corrected the problem and retaken the photos. As the light seemed better I have taken a few more which I have included above.
Edited by PlaStix
  • Like 37
Congratulations Stix. Very nice indeed.
And you're right, it shouldn't be the subject of a starter set. The old tool version would actually be more suitable.
I gave up wrestling with mine, and kicked it into touch (very satisfying!).
Interesting WIP thread too.
Great job Stix, especially for a smaller scale model! What do you use to get the background images?
Martin :thumbsup2::)
Great 190. I built the A-8 a few months back and despite it being a relatively new kit from Airfix I remember it being a bit of a pain in places, especially around the engine/cannon area - lots of filler required; looks like you've beaten it though! How did you attach the EZ-line to the canopy - it looks very clean? I've put off adding to mine as I'm nervous I'll wreck it!
Hi Ian and thank you very much for your comments. Sorry you weren't able to finish yours - it was a bit touch and go with mine in places. It is a shame the manufacturers don't spend a bit of time checking whether kits are actually build-able by average people - especially those they put out as starter sets.
Hi Martin and thank you too for your comments. The background image was a on a copyright free image hosting site many years ago. I have looked for it since and cannot find it any more. I remember I put something like airstrip panorama into Google and this was one of several that were on this particular site - I have no idea what it was called now. This one turned out to be the most usable. It was a massive image which I worked on in Photoshop to tone down the colours and slightly blur it. I only ended up using about 3/4 of it because there were some distinct buildings on part of it. I got it originally to go behind my Spitfire collection but I now use it for quite a lot of my photographs. The image was printed out across 4 A4 sheets of paper which I laminated in matt laminating pouches.
Please let me know if you need any more information.
Kind regards,
Stix
Very nice `190, looks great
Thank you very much Russ. :thumbsup:
Lovely looking 190 Stix,great photo's as well....
Thank you very much as well Vince. :thumbsup:
Kind regards,
Stix
That came out real nice. Though to my old eye, WW2 Luftwaffe aircraft don't look right without the swastika on the tail.
Chris
Excellent work stix and very nicely brush painted and weathered too.
Regards
Dave
Hello! And thank you for your comments. Yeah the fit is very poor in places - I'm glad you were able to finish yours too. I attached the EZ-Line by first of all studying quite a few photos to see where it was supposed to attach and realised that there was no distinct place on the canopy Airfix have provided. There is a sight ridge on the inside of the canopy which runs back from the front frame so I decided to attach the wire just behind it. I used a sharp sowing needle to make a small hole on the outside top of the canopy, directly behind where the ridge is on the inside. I then used a .3mm micro-drill, but in my fingers rather than in the pin-vice, to drill a hole right through where I'd used the needle. I find I have more control for delicate drilling if I turn the drill between my forefinger and thumb. Once I'd carefully cleaned off the burr on the inside, with the drill, I fed the EZ-Line through the hole so there was a couple of centimeters on the inside. Next I put a tiny amount of Super Glue on the very end of the inside length of EZ-Line. Finally I gently/'slowly pulled on the outside length of EZ-Line so that the Super Glued bit attached itself inside the hole. I have found Super Glue works really well with EZ-Line - almost giving instant hold.
Hope that is of some use. Please let me know if anything needs more clarification.
Kind regards,
Stix
very nice build of this iconic Luftwaffe fighter. like it!
Michael
Hi Michael and thank you very much for your kind comments.
I meant to include some of the photos that Troy found of how the actual aircraft ended up in my original post but forgot - so here they are now:
Kind regards,
Stix
Edited by PlaStix
Kind regards,
Stix
Thanks for the very detailed response... it had crossed my mind to drill through the canopy and connect it to the point just behind the seat but I have glued the canopy down now but then I suppose it would come up with gentle persuasion. I'll have a go over the next few weeks and then share the result! I'll make sure I put my ultra steady hands on that day :S
Very nice, it looks fantastic and your photos are very good, all very realistic. I have this starter kit courtesy of the recent Home Bargains Airfix deals and I'm quite looking forward to it. I'll definitely be using your excellent model and pics as a reference when I do mine. If it turns out even half as good as yours I'll be pleased.
Finnthedude.
Nice job Stix :thumbsup2:
Glad you decided to try your hand on a German aircraft and camo.
On the starter kit thing as far back as I remember when I "started" building kits I didn't have a clue what "fit" was so they might be safe!! :analintruder:
Looking forward to your next foray.
Bruce
Chris
Hi Chris and thank you very much. I do know what you mean about the missing swastika. Unfortunately Airfix don't provide one in the box and, as this is my first and only one of two German aircraft kits I own (the other being another starter set from Airfix) I don't have any swastikas in reserve. I did wonder about using masking tape to try and paint one but I found it a bit tricky to draw out accurately, let alone cut out. If I acquire some that are suitable in future I may well add them.
Kind regards,
Stix
Great to see yo win the battle over this difficult kit Stix,turned out a beauty in the end though,great job :thumbsup:
Regards
Dave
Cheers Dave! That's very kind of you to say. :thumbsup:
Kind regards,
Stix
Well I hope it goes well if you do decide to add it!
Finnthedude.
Thank you Finnthedude. When you do get around to making yours have a check through my WIP (Here) as there are some issues with the kit - especially around the area in front of the canaopy.
Some more on Brown 6 as she was found late in the war, though some of the camo info might be a bit suspect.
Steve.
Hi Steve and thank you very much for the link - very interesting!
Kind regards,
Stix
Well done mate :)
Thank you Pawel! :cheers:
Bruce
Hi Bruce and thank you very much for your comments. Interesting point about the "fit" but I think for some this kit just won't go together at all!!
Kind regards,
Stix
Hi Steve and thank you. Yeah it was a bit of a struggle at times but it went together okay.
Tomorrow I start work on some 1/48 WW2 German tanks in the MTO GB. Can't wait!! :bounce:
Kind regards,
Stix
