1/72 Italeri UH-1B Huey in a Japanese Scheme
Nigel Heath
Today I first masked up for the matt black antiglare patch on the nose, I did this quite loosely so as not to get a step in the paint:
Here's how it came out along with the front aerial pylons:
While that was drying I mixed up a dark grey wash and redid the rotors:
Much better I think.
Then I tackled the short decals on the tail rotor. I soon found a good match for the red:
When the red bands were done and dry I sealed them in with liquid decal film:
Here they are finished and ready for some matt varnish:
By now the black was dry so I got that masked up:
I had left the yellow band as long as I could before masking as it's a semi-gloss and is prone to reacting with masking tape if not completely cured. I have also established from reference photos that the grab handle should actually be all olive drab so I needed to mask around its base. I used 1.2mm punch to create some appropriate custom masking:
Those were used like so:
I made a bit of an error with this area of dayglo on the underside. The side bands should in fact stop just above the skids:
With all the masking done I applied the olive drab:
Not forgetting the side doors and skids:
While that was drying I added the bristles to the front aerials (above are the PE replacements) and realised I should have included the wipers in the black spraying session this morning:
I think its best to let the green harden up overnight and then things will be almost ready for decal application.
Bye for now,
Nigel
  • Like 11
Tidy work as ever Nigel.
Am I the only one who finds it strange to see dayglo bands over a camouflage scheme? :hmmm:
It does defeat the purpose doesn't it!?
Looking great Nigel, echoing Craig's point that we may see this in the gallery soon.
Today, after doing all the paint touchups, I masked and brush painted the bevel gearbox with Dark Sea Grey:
While all the paint was drying I started work on a pitot tube using 0.3 and 0.5mm nickel silver tubes and 0.3mm rod to stop the tube collapsing when I bent it:
Unfortunately when I tried to bend it I got a different failure mode and the tube snapped so I made another one using brass tube this time:
In preparation for the decals I then gave the main craft a coat of Aqua Gloss and while I had the airbrush out also got some black on the wipers and olive drab on the new pitot tube:
Decalling application well underway, I had to add black rectangle under these NH decals, I sealed it with liquid decal film before applying the initials:
Here are all the kit decals done:
I will go over my reference pictures to see if there are any additional stencils required.
Bye for now,
Nigel
  • Like 12
The full colour decals and the dayglo paint really bring this scheme to life, one I've considered doing myself in 1/48.
More great work on the pitots, they look fantastic and much more realistic than the kit items.
I think you are going to be first across the finish line by a big margin.
This is all from yesterday, I couldn't get Photobucket to work last night. Inspecting the underside I found it had this crazed appearance, I have seen this before and know that it should vanish under a coat of matt varnish:
I had got most of the decals on so applied a second coat of Aqua gloss to protect them:
I did discover a few stencils that I added using decals from my spares box:
I then painted some matt black on the ski steps to represent the anti-slip patches:
After about four coats of white primer I brush painted some yellow on the tips of the main rotor:
Then it was onto final assembly steps, on went the pitot tube and blade aerial:
Tail skid:
Skis:
Front aerials:
I really should have done this before assembling all the sticky out bits but then I applied a panel line wash using Payne's Grey oil paint:
Here is the wash finished:
Next everything got a coat of matt varnish:
I started to remove the masking:
Next some light fabrication. I used plastic from a clear red cocktail stick and 1mm hole to make the light that goes on top of the engine:
For the four navigation lights I used the same technique but clear sprue and a 1.2mm hole, they were then sawn in half and coated with clear green and red, I made up a few spares to be on the safe side:
I thought some rigging wires would look good on this so started on the job of adding them using EZ line and a short length of 0.4mm brass tube:
After two coats of clear paint and when they were dry I started to add the navigation lights:
I used some more clear sprue to make the formation light for the tail (1.2mm dia.) and when sawn off painted the back with Alclad "Chrome":
Here it is glued on with a dab of GS Hypo cement:
Here is the dinky red roof light also glued on with GS Hypo cement:
So here it was a the end of the day, very nearly finished. One of the rings on the skis has gone missing and will have to be replaced and then there are a few paint and varnish touch ups to do but its just about there:
Bye for now,
Nigel
  • Like 13
Today I added the PE wipers using thinned Gator Grip:
Then I added the FM communications aeriel using 0.2mm nickel silver rod:
Then I painted up and added the missing PE ring to the skis:
The very last thing to do were a few paint and varnish touch ups and with those done this is now finished:
The RFI shots can be found in the Gallery here. I start a new job next week back down in England so my modelling will shortly come to a stop, for a while at least.
Bye,
Nigel
  • Like 17
