Sign in to follow this
Julien
Soviet ZSU-57-2 SPAAG - Takom 1:35
Takom 1:35
Following WWII and with the advent of the cold war the Soviets found themselves facing a potential enemy with good ground attack aircraft, they realised that a dedicated Anti-aircraft gun mounting auto cannons not machine guns was needed. To keep up with armoured forces this would also need to be tracked. Using the newest tank chassis the T-54 it was proposed as objeck 500 and would mount a twin 57mm S-68 automatic cannon. Development began in the late 1940's with updates in the early 1950's, finally entering service in 1955. The system relied entirely on optical/mechanical computing and carried no radar system which proved to be a major weakness. There were proposals to upgrade the system but these did not come to fruition as newer systems would come online. These guns would be retired on the early 1970s to be replaced by ZSU-23-4s.
Like many Soviet systems of the time they would be supplied to their sattilite states and the system was used by Cuba, Finland, Iraq and Egypt as well as the normal Warsaw pact countries. In combat they were using Vietnam and the Middle East. Lastly in the Yugoslav wars in the 1990s, and the invasion of Iraq.
The Kit
Like many kits this was earlier kitted by Tamyia, and now the Takom version will battle it out with a Trumpeter kit. Takom are making full use of their T-54/55 kits by producing this kit which utilises the same chassis. A fairly packed box arrives from Takom here. Along with the main lower hull plus the Turret there are five main sprues of parts, four sprues of suspension/wheel components, two sprues of gun parts, five sprues of ammunition; and a bag of track components. In addition there is a clear sprue, a sheet of photo etch, a metal tow cable, a flexible part which is the stowed canvas cover; and a small sheet of decals. The turret on this vehicle is open and you get a full interior and ammunition load.
Construction begins with the running gear of the tank. The suspension comments are added to the hull. The main wheels feature an inner and outer wheel, here Takom have moulded the rubber tyre as a separate part which needs to be added to the outside of the steel wheel. Eight main wheels in total are made up along with a two drive sprockets and two idler wheels. Once all the wheels are constructed they can be added to the lower hull.
Once the lower hull is complete construction moves to the upper hull. The hatches here can be left open, but as there is no interior there is little point. The rear grill is added along with spare tracklinks carried on the hull.
The tracks are the next major parts to be added. Here you get individual track links, but they are not the type you click together, you will have to glue them. I suspect the best way is to do the lower run first and let it dry. The upper parts can be constructed, and when your glue is going off they should still be flexible enough to drape around the wheels to get the run looking right. Not the best solution. There are 92 links per side.
The upper side covers for the tracks can now be built up. These feature equipment boxes on both sides with the front and rear mud guards being added. Once made up they can be attached to the upper hull. There are different configurations or the side parts depending on the country of the vehicle being made. The instructions are as clear as mud here, with a couple for the options being named, but the rest not. Given the various combinations of lockers etc the modeller should consult their references for the vehicle being modelled. Various grab handles, lights, cables etc can now be fitted as needed. There are also various tools and a ditching beam to add to the model.
Once the main hull is completed then we move onto the main event for this kit, the turret with its twin 54mm guns. This is highly detailed with a full interior. Construction starts with the central mounting platform. This is the core of the gun system. All of the sighting and control systems will mount to this. The lower controls and sighting systems are built up and added to this central part. Crew seats are added, then the barrels go one, these are one piece each with well moulded muzzle brakes.
Attention now moves to the inside of the main turret. The turret basket is made up. A full ammunition load is made up and added to the turret base, along with crew seats and controls. The turret basket can be added to the lower side and then the guns mounted. Additional ammunition is then added inside the turret.
The main upper part of the turret is the next to receive attention. This single moulded part receives more ammunition stowage on the inside, and a series of grab handles on the outside. The rear turret basket is made up from photo-etch and added. The upper and lower turret parts can then be joined and fitted to the hull. The flexible cover can then be added to the rear of the turret.
Decals
These vehicles carried little in the way of markings, and even with a small decal sheet you are able to build 11 versions out of the box.
  • Egyptian Army - Six Day War
  • Finnish Army
  • Iranian Army - Iran Iraq War
  • Iranian Army
  • PKK North Iraq/Kurdistan
  • East German Army
  • Red Army - Moscow Parade 1960
  • Serbian Army - Balkan War 1991
  • Syrian Army - Yom Kippur War 1973
  • North Vietnamese Army - Vietnam War - 2 different variants
Conclusion
This is a really good kit, just be careful with the tracks, and consult your references as the instructions are a little vague in places. It is good to see other tracked vehicles apart from tanks now appearing for modellers. Overall highly recommended
Review sample courtesy of
Nice review. :thumbsup: Trumpeters ZSU-57 kit has just been released, and it will be interesting to see a comparison .
It will be. We wait ages for this type of kit and then two arrive at nearly the same time.
Or three in some cases. :winkgrin:
Pleased to see a good kit of this vehicle, hopeful someone might do one in 1/48. :pray:
Many thanks! Two points of interest perhaps -
1. Magic Models do turned gun barrels and ammunition rounds (unfired and fired) for the ZPU-57-2. It's beyond reasonable cost for me to replace the full stowage, but I have bought a pack of fired cartridge cases to chuck into the empty cartridge basket.
2. The cartridge cases seem to vary in colour - the Finnish museum example at Parola has brass cartridge cases but others on film or photo have an aluminium or steel plated appearance - quite greasy or grimy as well.
Do you have a link to the magic models stuff?
Thx.
Julien
