snapper_city Posted July 26, 2016 Share Posted July 26, 2016 Looking good. I wonder if Eduard will release a Brassin resin engine for this someday? Link to comment Share on other sites More sharing options...
dazdot Posted July 27, 2016 Share Posted July 27, 2016 It doesn't really need a brassin engine the plastic one is damn good but it just needs patience to put together. The real problem is that none of it can be seen if you close it up 1 Link to comment Share on other sites More sharing options...
smuts Posted July 28, 2016 Share Posted July 28, 2016 Looking good Andy 1 Link to comment Share on other sites More sharing options...
Kahunaminor Posted July 29, 2016 Author Share Posted July 29, 2016 Thanks gents,Forging ahead in no particular order. A colleague once remarked that I use the instructions only as a abstract and they are somebody else's idea on how to build any way! I have started working on the cockpit, only because if I don't I cannot really proceed! I added some 0.05 rod to the base of the control column and starboard wall and a half piece to the port. Eduard PE pedals and map case and some 0.03 lead wire for the control column. Then base coat of Warbirds Enamel RLM 66 to the interiors:The side panel PE required about 1mm to be removed from the front to sit correctly. The lower instrument cluster was fitted and then all got some Future to bond them and set aside to dry:The Ultracast seat got its RLM 66 base coat and then I commenced detailing with the leather thigh straps whilst I had the MM Leather out for the control column boot and toe clips:I had detached the instrument shroud from the sprue and attached the upper instrument cluster backing board so I could paint it. It was too tempting just sitting there so I attached it using a small piece of styrene glued on the underside, between the forward edge and the panel. This addresses the issue of attaching it to just the forward edge of the cockpit. There is a little thin gap on the sides but the windscreen will cover that. It is just wide enough to allow a bond on each side:The two piece PE instruments were set in place with Future:Having pushed my luck far enough in that direction, I went back to the wings and wheels. The MLG braces, retraction locks and engine cover were fitted without incident. I then thinned the material around the edges of the wing root cannon cartridge ejector openings to give a better scale appearance:The wing upper interiors that would be visible through the ejector openings were sprayed MM Flat Black and the chutes for the nose mounted MG 17 ejector chutes were marked out for removing the centres to give the impression of open chutes rather than closed:I think I have tempted the modelling Gods enough today. You can just see the instrument shroud support block I added. The large piece of round rod that is visible on the lower port engine support is there to rectify an overzealous use of snips.Regards, 3 Link to comment Share on other sites More sharing options...
Parabat Posted July 29, 2016 Share Posted July 29, 2016 Nice update, looking good. Link to comment Share on other sites More sharing options...
dazdot Posted July 30, 2016 Share Posted July 30, 2016 That looks the business Kent, nice work Link to comment Share on other sites More sharing options...
Calum Posted July 30, 2016 Share Posted July 30, 2016 Cracking along there Kent Link to comment Share on other sites More sharing options...
Kahunaminor Posted July 30, 2016 Author Share Posted July 30, 2016 Thanks guys, I just hope I haven't created a rod for my back by skipping ahead too far with the front end! Regards, Link to comment Share on other sites More sharing options...
dazdot Posted July 31, 2016 Share Posted July 31, 2016 I wouldn't think so Kent it all looks the business to me Link to comment Share on other sites More sharing options...
Kahunaminor Posted July 31, 2016 Author Share Posted July 31, 2016 Thanks lads, I continued working the ejection chutes, first drilling two holes in each then cleaning out the material with a micro chisel. Then a coat of Warbirds RLM 02: The rest of the internals were shot with RLM 02: I also chain drilled the wing root cannon openings to incorporate the covers: The covers are meant to fit over the inners with the interior ribbing setting the position. However there is no wriggle room, so some of the ribs were removed. This resulted in a better idea of fit and what needs to be done to get the seal correct: I continued with the cockpit tub, adding some more PE: Regards, 3 Link to comment Share on other sites More sharing options...
Kahunaminor Posted August 1, 2016 Author Share Posted August 1, 2016 So, I set about finishing off the cockpit PE general finagling...before I knew it the cockpit was installed: I left the seat until later as I will now have to gloss coat, wash, weather and matte coat with the cockpit installed. I decided to test fit the lower wings and dry fit them to a point where the seams were almost invisible and thought, " I don't want to miss that chance, I'll just add a spot of glue to the lower wing joins to hold it." Well, before I knew it, the lower wings were attached and setting up nicely: Thanks for looking, 3 Link to comment Share on other sites More sharing options...
Kahunaminor Posted August 1, 2016 Author Share Posted August 1, 2016 Not to self....do not proceed with attaching cowling, no matter HOW tempting to check the fit, before you prepare, paint and install the exhausts! Regards, 1 Link to comment Share on other sites More sharing options...
PlaStix Posted August 1, 2016 Share Posted August 1, 2016 Hi Kent. More very impressive progress! Kind regards, Stix Link to comment Share on other sites More sharing options...
dazdot Posted August 1, 2016 Share Posted August 1, 2016 Not to self....do not proceed with attaching cowling, no matter HOW tempting to check the fit, before you prepare, paint and install the exhausts! Regards, Nice work Kent and you're right about that Not to self....do not proceed with attaching cowling, no matter HOW tempting to check the fit, before you prepare, paint and install the exhausts! Regards, Nice work Kent and you're right about that Link to comment Share on other sites More sharing options...
Kahunaminor Posted August 2, 2016 Author Share Posted August 2, 2016 Welcome back, True to my word, I spent the morning working on the exhaust. I found the longitudinal centre of each and marked them with a pin scriber in two places, about central to the micro drill I was using. I then drilled two shallow holes and cleaned out the centre, leaving a roughly similar shape to the exhaust outlets. As I intended to replicate the QB set, I cut the prepared ends of each eaxhaust and glued them to the interior of the cowling. I had marked the upper and lower extremes of the cowling wall. It was then a matter of align, check, re-align until I was happy: The lower exhaust was done the same way and then the downside to my haste became obvious. After about 30 minutes of attempting to manipulate the piece into place, I gave up and will install them from the outside later: I worked the MG 17 troughs, both lower and upper to get a better fit for the Master Barrels MG 17 tips. Once I was happy the only thing left to do was attach the cowling: Pretty happy with that. Thanks for looking. 3 Link to comment Share on other sites More sharing options...
kpc7676 Posted August 2, 2016 Share Posted August 2, 2016 Nice buddy! 1 Link to comment Share on other sites More sharing options...
PlaStix Posted August 3, 2016 Share Posted August 3, 2016 Certainly looks rather good with the cowl in place Kent. Very nice. 1 Link to comment Share on other sites More sharing options...
dazdot Posted August 6, 2016 Share Posted August 6, 2016 Brilliant work Kent mine is stallled waiting paint 1 Link to comment Share on other sites More sharing options...
fewr9fkr9595 Posted August 7, 2016 Share Posted August 7, 2016 Well done! This helps disprove all those horror stories about the eduard 190 a & d kits being poor fitting etc, esp when being 'closed up' I have done a few myself and as long as you take your time, follow the instructions and test fit (all the things you'd do with any model surely?) then you can get results like this. Keep it up 👍🏻 1 Link to comment Share on other sites More sharing options...
Kahunaminor Posted August 9, 2016 Author Share Posted August 9, 2016 Thanks guys, I appreciate the good words. I agree Tony, as I have said previously, the bad reputation is not entirely deserved. They build beautifully if done as designed to be (opened up) but to close them requires a little bit of skill as you are intentionally altering the engineering from the original intent. There are some places where one has to wonder why Eduard did it that way, (the IP shroud springs to mind) but these are made with very little tolerances. Anyway onto the update. I am concentrating on getting the wing root seam as close to perfect as I can, as there should be no seam forward of the cannon bay at all, being a one piece pressed metal construction. It is a case of dry fit, sand, chisel or scrape then dry fit again to locate "high" points in the spars, wing root cannon assemblies or fuselage to wing joins: I as a little overzealous in my sanding of the port wing root. I could not get a solid join and light showed through the underside join in the MLG bay. So a piece of thin card was glued to the inner edge, allowed to dry and then cut to shape: The result is pretty good, remembering these pieces are just sitting in place with some finger pressure: With various sections having had their gloss coat in preparation for washes, I turned my attention to the anemic shroud protector. On a previous build, I just painted it up. This time I wanted to beef it up so a piece of 1mm rod was cut and glued centrally to the shroud. Once this area has dried I intend to carefully bend the rod to conform to shape, ementing a bit at a time and allowing it to cure: That's all for now, thanks looking in. 4 Link to comment Share on other sites More sharing options...
Kahunaminor Posted August 10, 2016 Author Share Posted August 10, 2016 Welcome back, I have washed the interiors of the MLG and cockpit with AK Neutral grey enamel wash. The wing uppers have been attached with promising results. The port rear moved a little when I added the tape for dihedral but some PPP will fix that. The leather shroud pad has been trimmed and fixed into position: I have started detailing the MLG with fuel lines and wiring and the seat has been finished and awaits its matte coat and weathering: Regards, 2 Link to comment Share on other sites More sharing options...
Kahunaminor Posted August 10, 2016 Author Share Posted August 10, 2016 A quick update....some paint to the shroud pad and the Revi C12 gunsight and wing root cannon covers installed: Obviously a bit of fettling to do. I shall set about that once I have attached the windshield and masked the area off to prevent dust getting in. Regards, 5 Link to comment Share on other sites More sharing options...
Kahunaminor Posted August 11, 2016 Author Share Posted August 11, 2016 Welcome back, Steady progress this morning. I have applied AK Ultra Flat varnish to the finished interiors of the MLG and cockpit.The seat and the reflector glass and sun shield for the gunsight have been installed (I need to adjust the rear piece I can see!). I have dipped the clear parts in "Pledge" and once dry, I will mask and attach the windshield: Regards, 3 Link to comment Share on other sites More sharing options...
Canso65 Posted August 13, 2016 Share Posted August 13, 2016 Very nice progress Kent. Link to comment Share on other sites More sharing options...
Kahunaminor Posted August 13, 2016 Author Share Posted August 13, 2016 Thanks Canso65, One of the deficiencies of the Eduard kit is in the canopy internal structure. It is very simplified for an area that is so obviously on show. In my previous A8 build a couple of years ago, I had resorted to a crude but effective scratchbuilding attempt at the internals to at least give an impression of what actually lay beneath: Eduard have not adapted their current (first release) moulds and we are still given the basic three pieces to represent the framing. They may address this in their future release. However, in 2010 (according to the stamp on the PE) they did release some upgraded PE sets for their Fw190D series aircraft (D9, D11 and D13). These were in the new (old?) brass finish and contain a wealth of detail to jazz up your D series kits. The good thing is a lot of it can be used on an A series as well: Including this little piece of gold (no pun intended) the internal canopy framing: The only thing I have to ensure is the scheme I do for the D later on doesn't use it. I did have to undertake some remedial filling due to overzealous use of a drill bit on the outboard MG-FF apertures. I filled each gaping hole with some styrene rod (from the spares box...nothing gets thrown out!) which I will sand during the leading edge work and re drill to a smaller, more appropriate, aperture: Thanks for checking in! 4 Link to comment Share on other sites More sharing options...
