AlexN Posted July 11, 2016 Share Posted July 11, 2016 Fifth! Crikey, but there are a lot of stencil markings on those weapons pods! 1 Link to comment Share on other sites More sharing options...
Tomoshenko Posted July 11, 2016 Share Posted July 11, 2016 (edited) Sixed. Edited July 11, 2016 by Tomoshenko 1 Link to comment Share on other sites More sharing options...
Nigel Heath Posted July 12, 2016 Author Share Posted July 12, 2016 Busy with other matters today I have not got much done. I did however start on the fabrication of this blade aerial which is missing from this kit. The instructions provide full size drawings so I drew it out there first: I am going to add a bar across the top but here's how it looks for now: Bye for now, Nigel 5 Link to comment Share on other sites More sharing options...
Nigel Heath Posted July 13, 2016 Author Share Posted July 13, 2016 Today I have added some 0.3mm rod to the top of the blade aerial: I have also made the replacement for the plastic blade aerial I removed on the underside: I got that fitted along with a protective Blu Tack buffer: I then did a little airbrushing, giving the canopy a coat of the cockpit interior grey: As well as giving the rotors a light misting of matt varnish so as to preserve a slight satin sheen on the blades: I think I have now run out of things to do on this. I don't want to proceed with primer until the PE set arrives from the Ukraine. I don't think much of it will be usable but I would rather wait to see exactly what it supplies. Bye for now, Nigel 7 Link to comment Share on other sites More sharing options...
CedB Posted July 13, 2016 Share Posted July 13, 2016 Very nice Nigel, as usual! 'Blu Tack buffer' - great idea and now in my 'toolkit' - thanks 1 Link to comment Share on other sites More sharing options...
Nigel Heath Posted July 14, 2016 Author Share Posted July 14, 2016 As I'm probably not going to get the PE set for a week or two I've started on my next project here. Link to comment Share on other sites More sharing options...
Nigel Heath Posted July 29, 2016 Author Share Posted July 29, 2016 Evening folks, The PE for this arrived from the Ukraine a few days ago and as I've finished my Hs 132 I'm getting this build underway again. The PE is actually for the single seat Ka 50 so a lot won't be used as it won't fit but frankly I would have got it just for the wiper arm: This door for the underside needs a significant degree of curvature so I rigged up my bending machine with an aluminium rod of the right sort of curvature, the Blu Tack helped with the fixturing process: Here's how it looks in place: I tried to leave some of the fret on this tiny blade aerial to act as a mounting peg but it snapped off when I tried to unite it with its base plate. I'll leave it off for now as its a different colour from the fuselage: Here is the base along with a few other pieces of PE applied: I started to make a rod based replacement for this antenna using 0.4mm rod: I trimmed off part of the PE and got it ready for soldering like this: Here's the finished item: That was then installed on the underside: The last piece of the PE I'm using is the wiper but obviously I leave that off until right at the end: Next I reused one of my bending jigs to make some steps: Here they are fitted: The final job of the day was to fix on the fins and then apply some primer: That's a good place to stop as it can harden up overnight. Bye for now Nigel 9 Link to comment Share on other sites More sharing options...
The Spadgent Posted July 29, 2016 Share Posted July 29, 2016 (edited) Great work with the PE. I'm digging that home made jig, very snazzy. John. Edited July 29, 2016 by The Spadgent 1 Link to comment Share on other sites More sharing options...
phildagreek Posted July 30, 2016 Share Posted July 30, 2016 Looking good! 1 Link to comment Share on other sites More sharing options...
Nigel Heath Posted July 31, 2016 Author Share Posted July 31, 2016 I was at the East of Scotland model show yesterday so didn't get any work done and today I have been mainly repairing some of my models that got damaged by a really aggressive speed bump in Dundee. I have got a bit more done though, first I sanded the primer all over and corrected the odd highlighted flaw with a touch of filler: Then I got some of the blue grey applied to the underside: That can harden up overnight and then it will be masked off in the morning. Bye for now, Nigel 10 Link to comment Share on other sites More sharing options...
Duncan B Posted July 31, 2016 Share Posted July 31, 2016 Did the glue work OK? Duncan B Link to comment Share on other sites More sharing options...
Space Ranger Posted July 31, 2016 Share Posted July 31, 2016 I was at the East of Scotland model show yesterday so didn't get any work done and today I have been mainly repairing some of my models that got damaged by a really aggressive speed bump in Dundee. The color police will be watching even more closely now that you've called attention to yourself with your driving. 2 Link to comment Share on other sites More sharing options...
Nigel Heath Posted July 31, 2016 Author Share Posted July 31, 2016 Did the glue work OK? No, bit of a disaster actually as I managed to spill some on the rotors of the Helix. Link to comment Share on other sites More sharing options...
Nigel Heath Posted August 1, 2016 Author Share Posted August 1, 2016 I have spent most of today masking the undersides ready for the base camouflage colour "Sandy Brown": I got that applied but it has come out a bit rough in places: I think I'll let it harden overnight and then sand all over and have another go. Bye for now, Nigel 5 Link to comment Share on other sites More sharing options...
Pete in Lincs Posted August 1, 2016 Share Posted August 1, 2016 Russian paint was a bit rough. I saw the Mil 24 when it first came to the UK in the early nineties. Eye opener! what a shed. Then again, I saw U.S. Apaches in Germany in the eighties and you could have used the paint as wet n dry. 3 Link to comment Share on other sites More sharing options...
Nigel Heath Posted August 2, 2016 Author Share Posted August 2, 2016 It did not take too long to give it a thorough sanding all over using these tools in more or less this order, finishing with the fibre glass pencil: The finish was roughest in the most inaccessible areas such as between the engines and wings, I'm guessing because of the unfavourable airbrushing angle. That's where I had to resort to the fibre glass pencil. I think the paint was a bit too thick as well. This time I thinned the paint a bit more and used self levelling thinner and got a much better result: I then spent the next four hours masking up for the second camouflage colour: Here it is after applying the khaki green: I bet you want to know what it looks like with the masking off - me too. As soon as it was touch dry I removed the masking: As you can see I have managed to rip of the top blade aerial, I think its better left off now until later in the build. The final stage of the colour scheme are some areas of black that I will start on tomorrow. Bye for now, Nigel 9 Link to comment Share on other sites More sharing options...
AlexN Posted August 2, 2016 Share Posted August 2, 2016 Nice - in the mathematical sense . Quick question, Nigel: what diameter is the glass fibre pencil tip? They sell them over here at 4 mm (RS Components). Cheers, Alex. 1 Link to comment Share on other sites More sharing options...
milktrip Posted August 3, 2016 Share Posted August 3, 2016 Coming along beautifully Nigel. I hope Dundee was good fun 1 Link to comment Share on other sites More sharing options...
Nigel Heath Posted August 3, 2016 Author Share Posted August 3, 2016 Dundee was good, I got two second and two third places in the competition. what diameter is the glass fibre pencil tip? The tip on the one I used here is about 2mm in diameter. I also have a much chunkier one that is 8mm in diameter. 4 Link to comment Share on other sites More sharing options...
milktrip Posted August 3, 2016 Share Posted August 3, 2016 Excellent and congratulations Nigel! 1 Link to comment Share on other sites More sharing options...
Nigel Heath Posted August 3, 2016 Author Share Posted August 3, 2016 Today I got the masking for the black areas done with the help of two sandwich bags: This is how they came out along with the PE wiper: Now I could also remove the masking from the underside: That done I applied a coat of Aqua Gloss: Now all things are ready for decals in the morrow. Bye for now, Nigel 11 Link to comment Share on other sites More sharing options...
CedB Posted August 3, 2016 Share Posted August 3, 2016 Very nice Nigel and congrats on the awards! 1 Link to comment Share on other sites More sharing options...
TonyTiger66 Posted August 4, 2016 Share Posted August 4, 2016 Congratulations on Dundee ! It's looking great, looking forward to decals and a bit of a reveal Best regards Tony 1 Link to comment Share on other sites More sharing options...
Nigel Heath Posted August 4, 2016 Author Share Posted August 4, 2016 I have had a full modelling day today and spent virtually all of it getting the decals applied. It was the stencils that took the time, all 117 of them: The Begemot sheet certainly puts the kit's own decal sheet to shame and provides plenty left over for the spares box. Tomorrow I'll apply the final gloss coat and get on with final assembly, the finish line is in sight. Bye for now, Nigel 7 Link to comment Share on other sites More sharing options...
phildagreek Posted August 4, 2016 Share Posted August 4, 2016 Looking sharp! Good paint scheme on that bad boy! 1 Link to comment Share on other sites More sharing options...
