asselin22 Posted June 23, 2016 Share Posted June 23, 2016 I’ve been working with badog software for about a year now I was quite convinced that I can make this drawing in less than an hour but in reality it took to many twists and turns and I started to get really creative with my drawings. So it took a little bit longer than expected. you can see below the outline of the pieces and went at as usual on using 3 mm thick plywood with a 1.1 mm diameter tool with 2 teeth. once all the pieces were cutout of the wood I started to assemble them and had realized that one of the pieces and drawn upside down and if I put it together it would be backwards on the finished model so it was back to the drawing board and I made another piece and erased the original false piece. The entire project took about 15 to 20 minutes to cut if you don’t count the time I lost redoing the DXF files in the bundled software I had received with my machine. here’s an image of the semifinished Barbie doll bookshelf partially assembled before I painted pink. I had to disassemble the entire model in order to get the pieces perfectly covered by the pink well here’s the finished project all painted of the Barbie bookshelf 1 Link to comment Share on other sites More sharing options...
wyverns4 Posted June 23, 2016 Share Posted June 23, 2016 Somebody had fun! I hope your daughter likes it, just be prepared for more, (as the accessories grow...). Christian, exiled to africa and now smiling 1 Link to comment Share on other sites More sharing options...
asselin22 Posted June 24, 2016 Author Share Posted June 24, 2016 (edited) Somebody had fun! I hope your daughter likes it, just be prepared for more, (as the accessories grow...). Christian, exiled to africa and now smiling yes so much fun , thanks Edited June 24, 2016 by asselin22 Link to comment Share on other sites More sharing options...
