Pitot and Refuelling Probes
1:32/1:48/1:72/1:144 Master
Having released the Sukhoi collection, Master Models have also recently released several sets for Western aircraft, with particular emphasis on the three V Bombers in both 1:72 and 1:144.
[AM-32-090] – This pack contains two parts to build up the pitot probe and fairing for the Italeri 1:32 Mirage II. Rather than brass, the two parts have been turned in alluminium and is a simple direct replacement for the kit part.
[AM-48-118] – Another simple replacement pitot probe, this time for the Airfix 1:48 BAC TSR-2, it may have been along time in coming, but it is, nevertheless, a very welcome addition.
[AM-72-097/AM-144-009] – These two sets have been designed for the Airfix 1:72 and any of the 1:144 kits from the likes of Micro-Mir, Anigrand or Welsh Models. Each set contains two very fine pitot probes to replace the slightly clunky kit items.
[AM-72-098/AM-144-010] – These sets contain only one item, the prominent refuelling probe. The 1:72 for he Airfix kit and the 1:144 for either the Anigrand or Great Wall Hobby kits. Unfortunately even though they are meant to be different scales the review samples re exactly he same size, so do check when you buy your 1:144 as it would be absolutely massive when compared to even the kit part. In each case though, you will need to cut the kit part where it joins the nose fairing, drill out the hole then fit the metal part before adding to the model.
[AM-72-099/AM-144-011] – The last of the V bomber sets is naturally for the Victor, either the Matchbox/Revell 1:72 kit or the Anigrand/Welsh Models kits. Whilst he 1:72 set contains the two wing tip mounted pitot probes and the probe end piece for the refuelling probe, the 1:144 set does provide the whole refuelling probe as well as the pitot probes.
Conclusion
Five more very useful additions to the Master Models range. If you thought the 1:72 scale stuff was small, you really should check out the 1:144 scale parts. I would love to know how they produce such small items, with such finesse of detail. Very highly recommended
Review sample courtesy of Piotr at
