matiwashere Posted July 5, 2016 Share Posted July 5, 2016 Very typical for Berlin are also the two tone brick buildings from that time. We still have a few of those around. The primary school I went to had a similar fassade as the one you built and there are quite a few similar ones left. For instance, this is what the police station looks like in the district I grew up: Link to comment Share on other sites More sharing options...
Badder Posted July 6, 2016 Share Posted July 6, 2016 I have only just seen your dio. Very nice composition and balance. If that is your first model in 35 years, I will definitely be keeping an eye your future builds. Nice addition of the boots on the power line, amusing little touch with a story I am sure. Question; what is the OAH over the Cafe Bleu building? Dunno what OAH is, but guessing you mean the 'ivy'? The leaves are made from bits of Silver Birch tree 'catkins'. By pulling them apart you get seeds and 'seed separators'. It's the latter that look like ivy leaves. Great work on the walls. I can see the benefits of using plaster... so much easier to carve than plasticard. But I still like the strength of plastic. Rearguards, Badder Link to comment Share on other sites More sharing options...
modelman182 Posted July 6, 2016 Share Posted July 6, 2016 Can't say I've ever poured a street. I have done something similar with gypsum board however. (dunno what you lot call it over there) Soak one side and peel off the cardboard and carve away! Useful stuff. Hey Tzulscha Thanks for that tip - I'm just drywalling my new man caves and hadn't thought about using the left-overs as diorama material, until I read your post, that is. Crayons - great work. Looking forward to seeing it painted. I may try something similar (but more modern and without battle damage) with the Berlin Camo Chieftain I have part built and painted. Kev 1 Link to comment Share on other sites More sharing options...
Crayons Posted July 6, 2016 Author Share Posted July 6, 2016 Very typical for Berlin are also the two tone brick buildings from that time. We still have a few of those around. The primary school I went to had a similar fassade as the one you built and there are quite a few similar ones left. For instance, this is what the police station looks like in the district I grew up: Thanks for those, the lower portion of the police station photo was how I was originally going to do the building, but could not find any decent photos. I will be saving those pictures if you don't mind. Dunno what OAH is, but guessing you mean the 'ivy'? The leaves are made from bits of Silver Birch tree 'catkins'. By pulling them apart you get seeds and 'seed separators'. It's the latter that look like ivy leaves. Great work on the walls. I can see the benefits of using plaster... so much easier to carve than plasticard. But I still like the strength of plastic. Rearguards, Badder OverAll Height. Thanks for the run down on the ivy, will keep that info in the toolbox. Kev, painting is the last thing on my list. I tend to build everything first and then worry about the paint work. Sadly, I have not had much time of late. 99% finished the hole in the wall, just a few bits of external brick need to be damage up some more. Internal roof cavity brickwork done and chipped out. As this will be visible, I decided to replicate the damage to the brickwork caused to years of damp. Started marking the window frames out. My plan is build them in boxes and then slot the entire section into the plaster window opening. As I am still unhappy with the prospect of one large cement/asphalt coloured block for the road so I am thinking of scribing in two cobble stone crossings 90° to the corner just to add some variation. 7 Link to comment Share on other sites More sharing options...
Badder Posted July 6, 2016 Share Posted July 6, 2016 (edited) Ah, the over all height! Well the Café WAS 280mm, but I'd set it back from the road a bit when compared to the Charcuterie, so I truncated the roof forward of the actual roof ridge. It would have been around 285mm had I extended the roof back (and had it overhanging the base) The Café is now gone, to be replaced by one level with the Charcuterie... in fact only the Charcuterie and road remain. All the rest is going to be replaced. Rearguards Badder Edited July 6, 2016 by Mike Removing large photo quote Link to comment Share on other sites More sharing options...
carloscarneiro Posted July 7, 2016 Share Posted July 7, 2016 WOW, what a work Best regards Carlos Link to comment Share on other sites More sharing options...
Crayons Posted July 16, 2016 Author Share Posted July 16, 2016 Back home again. Haven't had anytime to work on this thanks to work sending me interstate last week to finish off a project they screwed up. Window and a section of decorative wall trim finished off. In situ temporarily. The glazing for the windows will be made from a sheet of plastic that I found in a box of chocolates. Once it is glued into place I will then set about breaking the panes as required. The decorative trim will be on both floors and run the length of the wall sections. The hardest part is going to be destroying/splintering the section the runs along the section of wall that has the hole blown in it. I am sure I will figure something out. 5 Link to comment Share on other sites More sharing options...
Crayons Posted July 18, 2016 Author Share Posted July 18, 2016 (edited) More of a random musing than an update.This is how I am thinking of doing the road section: The layout pattern is based on some war time photos I was looking at. All cobbles, but based on the photos, they are larger, more like heavy driveway paving slabs. Thoughts and/or suggestions? Edited July 18, 2016 by Crayons 2 Link to comment Share on other sites More sharing options...
James G Posted July 19, 2016 Share Posted July 19, 2016 Fantastic details! Looking forward to more. Link to comment Share on other sites More sharing options...
Crayons Posted July 22, 2016 Author Share Posted July 22, 2016 So, after a quiet night of beer and music this is where the base is: Going to drill the locating holes for the building, then start with some paint. 6 Link to comment Share on other sites More sharing options...
Tzulscha Posted July 22, 2016 Share Posted July 22, 2016 The street looks REALLY good. I am looking forward to seeing it in colour. In fact the base is so nice I've plumb forgotten what you plan on parking there.... Link to comment Share on other sites More sharing options...
modelman182 Posted July 24, 2016 Share Posted July 24, 2016 I know the stuff you are referring to. Fibre reinforced plasterboard commonly used for ceilings and interior walls in single leaf housing.. I have been contemplating using it instead of casting slabs of plaster. Would scale out producing a wall with a thickness of 350mm. Cut the slot for the drainage, ended up looking like father christmas (minus the belly) from the clouds of fine plaster dust. Photos to follow. Ha ha - I have an advantage over you when cutting plasterboard, cos I already GOT the belly! LOL! Seriously though, that stuff sure does produce a plethora of fine white dust when you're smoothing the cut edges. Gonna have to scrub the garden paving once I've finished, it looks like someone's smeared white paint all over it at the moment. Kev Link to comment Share on other sites More sharing options...
Crayons Posted July 31, 2016 Author Share Posted July 31, 2016 Base paint work blocked in: Still quite a few bits to highlight/pick out. I am not happy with the gutter paint work at this stage, it just seems bland. 9 Link to comment Share on other sites More sharing options...
modelman182 Posted July 31, 2016 Share Posted July 31, 2016 Very tasty! I am left wondering when was the last time I saw any gutters that looked anything other than bland, though? Can't see the need for much more work on that, looks great to me. Kev Link to comment Share on other sites More sharing options...
Crayons Posted August 2, 2016 Author Share Posted August 2, 2016 Drain cover painted in place. I decided to run a green wash over the gutter to replicate the appearance of algae. Foot path up next just waiting on paint to arrive. 12 Link to comment Share on other sites More sharing options...
Tzulscha Posted August 5, 2016 Share Posted August 5, 2016 Trash, drifted leaves, rubble. Lots of things to clog guttering.. um "add character" The colours look terrific. Link to comment Share on other sites More sharing options...
Wogga Posted August 6, 2016 Share Posted August 6, 2016 Just fell on to this, what super detail however what is the surface made of ..plaster? really stunning work. Link to comment Share on other sites More sharing options...
Crayons Posted August 6, 2016 Author Share Posted August 6, 2016 Just fell on to this, what super detail however what is the surface made of ..plaster? really stunning work. The road and pavement section I made from plaster and scribed to suit. The building, I cast slabs of plaster then scribed/cut to suit. Window fascia and wall trim I made from styrene then texted it. Link to comment Share on other sites More sharing options...
Crayons Posted August 17, 2016 Author Share Posted August 17, 2016 Not much progress, but, I have started the painting building and the base is almost complete: Link to comment Share on other sites More sharing options...
Crayons Posted August 21, 2016 Author Share Posted August 21, 2016 I was initially going to have mostly intact panes of glass in the windows, but I have decided against that option and instead will use just small fragments along the sides and edges. Still a lot to do on the walls with only the basic brick paint work finished. 5 Link to comment Share on other sites More sharing options...
Crayons Posted September 5, 2016 Author Share Posted September 5, 2016 Home again. Started work on two of the figures while I was away. Volkssturm (set number 3621) from Zvezda. The figures in the set are quite good overall with the exception of the heads, they are rubbish. Using replacements from the Hornet range. There is one more Volkssturm figure to go, but I am awaiting additional parts to arrive. Bit of tweaking to get them to hold the weapons properly, but got there in the end. 2 Link to comment Share on other sites More sharing options...
Crayons Posted October 8, 2016 Author Share Posted October 8, 2016 Finally got some time to work on this. A few modifications to the building, namely the upper section of brickwork was cut off after I realised that I had attached the building pieces in the wrong order thus making the roof near impossible to build. Started work on the inside of the building. I had originally intended to use the decorative styrene wall trim I had made, but after several unsuccessful attempts to paint a half way decent wood finish/pattern, I gave up on the idea and binned them. Roof framing started and currently deciding whether to use pantiles or something like slate tiles. Â Â 4 Link to comment Share on other sites More sharing options...
Rob 1 Posted October 12, 2016 Share Posted October 12, 2016 Wow, this is amazing work, both the scope and quality. Very inspiring! Link to comment Share on other sites More sharing options...
Mancunian airman Posted October 19, 2016 Share Posted October 19, 2016 Its been an eye-opener into working with plaster, absolutely loving the roadway and particular liking the gutter shallow in the road edge.  All power to you and the building look s good too but not quite sure about the exposed brick and the plaster ? Is the plaster where temp repairs have been made as I would have thought it would be brick-work all over the building ?/  I shall be watching with interest . . . Ian Link to comment Share on other sites More sharing options...
Timmas Posted August 25, 2017 Share Posted August 25, 2017 As a new BM member I've only just come across this. It is absolutely stunning. Have you finished it? If so, I would love to see the completed piece, or even more WIP images. Link to comment Share on other sites More sharing options...
