Bracing wires for RAF/FAA biplanes
Papertiger59
Hi Gentlemen,
My question is about bracing wires for interwar RAF/FAA biplanes. Were they "round" or "flat", by "flat" I mean "Raf-wires" ?
This question deals with the kits I have in my stash.
Hawker Woodcock
Hawker Hart Family
Hawker Fury/Nimrod
Fairey Flycatcher
Fairey Fawn
Fairey Swordfish
Fairey Seafox
Fairey Campania
AW Siskin
DH-9a
Gloster Grebe
Gloster Gamecock
Gloster Gauntlet
Gloster Gladiator
Avro 504
Avro Bison
Sopwith Snipe
HP Heyford
Vickers Vimy
Vickers Vildebeest
Westland Wapiti
Supermarine Seagull
Supermarine Southampton
Supermarine Walrus
Supermarine Stanraer
Blackburn Shark
Blackburn Baffin/Ripon
Thanks,
Chris.
Edited by Papertiger59
  • 9 months later...
I'll thow a cat among the pigeons here. I made 'RAFwires' out of stretched sprue with its flat sides for 1/72 scale - completely accidently!!!
I was stretching the sprue over a candle flame as usual (back in the day) , but I used a piece that had a short 'branch' on it a right angles, expecting it to just pull out to a round cross section. It didn't. It retained a flat cross section, much to my surprise. I made some more (enough to rig a then-new Airfix Pup). It was a complete pain to do (keeping the wire in the correct line of flight was agony!), and I used up the sprue from three kits just to get enough of consistent quality for use.
I hate to say it, but the final result was excellent, the appearance of the different apparent 'thicknesses' depending on the angle of view was absolutely spot on.
The model was crashed and trashed many years ago, unfortunately.
Would I do it again? Almost certainly not!
a suggestion made on Hyperscale, IIRC, was Kanthal Ribbon Resistance Flat Coil wire, it  gave a link to ebay  US,  I found some on ebay UK
http://www.ebay.co.uk/itm/232017299575
the poster suggested the 0.3 X 0.1mm gauge for 1/48th,   full size the  would be a width of 14.4 mm, (0.3 x 48)  I'm not sure how wide/thick streamlined bracing wire is, but perhaps someone who  knows maybe able to add futher info.
HTH
T
On the subject of flat line rigging wires I came across an unusual if not serendipitous situation with e-zee line. I am now on my second reel of fine black line but did notice whilst using the line that sections of the line were flat and definitely not round.  This line was not good for the WWI German aircraft that I was using for at the time. I presume it was a fault with part of the reel I had as it was only a small part of the reel that was like this.  Has any one else noticed this?
Andrew.
Edited by Bear Paw
I thought everyone knew this! Yes, if you file a length of sprue to a given cross-section, and then stretch it, it will retain most of its cross-section when you stretch it (only smaller, obvs) .
So for a small scale rendition of RAFwires try stetching some Slaters strip.
Every manufacturer of Blackpool rock could certainly testify to its efficacy.
