AndyC Posted June 11, 2016 Posted June 11, 2016 Never done these before - my SA-6 for the GB has them and so do several kits recently bought. I've only ever used vinyl tracks before.. Any good hints as to how to put these on the model? Paint first? Glue in-situ for all, or just the last links? Thanks in advance chaps
Shar2 Posted June 11, 2016 Posted June 11, 2016 I'd paint them first, loosely fit the lengths, then build up the links around the sprockets and idlers adjusting the lengths as required. 2
SaintsPhil Posted June 11, 2016 Posted June 11, 2016 (edited) Having just mucked up the first set I tried here's a couple of lesson learnt, I built mine up in small subsections, the individual bits at least, then painted and weathered off the model. Great idea in theory, except I mixed the parts up while painting and ended up with some mind boggling 3D jigsaw puzzle so make sure you clearly label at least which side they are for!! Looking back I probably could have made each set in one top and one bottom run, they do conform a bit after painting to allow you to fit them. Phil Edited June 11, 2016 by SaintsPhil 1
Foghorn Leghorn Posted June 11, 2016 Posted June 11, 2016 Can I also suggest a stiff libation within reach (but not close enough to knock it over)? Never done any link tracks myself either but now I've got a Chieftain with them, and not only links but also separate trackpads, I'm not looking forward to it. Oh shugar ... I've just remembered, I've got Dragon Maultier with the damn things as well ... 2
AndyC Posted June 11, 2016 Author Posted June 11, 2016 Don't even mention individual track links! Step too far right now 2
Shar2 Posted June 11, 2016 Posted June 11, 2016 It does depend on the manufacturer. I'm not keen on the indy links that you gave to glue together, you might as have link and length. But the ones with separate pins or click together aren't bad, once you get in the right frame of mind. The best indy link tracks i've found in a kit are in the later Takom WW1 tanks and the Meng Mk.V's. If in doubt i'd plump for Friulmodel metal links. 1
Panzer Vor!!! Posted June 11, 2016 Posted June 11, 2016 SIMPLES Sit down tray on knee glass of amber watch tv click the tracks together Thats the way to do it!!!!! 1
AndyC Posted June 11, 2016 Author Posted June 11, 2016 Some of the recent HB kits have indy links - I need to try and work out which types they are before tackling them. FRiul look good but that's another 20 bucks on the top of a kit
Shar2 Posted June 11, 2016 Posted June 11, 2016 It is an extra expense, but they produce a nice natural sag where required, and give the model some weight to keep in on the shelf. 1
Antoine Posted June 11, 2016 Posted June 11, 2016 (edited) Maybe a few pics will help. First, prepare the wheels/sprockets and put them on your tank (No need to glue them yet if they stay in place). Then assemble about half a track on some tape. When its done, glue them with tamiya green in very small quantity. Then wait a bit for the glue to act, You need to have a track solid enough so that no links fall appart, but a track that you can still bend. When you think its ok, put the track in place, give it some sagging according to what you can observe on pics. In one word, make it live. You can add some weight on the hull so that it'll help the track keep the shape you gave it while the glue dry. Then prepare the second half, and by the time you'll be able to fit it to the tank, the other half will be ready Then let the whole thing dry for about 24h00, before removing it. Remove also the tape, then its ready to paint. You might need some touch up when you'll assemble the two halfs. Also, if those two half are difficult to put in place, you can decide to cut a third part of just a few links, to make things more easy. Then again, it's up to you, fit the tracks latter and paint the hull, or put them in place once the wheels are painted, and mask. Edited June 11, 2016 by Antoine 4
simon64 Posted August 23, 2016 Posted August 23, 2016 I've been reduced to a quivering mess with link and length so i use fruilmodel now. 1
