Good morning!
I picked up this kit from Bruntingthorpe on Sunday along with a 1:48 Airfix Lightning.
I will be quite honest- this kit is a mixed blessing:
Pros:
-Great surface detail
-Resin exhaust cans and seats
-An Eduard photoetch fret included (this contains the instrument panel, belts and various aerials
-A large decal sheet (which was barely used, decals sourced from the spares box for my alternative scheme)
-Relatively straightforward to build and paint
-Positionable flaps
Cons:
-Almost nothing in the way of guides to tell you where you should place the various parts (cockpit tub, intake cone and nose gear bay)
-Nothing in the way of guide pins for the rudder and elevators
-Main wheels with no hole through them (a hole had to be drilled to fit the axle through)
-A myriad of ejection pins inside the fuselage, specifically of concern were those in the intake area
-Wing-fuselage locating pins did not fit at all and these were subsequently filed down
-No option to have open airbrakes!!!
What I've done:
Well, with a bit of fiddling around I apparently managed to get the intake cone, etc and the cockpit to line up correctly in the fuselage- once that was done I closed it up, added the various surfaces and painted her in Alclad. It's my first time with Alclad! I put down a coat of black Vallejo paint followed by a coat of Alclad gloss coat. I then sprayed on the Alclad, building it up to what it currently is. I didn't need to re-paint the black rudder because that was masked over before I sprayed the Alclad. I then masked and painted the yellow stripes on the wings and rear fuselage, added the IFR probe, small intakes and attached the PE aerials.
Kit: Sword Lightning t5 1:72
Paints used: Vallejo model air: black, gold yellow. Alclad II Aluminium
Note: Decals used and colour schemes are based off reference pictures but are to some extent fictional
Thanks for having a look!
Many thanks,
Sam
Edited by cathasatail
Hi Sam,
calling this kit a mixed bag is an understatement! But you achieved a fine model, despite all the stumbling blocks.
I know for sure that this is not a kit for me...
Well done!
JR
Hello,Sam - My compliments to you on a well built and painted model of your 'Lightning'.I think the cockpit detail looks splendid,including the ejector seats.I commend the Alclad finish too.Good for you! ;) I think 11sqn and 92sqn would be doing 'battle royal' as to who looks after this beauty.:) All the best,Paul.
