krazyivan1942 Posted May 28, 2016 Share Posted May 28, 2016 (edited) Currently building the Airfix 1/72 Mustang IV in 3 Sqn RAAF marking, but I need to paint the fuselage band. What would be the best way of doing the band. http://www.3squadron.org.au/subpages/Mustangs/D%20CV-P%20KH677.bmp Edited May 28, 2016 by krazyivan1942 Link to comment Share on other sites More sharing options...
Darby Posted May 28, 2016 Share Posted May 28, 2016 My method would be paint the band colour and then using thin strips of Tamiya tape mask the width of the band at both edges. Thin strips with be easier to conform to the surface shape. Once that has been done then in fill with more masking tape. I haven't used the Tamiya tape for Curves yet so can't comment on that. Other methods of painting and masking are available though. 2 Link to comment Share on other sites More sharing options...
Rick Brown Posted May 28, 2016 Share Posted May 28, 2016 What Darby said. Rick. Link to comment Share on other sites More sharing options...
bentwaters81tfw Posted May 28, 2016 Share Posted May 28, 2016 Seal the edges of the tape with Klear or similar clear acrylic, to prevent paint bleed. 1 Link to comment Share on other sites More sharing options...
RJP Posted May 28, 2016 Share Posted May 28, 2016 (edited) Yes, paint the band area first and make sure to seal the tape as described above. One tweak, though. The sealer might bleed but if you seal with the band colour you won't be able to see it. You might find paint ridges after removing the tape but they are easily dealt with - very fine sandpaper applied gently after the paint has cured (not just touch dry). Edited May 28, 2016 by RJP Link to comment Share on other sites More sharing options...
krazyivan1942 Posted May 28, 2016 Author Share Posted May 28, 2016 (edited) Thanks guys, was thinking to do it as described, my concern was how to get around the surface shape and over the fin fillet to get a nice straight lines. I'll cut some Tamiya tape into thin strips and then seal it with the band colour to prevent bleeding. Edited May 28, 2016 by krazyivan1942 Link to comment Share on other sites More sharing options...
Selwyn Posted May 29, 2016 Share Posted May 29, 2016 Seal the edges of the tape with Klear or similar clear acrylic, to prevent paint bleed. I seal using the band colour paint. Selwyn Link to comment Share on other sites More sharing options...
Giorgio N Posted May 31, 2016 Share Posted May 31, 2016 If there's too many curves for the standard Tamiya tape, try electric insulation tape, again cut in narrow strips. This is very flexible and can be adapted to some very tight curves, should work well on a 1/72 Mustang fuselage. Before using this tape, remove some of the adhesive, it's not meant for masking so there's the risk of peeling away some paint if too much adhesive is left on the tape. Tamiya of course now has a flexible tape but I've yet to try it on a model 1 Link to comment Share on other sites More sharing options...
Marcel Posted June 1, 2016 Share Posted June 1, 2016 Not the best photo I have - the Sky band on my Tiffie has been sprayed and then masked using the Tamiya flexible tape - it was OK even between the reinforcement plates. I am really happy with the tape. Link to comment Share on other sites More sharing options...
PhantomBigStu Posted June 1, 2016 Share Posted June 1, 2016 As Giorgio N said, gave me that advice back in jan and I've not look back, takes practice and care but very doable Link to comment Share on other sites More sharing options...
woody37 Posted June 1, 2016 Share Posted June 1, 2016 I got some of the Tamiya flexible masking tape recently and used it on the Canberra that's in the WIP section. Highly recommend it for those difficult contours such as around the fin. Link to comment Share on other sites More sharing options...
mossieramm Posted June 14, 2016 Share Posted June 14, 2016 Sorry for the thread hike, but I'm doing the same thing for my 1/72 P-51C and was wondering how wide should the fuselage band be ?? David. Link to comment Share on other sites More sharing options...
johnd Posted June 14, 2016 Share Posted June 14, 2016 18", so 6.3mm in 1/72. John. Link to comment Share on other sites More sharing options...
PhantomBigStu Posted June 14, 2016 Share Posted June 14, 2016 Or more accuratly as its not quite 6.3mm but inches it is exactly a 0.25 inches Link to comment Share on other sites More sharing options...
mossieramm Posted June 14, 2016 Share Posted June 14, 2016 Thanks guys Link to comment Share on other sites More sharing options...
stevehnz Posted June 14, 2016 Share Posted June 14, 2016 Very close to 6mm Tamiya masking tape, close enough for me anyway. Steve 1 Link to comment Share on other sites More sharing options...
Beard Posted June 16, 2016 Share Posted June 16, 2016 Very close to 6mm Tamiya masking tape, close enough for me anyway. Steve Me too. 1 Link to comment Share on other sites More sharing options...
jckspratt1 Posted June 16, 2016 Share Posted June 16, 2016 Mate, if you aren't happy using thin strips of Tamiya tape, their tape for curves does really good work if applied carefully (all the caveats about sealing still apply!). 1 Link to comment Share on other sites More sharing options...
