Hello everyone.
This is my first WiP posting, and I'm using it as a means to encourage me to get the job done! All the raw materials are ready:
Rummaging in the loft, I found the instruction sheet from my last attempt, when it was first released back in the sixties. Saw it in the window of the model shop which was conveniently next to my primary school. Had to have it - those markings did it for me. Am I weird or does anyone else keep all their instruction sheets?!
My next posting could take a while!
Haris
:popcorn: and :drink: ready!
Christian, exiled to the armpit of the globe
Haris
But of course, most of them anyway. I'm ashamed to say that though I still have the header card & decals for the Airfix Demon, I butchered it years decades ago, to use in a Nimrod conversion, still on the go. :D
Steve.
It's a cool (and fierce) looking thing, I look forward to seeing it take shape.
Will
Nice choice for a vintage kit. And in answer to your query re instructions I have virtually ( NOT ALL!) everyone I built still. Any duplicates from building more than one which I discard or keep separate to pass on to anyone that wants it.
Most definitely up for watching this one develop. Good luck with this WIP Haris!
Tony
Excellent choice - I love the Hart family! Regarding the instruction sheets, yes I keep all of them*, and each time I finish a model, the sheet gets added to the stack, which I keep together. Best of luck with the build!
Regards,
Jason
*Mind you, this does not preclude your being weird, this is just evidence that you have company.
Edited by Learstang
Good luck with this, mine's stalled after a real life flying event broke the wing supports and wheel axle. That said I'd reccomend replacing said axle with a length of plastic rod anyway. The one provided has too small a diameter leaving the wheels loose and a fight to line them up properly.
Thanks for the advice, and everyone for their support. Project now underway and I have a lap full of Airfix Demon dust after removing most of the surface detail off the wings. I will post pictures in the next few days.
Haris
Hello everyone.
Making some progress with the build at last. First, some of the immediate problems - corrugated wings and sink marks.
Tail fin a bit pointed and will need rounding off.
Some very odd malnourished wheels.
Holes need to be plugged.
Sink marks filled and ribs rubbed down. Ailerons carefully removed with a sharp blade, hand grips drilled.
Reworked parts so far. Details to the upper wing added with self-adhesive aluminium plumbers tape, Some re-scribing, and hinges to moving areas added after separation. Wheels came from the Aeroclub Hart/Audax kit which I didn't even realise I had, found on another trip to the loft! They've been drilled and detailed.
After a coat of Tamiya Grey primer, the wing looks fine, apart from a bit of touching up here and there.
Now the inside. Will post more soon.
Haris
  • Like 10
Hello again.
Some progress made with the interior. I've had to remove quite a bit of plastic to had a bit of interior detailing. I didn't want to go over the top with this but to add enough to make it look busy. Most parts have been fashioned form bits of plastic and a few from the spares box, particularly the photoetch. Only thing I think I need to add now are the seat belts.
Before painting.......
.........and after
I also made a start on the exterior by cutting a hole for the radiator from the Aeroclub set.
The detail on the radiator isn't great so I pasted a layer of green putty onto both ends, pressing the wet putty onto some cloth for a bit of textured detail. This will be cleaned up and added to later.
Also the gunners position has been reshaped by removing the section behind the pilots seat.
Hoping to get the two halves together today so that I can make a serious attempt to sort out the exterior.
Haris
Great stuff Haris. That putty/ cloth imprinting process looks simple and very effective.
Tony
Just found this and I must say your improvements are definitely bringing this old relic up to scratch! I do hope Airfix retool their old biplanes soon, they do some great subjects!
Ian
