Basilisk
1/48 ModelSvit VVS Yakovlev Yak-1B white 6 from GC 3 Normandie-Niemen
My second build is of the VVS Yakovlev Yak-1B white 6 from the GC 3 Normandie-Niemen apparently flown by Albert Durand from Mosalsk during April 1943.
The question is if the Yak-1 on the above two pictures is of the same aircraft as there are other profiles of this aircraft showing it as white 11. Unfortunately most if not all pictures of Normandie-Niemen Yak-1 with sharkmouth don't show the fuselage numbers. A great site for information on the Yak-1 is this Russian site.
Originally I wanted to build the recently released Eduard Yak-1 kit which contains the Accurate Miniature plastic. There are many favorable reviews of this kit. But when you check reviews on Russian forums (google translate is such a great tool) things don't look so good anymore as the Accurate Miniature Yak-1 has apparently some shape issues difficult to correct.
So I ordered a ModelSvit kit of the Yak-1 which is seen as more accurate together with - yes you guessed it - some resin goodies :thumbsup: .
I hope I get the kit in a week or two, so I can't get started immediately on this build. But I am sure I have enough to do with the P-40K and the other GBs I didn't finish.
Cheers, Peter
Edited by Basilisk
good choice Peter. I love the scheme you want to do.
Thanks Arnold. The scheme is a bit different and it will be a challenge to get the nose looking as on the picture.
The good news is that the kit with some additional goodies arrived from the Ukraine today :thumbsup:
So I am set to get started.
In addition to the kit, I will use following extra parts:
- Armory PE set
- Armory Resin Wheels
- Quickboost exhaust
- DMM decals
It is a shortrun kit, but very well made.
And no rivets to add for me :weep:
Still, It will not fall together and needs a bit of work. But there is lots of detail included.
The Armory PE set looks very nice too.
The resin wheels and exhaust will complement the PE nicely.
Nice stuff.
Cheers, Peter
I hope I won't disappoint. The kit does have all the hallmarks of a shortrun kit, so the parts need a lot of preparation and fitting them can be a bit of a challenge.
But after the clean up is done, the fit so far is surprisingly good.
Cheers, Peter
This will be a slow build as all the parts need to be extensively cleaned up. But surprisingly the fit is very good after the clean-up.
And it is amazing how well the small parts are defined. And with the addition of some PE, it will look great.
I also learned that PE parts can be worse than the plastic part they replace.
Armory PE compared to the kit part.
And on the original.
I have to say, I enjoy building this kit a lot.
Cheers, Peter
Edited by Basilisk
When I see how fast some build their models, I start to get a bit concerned about my snail speed. But I did manage to add some more bits to the Yak.
The wing trailing edges are rather thick, so the obligatory thinning was in order.
The next step was to add the oil radiator intake mesh. Actually I didn't replace the mesh as it was again too coarse, but I added the PE showing the solder joints.
Had to make a groove in front of the mesh as the PE part was a bit too large.
Then it was time to add some wires after the Armory PE part side consoles had been fitted.
And in place.
The other side looks a bit more busy.
Still have to tidy up and add some additional small parts before I can start with painting.
Cheers, Peter
No need to worry about speed when you have that level of quality. I'm throwing together a lot of easy build kits because the one I intended to do has about 2 million parts and some PE that doesn't have IM equivalents - it is beyond my skill level and I simply can't do what you are.
Definitely don't worry about speed...my build is oob so will move a lot faster than yours, you will be spending a lot of time on detailed PE and other addons which some of us aren't - plus the quality of this build is looking stunning :)
Looking great so far Peter, with lots of nice added detail :) .
Cliff
Thank you all for the kind comments.
I got a bit further, by adding some missing parts.
I also created some depth on the flat PE parts with white glue on the wheels and knobs, followed by Mr. Surfacer resin primer as a first coat as it sticks well to metal parts too.
I am always surprised how the look is improving having all the various parts in the same colour.
And the remaining parts making up the cockpit.
I noticed some spots to clean up. After that I can prime it all black and commence the painting :thumbsup:
Cheers, Peter
Edited by Basilisk
Thanks Sgt. I think it even looks better with a bit of colour :winkgrin:
But the work on the IP didn't go as planed.
The white paint I painted the back of the clear film with came loose when I glued the film to the PE part, staying on the post it note piece :banghead:
To get the rest of the cockpit together, I need the wings assembled, but I wanted to add a bit of detail in the wheel wells first.
This part can then go onto the wing.
I do have some issues with the seat and the harness. Armory has a harness for the Yak-1 which I think is wrong. Apparently the Yak-1 had a Sutton style harness which can be seen in the picture below.
The harness Armory provides I have only seen in older Soviet aircraft like the Rata.
In addition, I have seen several builds where a slot was added to the seat backrest for the harness to go through. The Modelsvit seat back doesn't have the slot and I wonder if it the harness goes through a slot or over the top of the seat back. Unfortunately I can't find any pictures showing this.
Any help with this is much appreciated.
Cheers, Peter
Thanks Sgt. Finally the cockpit is done - well 99% done. Spent a bit of time re-modelling and adding extra detail. Attaching the seat was a bit a challenge too.
And now all is in place and weathered. I redone some of the wiring and added the pipes from the radiator to the engine
This pipe seems to be the "hot" pipe and was insulated.
And here together.
I attached the seat pan lower as it was way too high in the kit. I also ended up adding a slot for the harness as I found some drawings having it. But I am still not sure if it is correct that way.
As soon as the Eduard harness arrives I can close her up.
Cheers, Peter
Edited by Basilisk
Cockpit is finally done - but it was a bit of a journey to get there.
The fuselage came together with a bit persuasion.
I fitted a new Eduard Russian steel harness which has harnesses for LaGGs and Yaks. But something just didn't look right :weep:
Well it seems Eduard is not only having scale issues when making kits, but also with PE parts :fuyou_2:
Left Eduard, right GoNzA - what did I say about scale, about 1/3rd too small so close to 1/72. And yes, I checked if they sent me the wrong scale PE, but it is the 1/48 set.
here the comparison on the seat.
What a difference. Sorry I had already removed the back harness before I took the picture. Now the GoNzA harness is maybe a tad over scale. But as the ModelSvit seat is a bit too large, they work well together.
I used Gunze Mr. Metal Primer for the first time (applied by brush) on the GoNzA harness and I am impressed - no paint pealed off when handling, folding and attaching the harness - a rather tricky venture in the closed cockpit.
Finally the Fuselage and wing with the cockpit floor was ready to go together :thumbsup:
As with the fuselage assembly, this needed a bit of pressure to make it fit.
And here the finished cockpit.
I am glad I added the coolant pipes as they can be seen rather well.
I will fit the gunsight with mounting bar later in the build when attaching all the other small parts.
Cheers, Peter
Edited by Basilisk
Looks really good Peter, this answers a lot of questions I have about the Yak-1 'pit
That cockpit is seriously impressive Peter, great job.
All the best Chris
Thanks everyone for the comments.
Glad that this build is of some help, but The cockpit does represent a late model Yak-1b (only information I could find) and I think there are differences on a early Yak-1b as the Soviets implemented changes all the time.
Unfortunately the feedback to my questions from the expert was a bit lacking here. But fortunately my thread at Sovietwarplanes.com did answer many of the question with some interesting discussions, which unfortunately never materialized here.
I just received the Kagero Yak-1 book today.
110974-15526-59.jpg?nr=5&company=kagero&
Flicking through the 190 plus pages, only one word comes to mind WOW. Lots of pictures I haven't seen before and many detail drawings. But no scale drawings in this volume at all (maybe they are reserved for Volume 2), which I don't mind as I have some good drawings already and I found the detail information in this volume much more valuable.
Cheers, Peter
Edited by Basilisk
Hi Peter, here are some photos that I used when building the Montex Yak 1b, the cockpit photos do show the harness going through the seat back.
http://sovietwarplanes.com/board/index.php?topic=1988.0
http://karopka.ru/forum/forum212/topic457/
Dennis
