Brundledonk
Airfix Daleks in Manhattan
It's shaping up nicely. Good work.
Thanks Rob
Slow but steady this build
Pete
Looking good there.
Thanks buddy
Pete
Great paint Pete, its looking very nice
Cheers Hunter,
I'm pleased with how it's turning out so far
Pete
looks great so far. :goodjob:
Cheers Tim
Pete
Found some time to work on Dalek Sec's innards today
The screen grabs that I have show the inside to be a sort of dark metalic grey but seeing as how Sec will be mostly black I used artistic licence and went with gold for more contrast
20160630_133559_zps5qpm9m7o.jpgw
I will go back in and brush paint the details
I used Alclad pale gold as a base, steel for shading and pale gold mixed with aluminium for the highlight
Edited by Brundledonk
I exaggerated the contrast as its going to be dark inside once Squidward goes in and I want it to show up
Everything is just tentatively dry fitted here just to get an idea of how it's going to look
And from the back
There's going to be filing needed on the panel joins methinks
Not too much more to do inside, just pick out the details of the wiring but outside I've still go to mask the head and prime and also there are a ton of hemispheres that need priming / painting and I'm really not looking forward to that bit.
But I'll get there in the end I'm sure
Pete
The Daleks and the base look awesome.
I wish now I had snabbed this kit when I had the chance.
Bugger.
The guy in the respirator looks a little unfinished though, maybe a bit more shading...
:coolio:
seem to be struggling with the old mojo I'm afraid but I did a little bit more to the Dalek this morning
I painted the moulded wires that are on the inside of the Dalek Matt black but it looked a little flat so I went over a little bit with dark grey and then again with light grey ( leaving the underlying colours showing through a bit ) to try and give it some definition and add some depth
They looked good in black as the contrast against the gold was very strong but the detail was lost.
The grey has helped the details show but I've lost the contrast
Got the head masked and primed and everyhting up to the head is now glued . The open panels are a friction fit so I will easily be able remove them for painting the outsides
There are gaps where the skirt meets the base and between the panels but I'll fix those when my mojo is up
I airbrushed the end of the eye stalk blue then airbrushed a dot of white and masked with a blob of blue tac before painting everyhting black
I scratchbuilt the gun from aluminium tube and beading wire but this one is just a place holder as it was just to test the concept and I will make 2 slightly more refined ones when I buld the second Dalek as I think this one is a bit bulky
The kit one is moulded in one piece and is very innacurate
The kit part for the arm of the manipulator is bit clunky too
So seeing as I had the Ali tube out I made a new one
Pete
I neednt have done much to the interior painting as once Squidward is in place you can't see much of it
Before I glued them I. I sprayed german grey around the sockets where the hemispheres go on the lower skirt to help them stand out a bit
The top half should be gloss black to match the hemispheres but I didn't think it would look right in scale so I went with satin and just dry brushed a little bit in dark grey to bring out the detail but with hindsight I think the gloss would have worked
He does talk and light up ( I'll do a video tomorrow if I get a chance )
EXTERMINATE ! ( unbelievably neither Dalek actually say this )
Managed to chip some paint off one of the tenticles as the vinyl is crap at holding paint
And with him on the diorama
So one Dalek down and one to go !
It will be a little while before I get back to the Other one though as I have to jump into the TARDIS and go back to 1916 and finish of a DH-2
Pete
This is looking really good. :goodjob:
Might inspire me to dig from the shelf of doom my almost finished copy. I both got both Darlek's built although I did close Sec up though... those panels do fit into a closed skirt with a bit of work. I also got some colours on the base although that wasn't finished either.
I did stall when I attempted to scratch build new gun arms from sprue and staples... never got anything I was happy with and shelved the kit.
Bugger.
:coolio:
Thanks mate
Its worth keeping an eye out for one as it really is a nice kit and a lot of fun to paint.
Yes the face has a few seams that could do with a bit of filler too lol
Pete
Dig it out and finish It as it makes a great display piece with the daleks on the base.
Closing Sec up must have been a fair bit of work I imagine. Did you have to do a load of filling ?
I tried to use a stiffer wire for the guns but had trouble bending it so went with beading wire and although nice and easy to cut and bend it was very dificult not to bend it out of shape when glueing, I'll try and find something that's a bit more robust when I do the next ones
Pete
Very convincing work on dalek sec.
Cheers bud
Pete
Brilliant Pete. I'mnot really a fan of Who but that's some grade A mogglin' right there.
Thanks mate,
I'm not much of a fan of the current series but I did enjoy the comeback and earlier ones
Pete
I have finally completed the DH-2 and will crack on again with Dalek Caan.
Hope to get some bench time today, but tomorrow I'm off to the Inlaws with the wife and kids for a week so things will grind to a halt again
Pete
