steve4428 23 Posted April 17, 2016 Share Posted April 17, 2016 Anyone tell me why I am still getting a milky powdery look on my Canberra PR9 after using this varnish??? I gave it a good shake, and painted it in light coats, however, when it dried, it did have a Matt finish, but with white streaks, which would not wash off with warm water! Any suggestions/help gratefully appreciated. Regards Steve Link to post Share on other sites
emlra 8 Posted April 17, 2016 Share Posted April 17, 2016 The white streaks are probably the matting agent, needs a lot more stirring......shaking just wont 'cut it', what to do about it now......not sure..that's another problem! Link to post Share on other sites
Jamie @ Sovereign Hobbies 12,850 Posted April 18, 2016 Share Posted April 18, 2016 I'd recommend investing £8~15 on an electric paint stirrer. A few seconds will see anything properly stirred and thus avoid this sort of problem across the board of whatever you use. Otherwise, I've found Humbrol Matt Clear to be pretty good stuff - although admittedly I'm spraying it, and then after the above electric stirring treatment. Link to post Share on other sites
dubster72 212 Posted April 18, 2016 Share Posted April 18, 2016 Or make your own from a nasal hair trimmer courtesy of your local Poundshop 6 years on, it's still going strong! 1 Link to post Share on other sites
PenquinTony 8 Posted April 18, 2016 Share Posted April 18, 2016 A spray of clear gloss will make the white go away.if done carefully you might even end up with the look you wanted otherwise its back to square one and a fine mist of matt again. Tony Link to post Share on other sites
steve4428 23 Posted April 20, 2016 Author Share Posted April 20, 2016 Thank you for all your comments and suggestions guys! Regards Steve Link to post Share on other sites
