Airfix 1:24th Scale Mozzie
Hi,
here are some images of my 1:24th scale Mosquito. I started it last year, or perhaps even the year before that. I got it out again last Weekend ans since then progress has been good. I try to be careful with wash and weathering to avoid overdoing it. The scratch on the seat cushion will one day be covered with Eduard seat-belts.
Hope you like the pics.
Regards
Peter
Thanks for your comments and likes! :)
As I'm from Germany we get WWII historical sites and Crash sites by the dozens here. Many years ago a friend of mine and retired schoolteacher did what he called Aviation Archaeology, he dug up remains of crashed WWII aircraft. I assisted him on his trips several times. I recall we went to a site near Dortmund what was said to be a MKII 51 Sqdn Halifax bomber, one with a Tollerton nose fairing. I remember the surprising large amount wood-splinters we found at the site (amongst many other things) and I asked my friend if he's sure we hadn't found a Mosquito instead. He was obviously disturbed by my remark and from his reaction I could tell he wasn't certain that the wreckage we had found was indeed a Halifax. Anyway the site became known as the "Hurler Busch Halifax". The Hurler Busch is a small Wood near Dortmund. While we still at the site I found a very remarkable piece: It was a black disc about the size of the palm of a man's hand, maybe slightly larger. It was about2-3 inches thick, was from cast material, painted black with a White "Crown Property" (or something to that effect) stamp on it with a White crown in the center. The inside was hollow and there was a sprocket inside which was abviously some sort of fairlead of a bicycle chain. One side was open, something must have been attached to the open side once. To me there was no doubt it was part of the control column, though it was obviously too small to be from a Halifax. I'm certain the part we had found was this:
Perhaps it was a Mosquito we had found after all? I no longer have this piece as all items went into the collection of the schoolteacher, who has now long since passed away. Perhaps someone here can post a picture of a real Mosquito column for me to see if I'm right.
Like I said in my post above I'm planning to use Eduard seat belts for my model. On the Airfix pilot's seat the opening in the backrest for the seat belt is not central, it is slightly offset to stbd.
I think on Tamiya's 1:32nd scale Mosquito this opening is indeed central. I don't know how the ends of the seat belt were fastened to the back of the seat. I don't wasnt to simply stick them on there, maybe someone here can shed some light on this.
Thanks!
Peter
Edited by olympic1911
First seatbelts are in place. Those Eduard seatbelts are quite a challenge! I found it far easier to thread the belts into the buckles BEFORE the buckles were cut from the fret. This made them far less prone to loss. Now for the bottom halfs!
Peter
Today I added details to the instrument panel. Though I have the Airscale instrument panel decal I decided to use the Airfix offering after all. Alle instruments received a blob of Model Master Glosscote.
Peter
Work on the Cockpit is progressing well. I'm trying not to over-do the weathering as this can ruin a model
The clear safety-cap was glued with PVA to avoid messy stains
I might be able to glue the fuselage halfs together this weekend.
Regards
Peter
Your model looks superb Peter - and fascinating info regarding the archaeology. Any further news on the identity of the find?
Kirk
Wohoo! Kate Bush Album cover as an Avatar! Your my best pal already! :winkgrin:
I did some further research into the object we found back then but as it was about 20 years ago some details surely aren't present anymore others may be incorrect. However, now I'm certain that it was stamped A M (Air Ministry - obviously!) with a white crown underneath and not Crown Property as stated above.
My best bet it was from a Halifax after all and it was this here:
It is an auto-pilot speed steering lever so it would make perfect sense that there was a sprocket inside.
The finds that this retired schoolteacher made back then were truly amazing. He dug up several B17 Bombers finding crew-members' belongings such as navigational instruments, rulers even parts of a wrist watch. On a Lancaster site we found several one penny coins which were most likely good luck charms. We also found parts of a browning .303 machine-gun at a Lancaster site near Iysselsteyn in Holland. This aircraft had the codes "JO-Z" I don't recall the serial-number anymore.
Anyway - back to the Mosquito
The Radiators will receive a layer of Humbrol silver later on today and once this has fully dried it'll get some wash to bring out the mesh.
I have masked parts of the wings for here too the radiator area will be painted in silver. I'm planning to build an all-silver RAAF version of the Mosquito. By the way: All paintwork has been aibrushed and none of it has been painted with a brush (yet), apart from minor details and the washes of course.
A few bits and pieces are being prepared for a coat of surfacer, filling if necessary and final painting
I found it easier to attach the rear bulkhead to the wing-spar rather then to the fuselage as advised in the instruction booklet. This would ensure that there are no gaps between the pieces after the wings have been joined to the fuselage. I have to say though that the general fit of parts in this kit is superb!
More soon!
Peter
  • 1 year later...
Well, I've got her off the shelf again, after more than a year. One thing I noticed is the top surface of the flaps don't fit properly. You can see the top surface of the nacelle protruding over the flap surface.
J4100017a.jpgBilder hochladen
I have seen a number of build-logs on the Airfix Mosquito but this issue seems to have never been mentioned.
You can see here I have used the edge of the nacelle as a template to draw its outline onto the flap with a pencil.
J4100018a.jpgBilder hochladen
What would be best? Surely to trim the nacelle would be the simpler Approach, but somehow I believe that to cut this area away from the flap will be the more difficult but better solution.
Regards
Peter
typo
