Graham T Posted April 11, 2016 Share Posted April 11, 2016 Two recently completed. First up the 1/32 Hasegawa Fw190-D9. Really nice kit that, despite being pretty simple & with comparatively few parts, builds up into quite an impressive model. No real issues ecxept the undernose wing to fuselage joint where I ended up with a nasty step that required careful filling & sanding. Probably my fault although I couln't see where I went wrong. OOB apart from HGW seat belts from the Luftwaffe late war fighters set. The instructions it provides are "generic" & give no real clues as to how they attach to the airframe so I suspect I have those shoulder belts wrong but I can live with it. Kit markings are for two JV44 "Parrot Flight" machines plus one other. I went for the other! Next the Airfix 1/72 Lancaster II. A bit of a departure scalewise for me, I can't recal the last 1/72 build I tackled but I enjoyed this & have other WW2 "heavies" in the stash! I added the Eduard self adhesive interior set, along with some elements of the exterior set for the wheel bays mostly. I also used the Eduard canopy masks as I didn't fancy trying to apply my own usual Tamiya tape to the canopies & turrets. All the fuselage window glazing is Kristal Klear rather then the transprent parts in the kit. Sadly quite a bit of "crud" gathered in the front turret which wasn't visible until the masks were removed - too late to do anything about that now. The only real issue was the bomb aimers blister which was too large for the aperture, at least on my example. Also, I understand why manufacturers do it from a production point of view but glueing transparencies together as a part of the build is not an easy task. Do you use CA & risk fogging & finger marks or PVA & risk the joint coming apart. I used the latter without complete success on the main canopy where separate parts (with/without blister) are supplied, according to which version you build. Also, my bomb bay doors are attached to their fore & aft jacks, but "float" inbetween - not right!. Anyway, not bad for a first effort IMHO! I've bought a base sheet which I have to mount on a suitable plinth & add the Airfix bomber resupply set which I am busy with at the moment. 9 Link to comment Share on other sites More sharing options...
SimonR Posted April 11, 2016 Share Posted April 11, 2016 Both very nice, love the Lanc, got this kit in the stash, does it go together ok? Cheers Simon Link to comment Share on other sites More sharing options...
Graham T Posted April 11, 2016 Author Share Posted April 11, 2016 Both very nice, love the Lanc, got this kit in the stash, does it go together ok? Cheers Simon Yep pretty viceless! Link to comment Share on other sites More sharing options...
Duncan B Posted April 12, 2016 Share Posted April 12, 2016 Both very nice, the B II is such an interesting subject but of course the Dora is my favourite. I now what you mean about HGW fabric seatbelt instructions having just made my first set but they look great once finished. Duncan B Link to comment Share on other sites More sharing options...
