54mm Scratchbuilt Hansom Cab - buckling down to it
The horsie and his harness look terrific I must say.
Your driver looks like he has been savaged by his own mustaches however.
Not unsalvageable though, just cut in some skin tones with a fine brush. A bit of a trim as you might say.
I do a lot of face fur with a pencil. A clear coat turns the graphite from silvery to black. It does mean I have a lot of brunette figures...
I might give that a go Tzulscha, this is only a facial recognition test anyway, he is destined to get darker brown, almost black hairyness after I get his eyeballs done
And yes I know the eyes are scary too at the moment
Pencil, I did wonder about the silveryness
Obviously well worth a try
I was considering adding facial details with watercolour pencils too
Yes it probably would, I'm just having one of my sessions of not quite liking it lately
too many sessions of it not quite setting and the like
but re-inspired I might whip off the plasticene and whip up a dollop of Milli :)
I have to admit Bill, I was quite surprised you hadn't used Milliput as you're the master of using it for canopy moulds & the like. I have to admit to hating the stuff personally as I never seem to be able to mix it properly & end up having those non setting issues!
Loving the work on the horse and tack, smashing stuff.
If you don't want to use Milliput, would it be feasible to carefully cut the plasticine into two halves. Cast them in resin, and then reassemble? That way you can retain the nice curves but also the crucial snug fit?
Yes I did think about casting a collar (or two!) but I was having 'stale brain syndrome' and simply went for the modelling clay as a'quick fix'. Wasn't that going to happen huh? :(
No I've decided to do it proper, out with another humungeous sheet of clingfilm next huh
Miliput tonight.......
At least it won't distort slightly every time I walk by. :)
Good question Roger, I've never tried it
Can it be rolled out like Milli or plasticine?
Should I hang fire on whipping off the plasticine collar 'til I can find some to try out?
Tamiya epoxy can be used just the same as Miliput armour modellers roll it out thin to make tarpaulins as well as for adding lumps and bumps
Just type in Tamiya epoxy putty in toys & games on Amazon
Roger
Edited by Hamden
excellent work on those buckles Bill - really fine!.
I've used two part epoxy clay - admittedly not Tamiya, but several other brands - they are good for what they are but I find that they set rather quickly for my liking. Tamiya's may well be different
Just as an FYI - there are also several brands of air drying modelling clay on the market that might do the job
Quick setting sounds like just exacterrley wot I need Hendie
Off to LMS tomorrow in 'seek mode
or it'll have to be Amazon
Or Das which the LMS does stock, how long does Das take to dry out?
I suddenly realized that I'm not sure that what I call 'plasticene' and what you guys call 'plasticene' is the same thing.
I am familiar with an oil based clay with a sulphur binder. Kids non-hardening modeling clay...
Yes? :huh:
That is why we call plasticene too Tzulscha
I have used it before for various, less important modelling tasks
If you use some old stuff, well modified by hand-dirt, paint and Klear it changes to a more stable medium that is very dry and flexible
It was easy to remove it from the horse's neck and came away undamaged so I can refit it if the epoxy putty doesn't work
When i used some to 'landscape' my abortive model railway. it (probably obviously!) depended on thickness - couple of mm was a couple of hours, 6-7 mm overnight.
Keith
Tried Das
Didn't like Das
Cant get used to Das...try something else
The chap in the LMS says he cannot get Tamiya Putty due to some kind of complex EU (maybe) regulations
"Some people can stock it because they have hoops jumped and import sorted"
:mental:
I have decided to use Milliput again
So Neddy got a new scarf and a new collar and the bulges on his 'saddle' that carry the shaft straps close to the shafts
(All these terms are utter rubbish but they're all my guesswork allows in the esoteric field of 'oss 'arnessery)
Anyway here's the latest
This tack will be painted in a day or so
The Milli is drying and I'm off to The Ace Cafe tomorrow in the Midget
When the basic tack is sorted Neddy and the cab will be stuck to the cobble street to allow further fixings to be bunged on
Most of this build is in the bag
If I ever get Jolyon right :banghead:
Cheers and thanks for looking in
Edited by perdu
Nice work again Bill, that collar looks just as good & no risk of any (now possibly non-existent!) oil leachiing out of plasticene & turning Neddy's neck into a gooey mess! I'm still mighty impressed by those plasticard buckles & straps too!
Enjoy your trip to the Ace!
Keith
The ACE CAFE on the Norff Circular, Park Royal* after a leisurely wander round the RAF Museum Hendon
I like to make a decent day of it when I goes to That London
I'll be back on Wednesday :)
I hopeses
*yes just of the A40 at the Hanger Corner Gyratory, words I remembered fondly from BBC traffic reports back in history, before local radio
Edited by perdu
Oh yes, deciding at the moment whether to utilise Tamiya tape for some of the harness and of course cutting 10thou plasticard for other parts of it
Soon be time to decide whether to carry on with Joleon or start again with some pieces of Airfix Connoisseur range figures and REDO FROM START
Tape and plasticard already painted in base colour German Brown from Vallejo
Cutting proceeds...
Edited by perdu
