Sign in to follow this
Shar2
OS2U Kingfisher detail Sets. 1:32
Eduard 1:32
The Kittyhawk Kingfisher, reviewed HERE is a a lovely kit, without any additional aftermarket stuff, but, with Eduard, there’s always room for improvement in any model kit. As such, they have now released three individual sets to adorn the kit with extra and improved detail, along with a set of masks to help with the painting of the greenhouse canopy. As with most sets of this type some of the kit details will need to be removed before the etch can be added.
Interior Set (32861)
Contained on two sheets of relief etched brass, on half the size again as the other, one is unpainted whilst one comes pre-painted. The unpainted sheet contains items such as replacement equipment trays, and boxes, with the trays having vibration mounts made up of four separate discs. The front cockpit hoop is given a new front face, which comes complete with grab handles and the cockpit decking is also given the etch treatment once the kit details have been removed. The rear mounted machine gun is fitted with new expended shell catcher, cooling jacket, sights, ammunition tank and armoured plates, whilst the gun ring is provided with a new internal rail.
The pre-painted sheet provides the modeller with a variety of coloured knobs and levers, new auxiliary instrument panels, trim wheels, plus replacement dials for the side panels for the front cockpit. The main instrument panel is also pre-painted complete with the instrument faces on the backplate. A little dab of aqua clear will give them the appearance of glass fronts. There is also a new document/map case radio faces, equipment fittings, and various straps.
External Set (32386)
The single long, yet quite narrow sheet contains what appear to be mostly parts to detail the engine, with new wiring harness, fittings for the cylinder heads and new cowling support ring. Yet there are numerous smaller parts on the sheet, some of which will need to be shaped, either by rolling a marble/ball bearing over them to make a dome, of running a ball point pen to enhance look of the strengthening ribs. The domed access panels to the main and auxiliary floats are fitted with individual wing-nuts, the main float also having a replacement rudder provided. The bomb crutches are completely replaced with etched pts and once assembled will really look the business, but care will need to be taken to get them right. The bombs themselves are fitted with replacement box tails, and additional tail fuse detail, along with front and rear arming vanes. The identification lights and landing lights are given new surrounds which have very fine screw detail etched into them.
Seatbelts (32862)
This small fret of brass comes pre-painted for the most part, but with unpainted clasps, buckles etc. Although the belts are broader than normal it looks like they will still be fiddly to make, yet it will give the cockpits a real boost, so if you buy only one set this should be it.
Masks (JX189)
Naturally a set of detail updates wouldn’t be complete without Eduard adding some masks. Made of Kibuki style tape they are easy to use and can help make painting less of a chore, especially with the canopy style that the Kingfisher has.
Conclusion
These sets may not be as comprehensive as some Eduard have produce, perhaps because Kittyhawk go most of the detail on the kit from the beginning. What is provided will certainly enhance the kit, but if you’re money conscious you may want to just go for one or two. Highly recommended
