Jessica Posted September 8, 2016 Share Posted September 8, 2016 Hey Peter, Did you notice in the photo above, that the leading edge strip on the Rotol blade is segmented and not a single piece? Interesting. Can't wait to see how the resin comes out! PR That's actually pretty common for metal leading edge strips. In the event of damage, you can replace one segment, rather than the whole strip. 2 Link to comment Share on other sites More sharing options...
Pastor Rich Posted September 8, 2016 Share Posted September 8, 2016 I recall pilots of the 7th PRG at Mt. Farm was really rough on the props when they transitioned to reverse lend-lease Spitfire PR's. Pilots tended to nose over a lot not being used to braking in the Spit. Lightning drivers (my neck of the woods) didn't have such problems being trikes with all metal props. The thing that could get them was if the Prop Mechanic put the right prop on the left engine (or vice-versa). I have a buddy who's Dad was the prop mechanic for the 34th PRS and made that very mistake. It's not a mistake that you easily repeat! Memorable enough is running an engine with the wrong prop on it let alone the butt reaming he got from the Line Chief for doing it! PR 1 Link to comment Share on other sites More sharing options...
airscale Posted September 8, 2016 Author Share Posted September 8, 2016 evening ladies... thanks again for your kind words Nice trick with the sandpaper! i'm sure that will come in handy some day! As it happens i'm working on the humble frog pritfire XIV in 1/72 and the carb intake will need to be replaced, so your image might come in handy as a reference.for what it's worth two nice shots i have of the area: they are really useful shots, thank you, and the slipper tank hooks will definately need to be included as I have pictures of TZ138 in race config carrying one (bloody ugly thing it is too..) You have sharp eyes mr PR! Looks it was patched up or something like it.Peter, the fairing is so impressive. Great work! What is this P38? Is it an automotive body filler? thanks chaps - if that prop leading edge sheath is in parts then so be it, but mine is done so it's staying that way - as for P38. yes it's a UK car filler and I really like it - its cheap for loads of it, dries quickly, is strong and can be machined etc - I use it exclusively now for any filling / shaping job..so, on with the news... I think I have just done something pretty bloody difficult, so lets start with that...I used the master of the carb intake to cast a copy in resin - here in the top pic you can see the pipes that were attached in the 2-part mould to allow resin in and air out.....in the bottom pic I have dremelled out some innards and am making a litho sleeve for the intake opening.....I needed some mesh for the intake screen and very nearly chopped up Mrs A's kitchen sieve, but then thought I would avoid castration and try something else - a thought struck me that the local 'Head' shop might have mesh for all the crazy pipes and bongs they sell (I live in Brighton, there are lots around )....so here it is, also with some fixing bolts that have yet to have the shafts cut off.....after fitting the intake..next came the difficult bit.....the real intake seems to be skinned as one part, there are no panel lines at all that I can see..I expect it is a number of welded pressings or something. This posed a bit of a problem as it is just one big group of concave and convex curves - I thought I would give it a go.....I used tape and wooden blocks to try and form it, lots of kinks formed, and a few cuts were needed to create overlaps I hoped I could do something with later....the first one I made was short at the front frustratingly so that got scrapped, the next is buried under tape on the right....the second taught me where to make some cuts and overlaps and came out better, even here I didn't think I could work the kinks out of it.....after lots of burnishing, and something I tried for the first time which was using a small hammer to beat the kinks and deformaties flat before filing and sanding out - always being careful not to go too thin or through the skin I ended up with something I am pretty proud of - it's not perfect, but it's a lot better than I thought I could do with it happy days thats all for nowTTFNPeter 7 Link to comment Share on other sites More sharing options...
Nigel Heath Posted September 8, 2016 Share Posted September 8, 2016 That's lovely, that is. 1 Link to comment Share on other sites More sharing options...
cngaero Posted September 8, 2016 Share Posted September 8, 2016 I'm having difficulty speaking at the moment because my jaw has hit the floor again. That oil cooler is the bogs dollocks! You're coming on leaps and bounds now. I'm patiently waiting for my next fix. Thanks for sharing your skills with us. 1 Link to comment Share on other sites More sharing options...
lunarhighway Posted September 8, 2016 Share Posted September 8, 2016 that will do !!!! 1 Link to comment Share on other sites More sharing options...
hairystick Posted September 9, 2016 Share Posted September 9, 2016 Will there be an 1:18 scale English wheel being made for the panel work? 3 Link to comment Share on other sites More sharing options...
Pastor Rich Posted September 9, 2016 Share Posted September 9, 2016 My two favourite things that make my jaw drop lately: 1. The winning try for the ALL BLACKS at RWC 2015 2. THIS SPITFIRE BUILD!!!!! Masterful! Simply marvellous!!! I knew this part was going to take some time to fabricate and what incredible results Peter! Standing stunned in the Peanut Gallery.........PR 1 Link to comment Share on other sites More sharing options...
Valenstitch Posted September 9, 2016 Share Posted September 9, 2016 Sweet Baby Moses.................I`m speechless, I've been following this build from the start, every time I log on I hope there`s going to be another update, and it never disappoints! This is jaw droppingly brilliant, I`m sitting here mouth open in astonishment, kind of grinning and laughing out loud at the same time! Today is a good day! 1 Link to comment Share on other sites More sharing options...
noelbarnes Posted September 9, 2016 Share Posted September 9, 2016 Me and the family have been stuck at home with Gastro today.....I stumbled across this and it has been the good medicine to take my mind off of feeling lousy. Amazing work. 1 Link to comment Share on other sites More sharing options...
airscale Posted September 11, 2016 Author Share Posted September 11, 2016 morning folks so a couple of piccies this morning.. ..this is up next... tailwheel & bay... ..I designed the wheel & had that 3D printed, so next was the yoke - I made a paper template and started to cut it from thick brass sheet.. ..used the lathe to turn the leg... ..finished shaping the yoke and soldered it to a bit of tbe that would carry the oleo strut.. ..built up a collection of parts to make the basic leg/wheel combo.. ..and assembled them (I can take the wheel off still so I can paint it all...) ..I think I will make the whole tailwheel bay separately and just remove a section of the model and replace it with the finished structure rather than fiddle about trying keyhole surgery into a little opening in the fuselage.. onto that next... TTFNPeter 19 Link to comment Share on other sites More sharing options...
Nigel Heath Posted September 11, 2016 Share Posted September 11, 2016 Lovely neat work. 1 Link to comment Share on other sites More sharing options...
F4u Posted September 11, 2016 Share Posted September 11, 2016 Superb! Guy 1 Link to comment Share on other sites More sharing options...
Blogs On Posted September 11, 2016 Share Posted September 11, 2016 Even more superb work! 1 Link to comment Share on other sites More sharing options...
Pastor Rich Posted September 12, 2016 Share Posted September 12, 2016 (edited) Peter, Great idea on building the tail wheel bay separately! Keep it simple!! As much as I can't wait to see it sitting on all three wheels, the journey is just TOO MUCH FUN to rush through!!! I'll bet you're thinking about doing some major structures to move the project forward. Have you been thinking about skinning the wings yet? Once the tail wheel is done you'll have nothing to keep you from that, will you? Even skinning the vertical stab or a good chunk of the empennage?! Standing in perpetual applause in the Peanut Gallery, PR Edited September 12, 2016 by Pastor Rich 1 Link to comment Share on other sites More sharing options...
airscale Posted September 12, 2016 Author Share Posted September 12, 2016 evening my friends & thanks for stopping by so, a small bit to add to the WIP today - I started the tailwheel bay - once I have this cracked then it is most of the build work done where I need to hack the airframe about - then I can start skinning it (you are right PR!) ..first step was to cut away a section that the bay will slot into... ...as the tailwheel carries quite a bit of weight, I had to think how best to spread the load and remove points of failure - I decided a brass sheet construction lined with litho - here top left is the top and front formers in brass with holes for the leg and a depression the tyre retracts into... below that a bit of litho marked on the back ready to be cut out as the liner.... and on the right a bit of soft aluminium being worked into a balsa former to get the tyre depression fairing... ...next I lined the brass with riveted litho and added a pin to the leg so I could pin right through the angled mount (in the vice) into the bay wall - that should carry the load and spread it into the brasswork... ..like this... and in place - it is too long as I got some rudder geometry a bit out and need to add some skin to make up the rudder shroud... ..and thats it for now - I am away on business for a few days so hope to be back for the weekend TTFNPeter 17 Link to comment Share on other sites More sharing options...
CedB Posted September 12, 2016 Share Posted September 12, 2016 Still speechless... amazing stuff Peter 1 Link to comment Share on other sites More sharing options...
Pastor Rich Posted September 13, 2016 Share Posted September 13, 2016 Have a safe and prosperous trip Peter! Looking forward to your return. We'll manage on our own, somehow!!!! 1 Link to comment Share on other sites More sharing options...
Mr B Posted September 13, 2016 Share Posted September 13, 2016 Really outstanding work man or man just great rgds 1 Link to comment Share on other sites More sharing options...
Spookytooth Posted September 13, 2016 Share Posted September 13, 2016 Stunning Peter, no other words can describe what is going on. Simon. 1 Link to comment Share on other sites More sharing options...
Pastor Rich Posted September 13, 2016 Share Posted September 13, 2016 Hey Peter, One thing I noticed was that the oleo strut in the tailwheel photo in post #486 is not compressed. Yours is the same in the final fit of #491. You just need to shorten the strut to show "weight" on the gear. (Unless, of course, you can just bleed some air from the cylinder! Who knows how deep you got into the details there?!!!) Cheers! PR 1 Link to comment Share on other sites More sharing options...
John_W Posted September 13, 2016 Share Posted September 13, 2016 Wouldn't be suprised if it actualy works and compreses under load. 3 Link to comment Share on other sites More sharing options...
TGA Posted September 13, 2016 Share Posted September 13, 2016 Astonishing work Peter. Absolutely fabulous! 1 Link to comment Share on other sites More sharing options...
Caerbannog Posted September 16, 2016 Share Posted September 16, 2016 I start to wonder... do you employ apprentices?  Excellent work as always  Rene 1 Link to comment Share on other sites More sharing options...
John_W Posted September 16, 2016 Share Posted September 16, 2016 (edited)  47 47 minutes ago, Caerbannog said: I start to wonder... do you employ apprentices?  Excellent work as always  Rene I think he leaves it on the bench at night and tiny Elves do all the work. Edited September 16, 2016 by John_W Forum decided to post quote multiple times 4 Link to comment Share on other sites More sharing options...
