Phil Lewis
Revell 1/48 Bf109 G10 - Photo etch, rivetting and mottling
By the end of November 2015 I was getting quite confident. I had already decided on the next build a month earlier as I had been eying up the old Revell 1/48 Bf109 G10 which I had bought some years previously for silly money (£5 if I remember correctly). I had recently picked up some photo etch sets for various intended projects at Scale Model World and also picked up a rivetting tool.
I also have the Hasegawa Luftwaffe pilot figures and equipment set so the lack of a pilot was not an issue.
Unfortunately I cannot find the pictures I took of the initial stages so we start at the completed cockpit enhanced with an Eduard photoetch set fully enclosed in the fuselage and the wings and tail already on.
The various scoops around the nose have been hollowed out as have the exhaust stubs. You will also note that I made the cardinal sin of assuming something without checking references and cut off the square bulge for the enlarged battery behind the pilot and made it flush with an engraved door as in the E model.
Did not realise my error until all was buttoned up and painted so it's not going to get corrected.
Revell48Bf109G10WIP-05-03-16basic01_zpss
I have come to the realisation that I need a LOT more practice with photoetch but I did manage to get it mostly in without too much anguish.
Revell48Bf109G10WIP-05-03-16basic02_zps5
Managed to fettle the gear into the up position (I really prefer them flying :))
Revell48Bf109G10WIP-05-03-16basic03_zps8
Cut out the solid navigation lights and created clear ones fron clear sprue cut to a right angle, drilled at the back and the relevant colour of Tamiya clear popped in the hole.
Glued to the wing and then sanded and polished to shape.
Red didn't turn out so good.
Revell48Bf109G10WIP-05-03-16basic04_zpsz
Happy with the green though
Revell48Bf109G10WIP-05-03-16basic05_zps5
Those hollowed out and painted exhausts
Revell48Bf109G10WIP-05-03-16basic06_zpsy
I felt he looked better with the 'tache although he now looks more likely to say 'Tally ho chaps!'
Revell48Bf109G10WIP-05-03-16basic08_zpsb
In his office
Revell48Bf109G10WIP-05-03-16basic09_zpsm
Canopy on
Revell48Bf109G10WIP-05-03-16basic10_zpss
The pencil lines show where I have added the rivet lines using the Master tools rivetter although I couldn't get the rivets to show on the picture
Revell48Bf109G10WIP-05-03-16basic11_zpst
Used custom Tamiya mixes for the RLM 76,81 and 82.
RLM 76 applied after a nice undercoat of primer and a preshade. Note the prop spindle is now missing. That is the result of a mishap whilst undercoating whereby the spring clamp I was using to hold the plane sprung off sending the freshly primered 109 nosediving to the front dorstep where it proceeded to cartwheel with all the grace of a wounded gymnast hard against the wall. Not a happy bunny. Fixed it by drilling out the centre and glueing in a length of plastic rod of the appropriate diameter when the time came to add the prop
Revell48Bf109G10WIP-05-03-16basic14_zpst
Freehanded the camo but did use blutack sausages for the demarcation between upper and lower and Tamiya tape for the nose
Revell48Bf109G10WIP-05-03-16basic13_zpsj
My first attempt at freehand mottling with an airbrush begins, I had also feathered in the demarcation between the RLM 76 and the top camo colours.
Revell48Bf109G10WIP-05-03-16basic15_zpst
2nd mottle colour on
Revell48Bf109G10WIP-05-03-16basic16_zpsr
3rd mottle colour on and the nose is now a very fetching shade of RLM 04 Gelb
Revell48Bf109G10WIP-05-03-16basic18_zpsj
Gloss coated and decals on. Didn't use the decal for the green fuselage band as it didn't go all round the fuselage at the location it was supposed to be at.
Revell48Bf109G10WIP-05-03-16basic19_zpss
Revell48Bf109G10WIP-05-03-16basic20_zpsc
All the bits on, some weathering courtesy of the new set of Flory washes I got from Telford, a bit of exhaust staining topped with a coat of Tamiya Matt Clear and we're just about done.
Revell48Bf109G10WIP-05-03-16basic21_zpsj
Swastika came from a very old Xtradecal set of assorted sizes and I ended up masking around the fuselage decals and painting the fuselage band with my own approximation of the green.
Revell48Bf109G10WIP-05-03-16basic22_zpsf
Revell48Bf109G10WIP-05-03-16basic23_zpst
And you even get a shot of Phil's fingers too:)
Revell48Bf109G10WIP-05-03-16basic24_zpsg
Comments and suggestions always welcome.
Looks great. Congrats on the camouflage and free-hand mottling. Very well done :clap2:
Jaime
You have more courage than I. I'm afraid to even attempt painting a pilot figure. Nice work. Thanks for posting. Bob H.
