vontrips Posted May 5, 2016 Share Posted May 5, 2016 i wrote the Fiat museum...but they reply with so much delay, if at all... probably tipping a round table to call the spirits who built the engine. Typical of the Italian way! I concur, they are mesh intake gravel guards stuck on with some kind of old gak, and probably from a later period. I won't be surprised if it ran without them back in the day (so the kit part apertures could be drilled out!). Having said the one would think they would have some kind of protection when used in an airship configuration? There are clearer pics around, but can't find them now. To help research look for pre-war Solex carbs, as they are very similar. You'll see from search results that the carbs show little sign of having any filter attachment points! 1 Link to comment Share on other sites More sharing options...
sharknose156 Posted May 5, 2016 Author Share Posted May 5, 2016 (edited) Gentlemen, great to be back in full swing.... thank you very much for your inputs. yes i looked at solex carbs, excellent idea by the way. And other of the same period. just for general info, without being pedantic and for those who are interested in man's ingenuity : look at these beauties http://www.ebay.com/bhp/brass-carburetor http://www.prewarcar.com/index.php?option=com_caradvert&Itemid=106§ion_id=&dealer=0&part_category=20&part_manufacturer=0 Botafogo Fiat JL Chevrolet patent solex Ford T Edited May 5, 2016 by sharknose156 1 Link to comment Share on other sites More sharing options...
Codger Posted May 5, 2016 Share Posted May 5, 2016 Those things could be medieval marital aids..... Link to comment Share on other sites More sharing options...
sharknose156 Posted May 5, 2016 Author Share Posted May 5, 2016 haha, yes, they look like painful tubes for hydraulics, gymnastics and mechanics ! Explains why Henry only had Edsel, Chevrolet had only two sons and William Durant seems to only have had Cliff. Link to comment Share on other sites More sharing options...
roymattblack Posted May 5, 2016 Share Posted May 5, 2016 That one looks postively obscene! Roy. 2 Link to comment Share on other sites More sharing options...
vontrips Posted May 5, 2016 Share Posted May 5, 2016 Those things could be medieval marital aids..... Steely Dan? Link to comment Share on other sites More sharing options...
vontrips Posted May 5, 2016 Share Posted May 5, 2016 That one looks postively obscene! Roy. Ha ha; it's turning into Six Degrees of Separation here - what with the mention of Edsel from Sam! You guys know why it's thought the Edsel didn't sell, right?! ;-) Link to comment Share on other sites More sharing options...
roymattblack Posted May 5, 2016 Share Posted May 5, 2016 Abberlootley!!! I've got an Edsel kit in my stash. Am I the only one that thinks the Edsel looks fantastic? Roy. 1 Link to comment Share on other sites More sharing options...
vontrips Posted May 5, 2016 Share Posted May 5, 2016 Abberlootley!!! I've got an Edsel kit in my stash. Am I the only one that thinks the Edsel looks fantastic? Roy. I'd love one, if I had enough room to park it! Link to comment Share on other sites More sharing options...
sharknose156 Posted May 5, 2016 Author Share Posted May 5, 2016 (edited) The Edsel : snake oil .... and dragg ster... ps it does look good, the two doors coupe Edited May 5, 2016 by sharknose156 Link to comment Share on other sites More sharing options...
larchiefeng Posted May 5, 2016 Share Posted May 5, 2016 I've always liked the Edsel. My very first car model was an AMT screw bottom 1958 Edsel back in 1958. Long time ago! Link to comment Share on other sites More sharing options...
sharknose156 Posted May 15, 2016 Author Share Posted May 15, 2016 little progress to report, been working on preparing the body for priming and painting. will post pics very soon. also working on detailing the engine a little. Been researching pre war spark plugs and cables... here is what i found and settled for : so... pre war spark plugs for those gentlemen ( and ladies ) who can appreciate: top is the Italeri provided solution IMO both cable and pin out of scale below is a new spark plug 'Ã la' pre-war and silk cable and small pin. so now in process of repeating this 23 more time. Needless to say i did this first one 'a good deal of times' before i could get it right. will post pics of the body priming and painting as soon as possible cheers for now. 1 Link to comment Share on other sites More sharing options...
Jnkm13 Posted May 15, 2016 Share Posted May 15, 2016 Hi Sam, Looking good. Where did you get the small pin and silk from? Wondering if I should get some silk cable for my Bentley. Jeremy Link to comment Share on other sites More sharing options...
Codger Posted May 15, 2016 Share Posted May 15, 2016 Excellent choice and detail work. Link to comment Share on other sites More sharing options...
sharknose156 Posted May 15, 2016 Author Share Posted May 15, 2016 (edited) Thank you gentlemen. Joke aside on the girl advertising the spark plugs, one of the aspects of scale modeling i enjoy very much is the historical research. Jeremy, the silk cables are 0.6 mm from Prime Miniatures. Painted nato black with a hand brush ( AK interactive colors ) for the pin i simply used the older bigger pins, cut it, filed it using 50 % or less and drilled a smaller hole. for the rubber insulator i used the Italeri original cable, painted flat black to give the old rubber look. spent the afternoon priming and wet/dry sanding while following the F1 race, which was won by Young Vertsappen, youngest ever F1 winner at 18. Gravity Colors Primer: Here i used a Gravity Color primer for the first time. I found it very thin ( which i like ) and 'grabby'. The rivets etc. are still crisp, although perhaps not clear in the picture. i used 25 psi at about 10 - 15 cm with a H&S airbrush 0.2 mm. I first test-used spraying with a 0.4 mm but too much air as going trough and the results were terrible. 0.2 was perfect for my taste, it also cleaned very well and very quickly from the airbrush without using any nuclear chemical cleaners. Here is a pic after the first application. at this stage, it still needs wet/dry and then another application or two. Edited May 15, 2016 by sharknose156 Link to comment Share on other sites More sharing options...
Jnkm13 Posted May 15, 2016 Share Posted May 15, 2016 Thanks for the info. You used a 0.2 to paint? You must have the patience of a saint! I blasted mine with 0.5mm trigger type a/b! I used to follow F1, but stopped with the end of Mika's and Michael's rivalry. The new cars no longer look that appealing to me. Link to comment Share on other sites More sharing options...
larchiefeng Posted May 15, 2016 Share Posted May 15, 2016 I had my DVR set to record the race that, started here at 4:30 am but, the power went off at 3:30 am and didn't come back on until after 6:00 am. So, I missed the whole thing since it doesn't record with no power, Grr. Nice job on the plugs and good to see you back at it! Link to comment Share on other sites More sharing options...
sharknose156 Posted May 15, 2016 Author Share Posted May 15, 2016 (edited) Jeremy yes 0.2 small layers, it is fine, i prefer like this than too fast. Larchiefeng, Thanks. Unfortunately, my work is distracting me from this build... to my great frustration. on F1: been following F1 since a kid in the early 70's and did some little racing as well ( FF and F3 ). But i admit the current generation of drivers, except perhaps for Hamilton do not have interesting personalities. The cars are ugly and undistinguishable from each other. Now they are talking of putting a hood ... after creating scalextric tracks instead of racing tracks. In any case, today was a good race. 4 guys could have won, and the one who did deserved it, is truly talented, in control of himself, and bold. Usually the engineers are the ones more deserving than their drivers at the end of a modern F1 race. However, i don t mean to sound nostalgic. Whilst most sports with years became faster, more competitive and challenging; football, basketball, volleyball, golf, rugby, polo etc. F1 became more like an aquarium of spoilt brats racing each other wasting hundred of millions of whatever currency, just like popcorn, with much less spectacular challenges than their past elders. Edited May 15, 2016 by sharknose156 Link to comment Share on other sites More sharing options...
Borez Posted May 15, 2016 Share Posted May 15, 2016 Thank you gentlemen. Joke aside on the girl advertising the spark plugs, one of the aspects of scale modeling i enjoy very much is the historical research. Jeremy, the silk cables are 0.6 mm from Prime Miniatures. Painted nato black with a hand brush ( AK interactive colors ) for the pin i simply used the older bigger pins, cut it, filed it using 50 % or less and drilled a smaller hole. for the rubber insulator i used the Italeri original cable, painted flat black to give the old rubber look. spent the afternoon priming and wet/dry sanding while following the F1 race, which was won by Young Vertsappen, youngest ever F1 winner at 18. Gravity Colors Primer: Here i used a Gravity Color primer for the first time. I found it very thin ( which i like ) and 'grabby'. The rivets etc. are still crisp, although perhaps not clear in the picture. i used 25 psi at about 10 - 15 cm with a H&S airbrush 0.2 mm. I first test-used spraying with a 0.4 mm but too much air as going trough and the results were terrible. 0.2 was perfect for my taste, it also cleaned very well and very quickly from the airbrush without using any nuclear chemical cleaners. Here is a pic after the first application. at this stage, it still needs wet/dry and then another application or two. I find this with my H&S too, the 0.4mm nozzle seems to blow out a huge amount of paint. Trouble is though with most primers the 0.2 just clogs up all too easily. I've never tried Gravity Color primer though. Link to comment Share on other sites More sharing options...
sharknose156 Posted May 15, 2016 Author Share Posted May 15, 2016 (edited) Borez : My H&S never clogged with gravity primer or AK primer. Straight out of the bottle. But i paint right away and never pause more than a few dozens seconds. i also clean it immediately when done. Gravity colors fantastic if you like thin paint, it keeps all details crisp. Then they have several possibilities with gloss or polish finish. Edited May 15, 2016 by sharknose156 1 Link to comment Share on other sites More sharing options...
larchiefeng Posted May 16, 2016 Share Posted May 16, 2016 I don't know if Dave from the painting and masking thread looks at this thread Sam. But, this is exactly the result, I was referring to about how thin of a layer of paint can go down with an airbrush and not lose detail. This is perfect for getting just enough primer on without losing any detail prior to spraying your color coat. Looking good. Link to comment Share on other sites More sharing options...
Jnkm13 Posted May 16, 2016 Share Posted May 16, 2016 Don't you guys get uneven streaks using 0.2 mm on a big surface? I thin the primer / paint quite well, and using a 0.5 mm trigger type, it goes down very well, evenly covering big surfaces. Details are also not lost. Typically, 3 passes of the a/b with 5 minutes in between each pass will suffice. I have to stress that it's the trigger type a/b and not the regular type of a/b. Regards, Jeremy Link to comment Share on other sites More sharing options...
sharknose156 Posted May 16, 2016 Author Share Posted May 16, 2016 Larchiefeng, yes i feel i get much more accurate results than with spraying with a can. However, for painting my next large scale model i may try a spray gun from iwata. I painted one of my RC planes with cans and it worked fine. But i am not comfortable for smaller scale and for details like Roy does. But he is in another league. Jeremy, no uneven streaks at 0.2 but i still want to get the technique of using 0.4 mm right and bigger. https://www.youtube.com/watch?v=u6gI9ljJsdo&index=2&list=PLRK4diRzRX1dR1mLnD9HGKdCtl2CxIiy6 Link to comment Share on other sites More sharing options...
larchiefeng Posted May 16, 2016 Share Posted May 16, 2016 All this talk about airbrushing makes me want to break out my H&S airbrush and play around with the tips and some Zero Paint on one particular car I have. It's one of the cars I'm toying around with building next. Link to comment Share on other sites More sharing options...
larchiefeng Posted May 16, 2016 Share Posted May 16, 2016 I just watched the YouTube video that you linked and it was very good and makes a good argument for adding a larger modeling spray gun to the tool chest if you're going to be building large models and want to use better paint not available in cans or if you just want to use an airbrush/spray gun instead of cans. Thanks for sharing. Link to comment Share on other sites More sharing options...
