Phil Lewis Posted March 5, 2016 Share Posted March 5, 2016 (edited) This build took place late June to early July 2015 after residing in my stash since 2007/8 (can't remember exactly when I bought it) After the Tamiya 109E3 I wanted to try something that was not so shake 'n' bake and, as I wanted a Spitfire to go with the 109, I dug this one out. Work began with spraying the interior a custom mix of RAF interior green using Tamiya paints and then a light wash of burnt umber oils And then threw some paint in the general direction of the pilot figure Oh BTW can anyone tell me how to scale the picture sizes within the post? Whatever size the picture is it comes out enormous. Instrument panel painted up and dial markings scratched in to the faces. Interior assembled and pilot in place I had heard that the trailing edges on the flying surface were a little thick in this kit...no kidding! I think they were a scale 6 inches After much sanding, checking, sanding, checking....... I got the thicknesses to where I no longer cared. Closed up the fuselage added the wings and tailplanes, filled, sanded, refilled, resanded.......added canopy and arrived at the stage below Oh and I also thinned out the oversized cockpit door hinge. Canopy masked.. a bit harder than masking the 109 canopy And sprayed interior colour A nice coat of Halfords grey primer later... Some Tamiya flat aluminium toned down with Tamiya smoke in all the relevant places A bit of preshading After careful and strategic application of masking fluid a nice coat of RAF Sky (another custom mix of Tamiya paints) being careful not to completely obliterate all signs of the preshade. I decided I would try a something new (to me) and spray the camo freehand. I feel that the edges could have more definition but quite pleased with the result. At this point I think I had a rush of blood and completed the build without any further photo's But here it is. I used Xtradecal sheet X48145 as the kit sheet was rubbish. I think I only used the kit decal sheet's stencils And there it is. My second full build after a lengthy hiatus. You can find this aircraft accosting Adolph Galland's Bf109E3 in this RFI Comments and criticisms always welcome. Edited March 6, 2016 by Phil Lewis 2 Link to comment Share on other sites More sharing options...
Troy Smith Posted March 5, 2016 Share Posted March 5, 2016 really good job Phil. caught the oil and exhaust stains really well. the old tool Airfix can be improved even more, but requires more work, and a few leftover parts from other Spitfire kits really help see http://www.britmodeller.com/forums/index.php?/topic/59537-the-definitive-spitfire-mk1-thread/ Just in case you have another stashed (or for anyone else) cheers T Link to comment Share on other sites More sharing options...
Phil Lewis Posted March 6, 2016 Author Share Posted March 6, 2016 really good job Phil. caught the oil and exhaust stains really well. the old tool Airfix can be improved even more, but requires more work, and a few leftover parts from other Spitfire kits really help see http://www.britmodeller.com/forums/index.php?/topic/59537-the-definitive-spitfire-mk1-thread/ Just in case you have another stashed (or for anyone else) cheers T Thank you for your kind comments. I don't have any more of that particular release but I have invested in the Tamiya Mk1 which I have heard has issues and I also have the new mould 1/48 Airfix Mk1. I may do a side by side build with these but I have no plans to revisit the older Airfix kit. I do have the 1:24 scale one on the shelf though.... Link to comment Share on other sites More sharing options...
Troy Smith Posted March 7, 2016 Share Posted March 7, 2016 Thank you for your kind comments. I don't have any more of that particular release but I have invested in the Tamiya Mk1 which I have heard has issues and I also have the new mould 1/48 Airfix Mk1. I may do a side by side build with these but I have no plans to revisit the older Airfix kit. I do have the 1:24 scale one on the shelf though.... HI Phil Plastix dual build of the Airfix and Tamiya Vb kits (apart from cannon B wings the rest is same as Mk I) is well worth a read http://www.britmodeller.com/forums/index.php?/topic/234968337-two-148-mkvb-spitfires-tamiya-and-airfix-new-spitfire-collection-expansion-project-finished-photos-now-in-the-rfi-section-080615/ Has me showing some fixes for the Tamiya kit, if you can be bothered. The wing needs work as well, if you compare to the Airfix wing you will see it's to broad in chord. Fix requires removing ailerons, trimming back wing and filling and rescribing flap line. I've part done mine but no pics as yet. The new tool Airfix kit has a couple of potential pitfalls. The fit of the kit is very precise, a layer of paint or missed sprue nib in the wrong place can throw out alignments later, for example, the fit of the fuel tank cover. The UC leg attachment is badly designed, and it worth drilling and pinning from above, before closing up the wing. These are dealt with in link above, and below. Basilisk did a really good upgrade of the new tool Airfix http://www.britmodeller.com/forums/index.php?/topic/234986185-148-airfix-new-tool-spitfire-mki-x4382-from-no602-squadron-completed-on-31-10-at-1150-pm/ hope of interest and use. cheers T Link to comment Share on other sites More sharing options...
Phil Lewis Posted March 7, 2016 Author Share Posted March 7, 2016 HI Phil Plastix dual build of the Airfix and Tamiya Vb kits (apart from cannon B wings the rest is same as Mk I) is well worth a read http://www.britmodeller.com/forums/index.php?/topic/234968337-two-148-mkvb-spitfires-tamiya-and-airfix-new-spitfire-collection-expansion-project-finished-photos-now-in-the-rfi-section-080615/ Has me showing some fixes for the Tamiya kit, if you can be bothered. The wing needs work as well, if you compare to the Airfix wing you will see it's to broad in chord. Fix requires removing ailerons, trimming back wing and filling and rescribing flap line. I've part done mine but no pics as yet. The new tool Airfix kit has a couple of potential pitfalls. The fit of the kit is very precise, a layer of paint or missed sprue nib in the wrong place can throw out alignments later, for example, the fit of the fuel tank cover. The UC leg attachment is badly designed, and it worth drilling and pinning from above, before closing up the wing. These are dealt with in link above, and below. Basilisk did a really good upgrade of the new tool Airfix http://www.britmodeller.com/forums/index.php?/topic/234986185-148-airfix-new-tool-spitfire-mki-x4382-from-no602-squadron-completed-on-31-10-at-1150-pm/ hope of interest and use. cheers T Ok now I want to do the Airfix new tool. Basilisk's build is simply stunning. Link to comment Share on other sites More sharing options...
