AEW Navigator Posted March 14, 2018 Share Posted March 14, 2018 On 17/03/2016 at 19:16, Highlandsniper said: Can somebody help me please? I'm looking for information as follows: Location of ... ... ... Undercarriage locks. Any intake covers/blanking plates etc. Any other RBF tag uses on AEW.2 AEW.2 weapons bay - pix of Lindholme Gear plus flame/smoke floats etc. and anything else carried in the weapons bay. Thanks. I was a Shackleton AEW nav/captain for 9 years, until 8 Sqn folded at Lossiemouth in '91. My day to day bomb bay load was a set of Lindholme gear on the rear carrier, next station had 4 x 5" flares (nasty things!), then we had 3 carriers abreast. The middle one had 4 x Markers Marine and the outboard carriers were fitted Light Series Carriers and each had 4 x Smoke and Flame Floats. The Markers Marine and 5" flares all had RBF collars and tags on them. If we were going to deploy we used to drop the forward carriers and replace them with panniers. The pannier was a large, grey, canvas affair with a grey tubular external frame. I cannot put my hands on any photos at the moment, but I'll look. 2 2 Link to comment Share on other sites More sharing options...
AEW Navigator Posted March 14, 2018 Share Posted March 14, 2018 (edited) On 13/03/2016 at 21:28, John B (Sc) said: How did those de-icer strips work? Did they have small holes drilled in them to allow de-icer fluid to seep through? Their positioning below the centreline of the aerofoil nose section intrigues me. Presumably any fluid seeped upwards because of the reduced pressure? I did briefly wonder about there being an inflatable boot behind the wood, but why add weight and complexity, and a boot would normally be above the C/L to help crack off top surface ice, wouldn't it? Superb information this - thanks all. I used to see Shackletons almost daily for years and never noticed or knew of half these details. John B The de-icers were an anti-icing system. We would switch the pump, at the FE's station, to cyclic operation if we thought we were going to encounter icing conditions, wetting the flying surfaces with AL5, making it difficult for ice to accumulate. If the icing started setting off the alerters or we could just see it adhering we could set the pump to continuous. In that selection it wasn't going to last very long though, so we always tried to get out of the weather as quickly as possible. We also had to fly at specific speeds when using de-icing fluid, this was to ensure that the fluid would flow back over both the upper and lower flying surfaces. It was always beneficial to do a set of pre-flight checks on a dry day, as you could then see from the puddles appearing under the porous strips if any of them were blocked/failed. Edited March 14, 2018 by AEW Navigator grammar 2 1 Link to comment Share on other sites More sharing options...
