Lavochkin La-200 Avis kit problems - anyone else building one?
John R
Aaah! The u/c. I'm not looking forward to that. It did look a bit of a nightmare and flimsy with it.
What are you going to do about the drop tanks now we have found out that they are incorrect? I am in the process of reshaping the mountings.
I might just chicken out and leave them off - there are photos in the Red Star book of the La-200 without them - but with rocket rails.
Mine might be just in between the removal of the tanks - but before the fitment of the rails :whistle:
Or.... I may give myself a severe talking to - and try to re-shape the tanks like you John.
Ken - who is going off the idea of finishing the La-200.
The undercarriage is attached - but don't beathe on it - it's very weak.....
It may not support the model's weight....... (and trying to get both sides equal is a task).....
.... and the wheels have no 'ridges' between the tire and hub to aid painting - I've had to make some masks out of Tamiya tape.
I'm rapidly going off it.... :banghead:
Ken
I used Bare Metal Foil on mine
Reshaping the tank pylons isn't much fun either
John
Radleigh - the 'bit above' is the port undercarriage leg.
Ken
Of course it is, I posted from my phone and the image was tiny so I didn't really look at it to well! :doh:
Tough one, hope it holds! I'm no where near that stage yet..
Just a reminder on fitting the u/c legs tothe fuselage - make sure the locating holes in the u/c bay are clear and sufficiently wide to accept the u/c fittings BEFORE you fit the bay into the fuselage. It's impossible once fitted.
The real thing - or the model ???
I had to use a clear prop to take the weight off the delicate undercarriage.
There are some good B&W photos in the Red Star book showing the U/C - similar to the model photo above.
Ken
Just the model, I would love that book though..
I've painted the interior parts etc, should be good for closing up the fuselage soon, but I'm going to London tomorrow for the weekend so I cant post anything yet.
Anybody reading this and interested in seeing the finished article look in here
http://www.britmodeller.com/forums/index.php?/topic/235001226-lavochkin-la-200-with-korshun-radar-172-scale-model-from-avis/
It was posted by Ken (Flankerman) and shows mine as well as I didn't think it needed a another nearly identical thread.
Here is what I did to the u/c to stiffen it. Unlike Ken I managed to make the joint at front part of the trailing arm strong enough so now mine sits without the need of a prop.
John
Hi John,
That looks like a great solution to the weak legs - but the problem I had wasn't the vertical leg (they went in fine and are just strong enough)
My problem was with the horizontal trailing arm - with the tiny stub axles.
I attached them OK - but the glueing area is tiny - and when I went to add the wheels at the end of the build (to get the flats on the bottom lined up) - they simply broke off! - so when they were re-attached they were even weaker than before.
I'm impressed that yours are strong enough to take the weight without a prop :worthy:
Your completed model looks great - love the silver finish.
Ken
