Selwyn Posted February 13, 2016 Share Posted February 13, 2016 I am building a 1/72 Draken (the Hasegawa/ Revell kit) depicted c:1980 when visiting RAF Gutersloh when I was based there. Has anyone got any definitive information on the correct location and design of the outer wing pylons of the Danish Draken? Pictures on the net are at best a bit indistinct on this. there also appears to be what looks to be some additional wing fences fitted on the underside of the outer wing pylons as well in the pictures I have seen. Also can anybody give me an idea of the typical warload of a Draken at the same time period? Many thanks, Selwyn Link to comment Share on other sites More sharing options...
Julien Posted February 13, 2016 Share Posted February 13, 2016 The pylons are in our walkaround http://www.britmodeller.com/forums/index.php?/topic/78658-saab-draken/ Link to comment Share on other sites More sharing options...
Selwyn Posted February 13, 2016 Author Share Posted February 13, 2016 The pylons are in our walkaround http://www.britmodeller.com/forums/index.php?/topic/78658-saab-draken/ Yes I have seen them, but I am looking more for dimensions/locations. Selwyn Link to comment Share on other sites More sharing options...
Jens Posted February 13, 2016 Share Posted February 13, 2016 I think I have some pictures of what you are looking for. As for the typical load don't use the Draken in the walk-around section as a reference. Even the Sidewinder launcher is incorrect for a Danish Draken. While I look for my pictures you might want to check out these two links:http://www.britmodeller.com/forums/index.php?/topic/45336-building-the-hasegawa-draken/?hl=%2Bdraken+%2Bbuild http://www.amarc.dk/index.php/gallery-mainmenu-31/27-jet-aircraft-pictures Jens 1 Link to comment Share on other sites More sharing options...
Ossington 2 Posted February 13, 2016 Share Posted February 13, 2016 These any good? 1 Link to comment Share on other sites More sharing options...
Selwyn Posted February 13, 2016 Author Share Posted February 13, 2016 (edited) These any good? Its the 2 pylons under the outer wing i am looking for. Selwyn Edited February 13, 2016 by Selwyn Link to comment Share on other sites More sharing options...
Jens Posted February 13, 2016 Share Posted February 13, 2016 Selwyn, the pylons are identical. Jens Link to comment Share on other sites More sharing options...
Finn Posted February 13, 2016 Share Posted February 13, 2016 Don't know how accurate these drawings are but it should give you an idea on location of the pylons: http://www.the-blueprints.com/blueprints-depot/modernplanes/saab-ab/saab-j-35-draken-5.png Jari Link to comment Share on other sites More sharing options...
Selwyn Posted February 13, 2016 Author Share Posted February 13, 2016 Selwyn, the pylons are identical. Jens Thats good I can use the pylons with the kit as a pattern! Selwyn Link to comment Share on other sites More sharing options...
Selwyn Posted February 13, 2016 Author Share Posted February 13, 2016 Don't know how accurate these drawings are but it should give you an idea on location of the pylons: http://www.the-blueprints.com/blueprints-depot/modernplanes/saab-ab/saab-j-35-draken-5.png Jari Great drawing! Just what I was looking for. Selwyn Link to comment Share on other sites More sharing options...
sloegin57 Posted February 14, 2016 Share Posted February 14, 2016 Don't know how accurate these drawings are but it should give you an idea on location of the pylons: http://www.the-blueprints.com/blueprints-depot/modernplanes/saab-ab/saab-j-35-draken-5.png Jari Selwyn, those drawings only show three pylons under the mainplanes. On the aircraft that used to visit Leuchars from '80 onwards, there was a fourth smaller pylon outboard between the second and third underwing fences. It appeared to be integrated with a PWR similar to the ones that were fitted to the wing tips of the F-100's towards the end of their service lives. HTH Dennis Link to comment Share on other sites More sharing options...
cardiff guy Posted February 14, 2016 Share Posted February 14, 2016 Check Maestro models they do resin bits for a Danish Draken Glenn. Link to comment Share on other sites More sharing options...
Phantom726 Posted February 14, 2016 Share Posted February 14, 2016 1 Link to comment Share on other sites More sharing options...
Phantom726 Posted February 14, 2016 Share Posted February 14, 2016 Hope this helps. Let me know if you need more detail shots. Bjarne 2 Link to comment Share on other sites More sharing options...
Selwyn Posted February 14, 2016 Author Share Posted February 14, 2016 Hope this helps. Let me know if you need more detail shots. Bjarne Great shots! Do we know what mark of sidewinder was used by the Drakens? don't always trust museum shots on this. Selwyn Link to comment Share on other sites More sharing options...
ya-gabor Posted February 14, 2016 Share Posted February 14, 2016 Hi Bjarne, Excellent photos and a lot of help with the Danish Draken. I am still collecting info for a future build of the 72ns scale Hase. Collected some resin detail parts, ejection seats and so on. But still missing some info on the tail section, will have to scratch it. The Danish airframes had the dispensers and also the tail hook. Any good full side view, rear view and photos from the underside would be welcome. The plan is to do that extra weathered Danish airframe that I have seen several photos of. I dont like heavy weathering but that one looked magnificent!!! When the Austrian Drakens visited Hungary I took some views of this areas but they had a different version from the Danish, while the one at Kecel museum is a Swedish version without these modifications. ( Thanks in advance for help. Best regards Gabor Link to comment Share on other sites More sharing options...
Phantom726 Posted February 14, 2016 Share Posted February 14, 2016 Selwyn, I'll let Jens comment on the Sidewinder type. However, I think it's either B or P. Gabor, More shots inbound. 1 Link to comment Share on other sites More sharing options...
Phantom726 Posted February 14, 2016 Share Posted February 14, 2016 Link to comment Share on other sites More sharing options...
Hook Posted February 14, 2016 Share Posted February 14, 2016 I'll let Jens comment on the Sidewinder type. However, I think it's either B or P. It looks like a G to me. HTH, Andre Link to comment Share on other sites More sharing options...
Phantom726 Posted February 14, 2016 Share Posted February 14, 2016 2 Link to comment Share on other sites More sharing options...
Selwyn Posted February 14, 2016 Author Share Posted February 14, 2016 It looks like a G to me. HTH, Andre I know that the aircraft in the pictures has got a D/G sidewinder on it, but is this the model of sidewinder used operationally? Museum aircraft can have anything put on them for display. Selwyn Link to comment Share on other sites More sharing options...
Julien Posted February 14, 2016 Share Posted February 14, 2016 Any chance of sharing those shots for the walkaround section? Link to comment Share on other sites More sharing options...
Phantom726 Posted February 15, 2016 Share Posted February 15, 2016 Julien, No problem at all. Bjarne Link to comment Share on other sites More sharing options...
ya-gabor Posted February 15, 2016 Share Posted February 15, 2016 Hi Bjarne, Thanks for the photos you have posted. They are excellent and a lot of help! I am working on a 72ns Su-27 at the moment but seriously considering bringing the Draken project forward after this. Best regards Gabor Link to comment Share on other sites More sharing options...
