IDF Infantry Set 2000- (HS-004) 1:35
Mike
1:35 Meng Models
With the profusion of Israeli armour that we seem to have these days, it makes sense to have some figures to go with them, and Meng have now released another set to complement their original vehicle crew set that we reviewed here some time ago. This set contains four figures that would be ideally suited to a foot patrol accompanying armour, with modern equipment that places them in this millennium. They arrive in a standard figure-sized box in a satin finish, and inside you will find four sprues in a shiny mid-grey styrene. The instructions consist of a painting guide on the rear of the box, and each figure's parts are together on one sprue for ease of construction.
Each figure has separate legs, arms torso and head, plus a helmet with an oversize cover that looks unusual, but I believe has something to do with cooling and shading the soldier's neck and shoulders. Weapons are all Tavor (TAR-21) based, with either red-dot or holo-sights, and one has a 40mm grenade launcher attached under the barrel. Ammo pouches are also separate and are shown attached in various arrangements to the figures' vests, with additional pouches and day-sacks in various configurations. The figures are very well moulded, although a little flash is present, which can be seen from the photos. It's all pretty easy to remove however, and a good wash in warm soapy water is advisable, as there seems to be quite a lot of mould-release agent on the plastic, probably due to the complex nature of the mouldings. Two of the figures are in a walking pose, one with his weapon across his chest, the other holding it down to his side. Of the remaining two, one is standing with his rifle in both hands in a relaxed but ready pose. The other is on one knee shouting (judging by the size of his cake-hole) into a field radio handset, with his rifle cradled in his free hand.
Colour call-outs are given in Vallejo codes, but it's easy enough to convert these to any other brand, or you could pick up the IDF colour set from Lifecolor that is within my review here.
Be sure to check out my review of the resin IDF load-carrying equipment set here.
Review sample courtesy of
  • 5 years later...
Mike:
The camouflaged helmet cover (mitznefet) is meant to break up the perfectly geometric shape of the helmets when infantrymen are prone or kneeling in wooded or rocky terrain. They can also be adjusted to provide protection from the sun, as you say.
HTH
Mike E.
