Mike
Liquid Pigment Sets
LifeColor
I've been a LifeColor user for some years now, and I really like their handy boxsets that include pretty much all you need to accomplish a task. These new sets are a bit of a new thing however, as they profess to be "Liquid Pigments", which is a new term to me. They are odourless, and can be washed off with water if wet, or removed using a special Remover liquid once dry. This gives the modeller a lot of leeway in weathering their model, applying effects here and there, or all over and then cutting any over application back as needed. They apply on a satin or gloss surface for best effect, and there is no stipulation of enamel or acrylic paint, so they're good to go for all surfaces.
Each set contains six bottles with green lids containing 22ml of product, which I suspect will go a long way if used sparingly, and can be thinned with water if a more subdued effect is required. You can apply the liquid with a paintbrush or airbrush to achieve different effects, so their usefulness is quite varied. They are also able to be used as filters if diluted, and you can mix the colours together to obtain new shades for a specific use. If you decide to put a different colour over the original application, you'll need to fix it with a coat of varnish so that the shades don't bleed together, so you'd better be happy with the original coat before you fix it! The Remover is included in each set, and is a clear almost odourless liquid with just a faint hint of the chemicals that make it up. This is probably best used with a brush or cotton bud to remove any excess pigment after it has dried.
The sets are themed for a particular subject, and are aimed primarily at Armour modeller, although like so many modelling techniques they would be equally at home on a heavily weathered aircraft, ship, vehicle or diorama. Brief instructions are given on the back of each box in Italian and English, with a few colour photos of the process to assist you in understanding their use.
Detail Emphasiser (LP01)
Contains: LPW01 Burnt Umber, LPW02 Black Umber, LPW03 Burned Olive Green, LPW04 Black Grey, LPW05 Colonial Dark Sand, RE Remover.
Rust Wizard (LP02)
Contains: LPW06 Deep Rust, LPW07 Eroding Light Rust, LPW08 Eroding Dark Rust, LPW09 Orange Marks, LPW10 Yellow Marks, RE Remover.
Rain and Dust Makeup (LP03)
Contains: LPW11 Rain Marks, LPW12 Road Dust, LPW13 Light Earth, LPW14 Dark Dust, LPW15 Soot, RE Remover.
Hulls & Wooden Decks (LP04)
Contains: LPW16 Fouling Green. LPW17 Surfaces Shadower, LPW18 Wooden Deck Darkener, LPW19 Wooden Deck Shadower, LPW20 Dried Salt, RE Remover.
Wings & Fuselages Detail Emphasizer (LP06)
Contains: LPW26 Black Liner, LPW27 Grey Liner, LPW28 Paynes Grey Liner, LPW29 Landing Gear Dust, LPW30 Blue Burned Exhaust, RE Remover.
You can purchase the sets, or get individual colours to either suit your needs or top-up your sets after use, as well as getting the Remover separately in case you run out.
Conclusion
I haven't had chance to use these yet, so will report back when I have. That said however, LifeColor do make some good products, and I'm not expecting to be disappointed. I'm actually looking forward to using them – now where did I put that Jagdpanzer IV?
Review sample courtesy of
I can defiantly recommend the Rust wizard set I have recently used it on my build of a north sea trawler in the maritime section
and you can add further pigments to it to get that heavy build up look.
Beefy
  • 3 months later...
