PlaStix Posted March 11, 2016 Share Posted March 11, 2016 Your work on this project is amazingly detailed! Very well done. Looking forward to seeing more. Link to comment Share on other sites More sharing options...
Thom216 Posted March 15, 2016 Author Share Posted March 15, 2016 (edited) Well, as can be guessed from this picture... ...I lost a part... One of the resin scoops pinged off into the wild blue nothingness, and resisted all efforts at being discovered. So, it's out with the mold and resin - which I hope isn't too old by now - to make a replacement. Wish me luck... Edited March 15, 2016 by Thom216 2 Link to comment Share on other sites More sharing options...
Cookenbacher Posted March 15, 2016 Share Posted March 15, 2016 I hate when that happens. Good luck with the resin, at least you have the skill to attempt such a feat. Link to comment Share on other sites More sharing options...
Thom216 Posted March 15, 2016 Author Share Posted March 15, 2016 (edited) For all I've done with resin, I'm still a novice. It's not that hard to do though once you actually do it for the first time. I bought the two-part mold and resin from Harbor Freight. Thankfully, my fears that the two part mold bottles were too old was unfounded! I had to shake them up quite a bit as they'd gone solid, but they're loosening up. Here's the mold and the master. There must have been an air pocket inside, because the hollow of the master only extends in so far as the inner lip. That's no problem though. Like the original, I'll carefully dremel out the cavity. And here is the mold with the 2 part resin. As I type this, it's getting cloudy and rising up a bit, as this resin expands a bit. So about an hour from pour, I should have a replacement scoop! Edited March 15, 2016 by Thom216 5 Link to comment Share on other sites More sharing options...
Thom216 Posted March 16, 2016 Author Share Posted March 16, 2016 I forgot to take a pic of the fresh part, warts and all. It had a bulge on the mating surface and a tongue of resin sticking out the inlet. Some careful dremel-ing got rid of that and opened up the inlet. Do this well ventilated and with a dust mast at least. Resin dust stays in the lungs and becomes a bad irritant. Both parts still need some cleaning up, and I have to add some material to the new part. I have to remember that the resin I'm using is not as hard as the ones that came with the kit. It's easier to sand, and so easier to go a leetle too far... 6 Link to comment Share on other sites More sharing options...
Arniec Posted March 16, 2016 Share Posted March 16, 2016 Great Save!!! :thumbsup2: Cheers, Link to comment Share on other sites More sharing options...
trickyrich Posted March 17, 2016 Share Posted March 17, 2016 Very nice, I only discovered resin casting last year, and I'm hooked!! Don't worry, you'll find that missing scoop........in about a years time! And yes resin dust is pretty bad for you! Link to comment Share on other sites More sharing options...
PlaStix Posted March 17, 2016 Share Posted March 17, 2016 Impressive! Link to comment Share on other sites More sharing options...
Thom216 Posted March 17, 2016 Author Share Posted March 17, 2016 Thank you! They're on now and I'm blending them in with filler and nail polish remover... 2 Link to comment Share on other sites More sharing options...
Thom216 Posted April 2, 2016 Author Share Posted April 2, 2016 (edited) Well, it's been a week or so since the last update. I've been distracted by a pair of X-Wings... Since, I have put the scoops on and they looked mighty messy a few times. I also put the 'dash' in place, which is a PE piece, then the cockpit glass was masked and the front piece applied I sprayed it interior green, then used that to test the join lines all around, which are looking pretty dang good! I'm happy with most of them. The scoops as well, as after some liberal applications of nail polish remover over the dissolved putty, i have a pretty smooth transition. I'll need to apply a little more putty on the lower fuselage join, as one side is showing a slight step and sand down a little here there, but that is as close to good as I've ever gotten on a first shot! Edited April 2, 2016 by Thom216 6 Link to comment Share on other sites More sharing options...
trickyrich Posted April 3, 2016 Share Posted April 3, 2016 that's some nice join work there, especially after all the surgery. She's looking great, can't wait to see what she looks like with some colour on! Link to comment Share on other sites More sharing options...
PlaStix Posted April 4, 2016 Share Posted April 4, 2016 Very impressive detailing! Link to comment Share on other sites More sharing options...
Thom216 Posted April 4, 2016 Author Share Posted April 4, 2016 Into the scribing process. Oh, the terror I must endure! Scribe. Sand. Curse. Scribe. Sand. Sand. Curse louder. Sand, scribe curse and so on... 5 Link to comment Share on other sites More sharing options...
trickyrich Posted April 4, 2016 Share Posted April 4, 2016 arrr now you're at the bit I really hate....scribing is no fun at all!! Link to comment Share on other sites More sharing options...
Caerbannog Posted April 5, 2016 Share Posted April 5, 2016 Scribing alone is bad enough but scribing an assembled kit is extra horror. But I am sure the result will be more than rewarding. René Link to comment Share on other sites More sharing options...
Thom216 Posted April 5, 2016 Author Share Posted April 5, 2016 I'm trying. Slowly getting better. Running low on CA and sanding sticks... 3 Link to comment Share on other sites More sharing options...
Thom216 Posted April 8, 2016 Author Share Posted April 8, 2016 (edited) I think it's a fair bet I won't be finishing this by the 10th... I hope I haven't lost anything. Edited April 8, 2016 by Thom216 2 Link to comment Share on other sites More sharing options...
Caerbannog Posted April 10, 2016 Share Posted April 10, 2016 Sorry to hear so. But better to finish it properly than in a hurry. Next GB will be better - that is what I have told me the last felt hundrets of unfinished GBs :-) Will you continue the build here? René Link to comment Share on other sites More sharing options...
trickyrich Posted April 10, 2016 Share Posted April 10, 2016 That is a shame to hear, I have been a great conversion and it was really interesting to watch and follow. Please keep updating this thread as I'm sure that there are quite who want to see this beast completed. Link to comment Share on other sites More sharing options...
Thom216 Posted April 10, 2016 Author Share Posted April 10, 2016 I will continue it! I will struggle with the panel lines until they are good! Or at least good enough... Should I keep it here, or move it en mass to the Works in Progress - Aircraft section? Link to comment Share on other sites More sharing options...
trickyrich Posted April 10, 2016 Share Posted April 10, 2016 I will continue it! I will struggle with the panel lines until they are good! Or at least good enough... Should I keep it here, or move it en mass to the Works in Progress - Aircraft section? where you feel happiest with, though I think it deserves to go in the WIP section so everyone can appreciate the work you're doing. Just ask Enzo to move it across....I think he can do it?? Or start a new thread with a link back to here.....and a link her to it. Link to comment Share on other sites More sharing options...
Caerbannog Posted April 21, 2016 Share Posted April 21, 2016 Have you moved it to the WIP? I cannot find it. Any news? Rene Link to comment Share on other sites More sharing options...
Thom216 Posted April 23, 2016 Author Share Posted April 23, 2016 It's next on the work bench. I took a breather to finish my 1/1000 Yamato. Once I get started again I'll start a new thread for it in WIP. 2 Link to comment Share on other sites More sharing options...
