1/72 - Polikarpov I-3 resin kit by Small Stuff Models - released
Homebee
Small Stuff (http://www.smallstuffmodels.com/) is to release a 1/72nd Polikarpov I-3 resin kit - ref.72003
Source: http://www.smallstuffmodels.com/2016/01/172I3WorkinProgress.html
1/72 Polikarpov I-3 - Work In Progress
Here is an update on one of the projects currently under development. The subject is the Soviet biplane fighter I-3, developed by Nikolai Polikarpov. It was produced in significant numbers and served in Soviet Air Force for several years in the late 1920s and early 1930s.
The model was build using old-fashioned modelling techniques without employing 3D modelling and printing (except for one part).
Fuselage.
01_Fuselage_01_IMG_8666.jpg01_Fuselage_02_IMG_8669.jpg 01_Fuselage_03_IMG_8671.jpg 01_Fuselage_04_IMG_8674.jpg 01_Fuselage_05_IMG_8676.jpg 01_Fuselage_06_IMG_8678.jpg 01_Fuselage_07_IMG_8680.jpg 01_Fuselage_08_IMG_8719.jpg 01_Fuselage_09_IMG_8720.jpg 01_Fuselage_09_IMG_8721.jpg 01_Fuselage_11_IMG_8722.jpg 01_Fuselage_12_IMG_8723.jpg 01_Fuselage_13_IMG_8724.jpg 01_Fuselage_14_IMG_8777.jpg 01_Fuselage_15_IMG_8753.jpg 01_Fuselage_15_IMG_8911.jpg 01_Fuselage_16_IMG_8912.jpg 01_Fuselage_17_IMG_8913.jpg 01_Fuselage_19_IMG_8916.jpg
Tail surfaces.
03_Tail_01_IMG_8665.jpg 03_Tail_02_IMG_8685.jpg 03_Tail_03_IMG_8797.jpg 03_Tail_04_IMG_8687.jpg 03_Tail_05_IMG_8799.jpg 03_Tail_06_IMG_8745.jpg 03_Tail_08_IMG_8758.jpg 03_Tail_09_IMG_8765.jpg 03_Tail_10_IMG_8766.jpg 03_Tail_11_IMG_8768.jpg 03_Tail_12_IMG_8771.jpg 03_Tail_13_IMG_8796.jpg
Lower wing.
02_Wings_01_IMG_8672.jpg 02_Wings_02_IMG_8673.jpg 02_Wings_03_IMG_8698.jpg 02_Wings_04_IMG_8705.jpg 02_Wings_05_IMG_8700.jpg 02_Wings_06_IMG_8702.jpg
Upper wing. One of my first experiments with 3D printing. The quality of the printed parts leaves much to be desired, but I managed to use them anyway.
02_Wings_08_IMG_9019.jpg 02_Wings_09_IMG_9021.jpg 02_Wings_10_IMG_9369.jpg 02_Wings_11_IMG_9861.jpg 02_Wings_12_IMG_9862.jpg 02_Wings_13_IMG_9863.jpg 02_Wings_14_IMG_9865.jpg
Radiator.
05_Radiator_01_08_IMG_8681.jpg 05_Radiator_02__IMG_8709.jpg 05_Radiator_03_IMG_8715.jpg 05_Radiator_04_IMG_8725.jpg 05_Radiator_05_IMG_8738.jpg 05_Radiator_06_IMG_8737.jpg 05_Radiator_07_IMG_8736.jpg 05_Radiator_08_IMG_8756.jpg 05_Radiator_09_IMG_8757.jpg
Wheels.
04_Wheels_01_IMG_8683.jpg 04_Wheels_02_IMG_8710.jpg 04_Wheels_03_IMG_8782.jpg 04_Wheels_04_IMG_8779.jpg 04_Wheels_05_IMG_8783.jpg 04_Wheels_06_IMG_8784.jpg
Other stuff.
07_Small_Parts_01_00_IMG_8805.jpg 07_Small_Parts_01_01_IMG_8805%2BCopy.jpg 07_Small_Parts_01_02_IMG_8806.jpg 07_Small_Parts_01_03_IMG_8822.jpg 07_Small_Parts_01_IMG_8827.jpg 07_Small_Parts_02_IMG_8826.jpg 07_Small_Parts_03_IMG_8831.jpg 07_Small_Parts_04_IMG_8830.jpg 07_Small_Parts_05_IMG_8828.jpg 07_Small_Parts_07_IMG_8836.jpg 07_Small_Parts_07_IMG_8919.jpg 07_Small_Parts_08_IMG_8917.jpg 06_Undercarriage_01_IMG_8716.jpg 06_Undercarriage_02_IMG_8740.jpg 06_Undercarriage_03_IMG_8742.jpg 04_Misc_03_IMG_8690.jpg 04_Misc_04_IMG_8691.jpg 04_Misc_05_IMG_8706.jpg 04_Misc_06_IMG_8707.jpg 04_Misc_07_IMG_8708.jpg
Sprues (those that are currently ready):
IMG_0016.jpg IMG_0017.jpg IMG_0052.jpg IMG_0055.jpg IMG_0028.jpg IMG_0056.jpg IMG_0020.jpg IMG_0059.jpg IMG_0003.jpg IMG_0007.jpg IMG_0008.jpg IMG_0013.jpg IMG_0011.jpg IMG_0012.jpg
V.P.
Edited by Homebee
  • 1 month later...
  • 3 weeks later...
Painting and Markings.
Source: http://www.smallstuffmodels.com/2016/03/I3Painting.html
Misc_profiles_02.jpg Although Polikarpov I-3 saw a relatively widespread service in the Soviet Air Forces in the late 20s - mid-30s, the number and quality of photographic references on this aircraft leaves much to be desired. With the upcoming release of Small Stuff's Polikarpov I-3, I'd like to make most of the information which I used to create the painting and markings instructions for this kit available to the model builder, allowing him to draw his own conclusions in the ambiguous cases.
All I-3s appear to be painted in a standard Soviet scheme of that era with dark green wings upper surfaces and the whole fuselage and light blue wings and stabilizers undersides. The duralumin cowling panels are left unpainted.
Red stars are positioned on both upper and lower wings. Stars of three types could have been used - a plain red star, a star with a black outline, and a star with both black outline and black circle. In most cases it's not possible to determine the exact type of the star from the photo, and while the black outline/black circle type is the most probable, two other types are also possible. All three types are provided in the decal sheet.
It looks like the stars on the rear fuselage are always placed in the same standard position. While some photos seem to prove otherwise, this is most probably due to the distortion caused by the fact that the aircraft's side doesn't face the camera directly. To illustrate this effect I have used my old I-3 model to reproduce the similar camera angles.
Except for one photograph, the type of the fuselage star is also impossible to determine. Three types are provided, with a black outline + black circle type being the default.
These are the actual painting options provided in the decal sheet:
_11%2Bblue.jpg Red "11", as seen in the archive footage. This aircraft has an unusual star with white trimming on its fin. It is possible that the color of the rudder number and the stripes on the spinner is actually blue. Both options are provided in the decal sheet.
This I-3 has two unique parts that are not included in the kit and need to be scratch built in order to make this specific plane - the generator on the lower wing and the radio mast on the upper wing. 05.jpg 04.jpg
_02.jpg White "2" captured on the footage from a military parade in a row of other I-3s with similar white chevrons. 01.jpg02.jpg
_chevrons.jpg Another I-3 from the same lineup. This aircraft lacks a number, but wears chevrons on both it's rudder and fuselage. 03.jpg 01.jpg
_04%2Barrow.jpg Red "4" with white arrow is probably the most famous I-3, seen on two photos with a number of other I-3's with similar white arrows. Although I don't have any photographic evidence of the red number on it's rudder which is depicted in color profiles in many sources, I still included this number in the decal sheet. The first photo is the only one available to me in which the type of the I-3 fuselage star can be clearly identified. _008.jpg _023.jpg
_strelok.jpg Only the middle part of the aircraft is visible on the photo, so it's imposible to reconstruct the whole scheme. The inscription reads "Strelok VOKhR Stalinshiny" ("The rifleman of the Internal Guard of the Stalino province"). Stalino was the name of the present day Donetsk, Ukraine. _019.jpg
_02.jpg White "1". This I-3 is distinguished by the red star on the front of it's cowling. 1350671697_1348203054_59a4f259214c.jpg
_06.jpg One of the I-3s featured in "If War Comes Tomorrow" movie (1938). The "6" on the rudder appears to be a color different from the usual red, probably blue or yellow (both options are provided in the decal sheet). The color of the spinner could be red, or perhaps the same as the rudder number color. 04.jpg 03.jpg
_04.jpg Red "4", another I-3 from "If War Comes Tomorrow". The spinner is probably red, but other colors are also possible. 02.jpg 01.jpg
11%2B-%2Bno%2Bmarkings.jpg This aircraft appears to be devoid of any markings. It's wing struts are painted a dark color, probably green, while the metal panel in front of the lower wing is left unpainted. _003.jpg 02.jpg
I would like to thank Andrey Petrov and Sergey Trufanov for their help in decals development.
Eugeny KnupferQuote
V.P.
Edited by Homebee
Source:
1/72 Polikarpov I-3 Update - Box, Instructions, Decals
Here is a little update on the upcoming 1/72 Polikarpov I-3 from Small Stuff.
Box:
Instructions:
Decals:
Release is now imminent
Source: http://www.greenmats.club/topic/1278-поликарпов-и-3-в-172-разработка-смоляной-модели/?do=findComment&comment=18031
Между тем, благодаря самоотверженной работе Мусы, полным ходом идет серийное производство:
IMG_1647.thumb.jpg.195c867e977a3d9a1cf6c IMG_1648.thumb.jpg.5a8d0f1c97a08f9178286
02.thumb.jpg.3e8b85db25bf18739f592a6a43fIMG_1650.thumb.jpg.32579cf12937a6db802db
V.P.
Edited by Homebee
  • 2 years later...
