Deadman Disciple Posted January 26, 2016 Share Posted January 26, 2016 The 1313 Mockingbird Lane (Munster House) diorama is all done.I finally started on the garden, with the green grass powder from the scenarama kit I bought.Having to resort to mixing Micro Crystal Clear with water, as the project glue had dried inside the bottle to a silicon sealant consistency & I couldnt get it to re-melt.Using the empty spray bottle that I got with the kit, I sprayed my solution onto the wooden base & sprinkled the grass powder on top with my fingers & thumb all over, then re-spraying the solution on top of the grass, I left it 24 hours to dry.Thinking it wouldnt work, the next day my fears had dissapated the grass had dried to a sandpaper like feel, so I started on the other side of the front garden & around the back.Once everything had dried, I removed the masking tape (for where I was going to place the trees & walls) & placed the completed trees & glued them into place with super glue.A couple of days before, I used some modelling putty & put some around the base of each tree & kneaded it into some grease-proof paper to create a flat-base root type shape.Leaving the putty to dry for 24 hours, the trees were now free-standing.Topping up around the roots of the trees with a little more grass powder, I started on the walls & metal fences.Humbrol 26 Brown & 9 Tan Brown for the walls & Revell 36190 Silver for the metal fences, I also glued those into place onto the wooden base.Also I had to cut the gate in half, but using a spare bit of another piece of the fencing, I clipped off one rod & glued it to repair the other half of the gate, to make it complete.Picking up a tip using Google, I used 4 different types of herbal tea leaves to re-create the fallen dead leaves from the tree around the base of the tree.Simply mixing Camomile, Lemon & Ginger, Blackcurrant, Raspberry (IIRC) & some normal tea leaves into a shot glass & scattering them around the base of each tree, using the clear solution, I think it has made a great effect with the various colors.Finishing off the base with some Revell 36179 Greyish Blue, to re-create a pavement, I started on the finishing touches of the house.I washed the hell out of the house with some Citadel Agrax Earthshade & glueing on the weather vane, TV aerial, chimney pot & spire top.Im really chuffed on how this has turned out, not bad for my first attempt at a diorama. Cheers, Wayne. 7 Link to comment Share on other sites More sharing options...
Darby Posted January 26, 2016 Share Posted January 26, 2016 Loved watching the Munsters. Grandpa was my favourite and Yvonne Di Carlo was lovely Link to comment Share on other sites More sharing options...
whitestar12chris Posted January 27, 2016 Share Posted January 27, 2016 Very nicely done, looks absolutely great. All the best Chris Link to comment Share on other sites More sharing options...
