Sign in to follow this
Mike
Camouflage Netting (Green or Tan)
Pegasus Hobbies
Armour modellers occasionally need a source of camouflage netting that looks good enough in scale to pass for the real thing. There are a number of DIY techniques, but they can be time-consuming, especially for the novice. These packs from Pegasus give you the basics that you need to begin, and they have been pre-dyed in either green or tan to take away one of the most messy stages of the task.
Each pack comes with approximately 30cm x 40cm of the cloth, folded up to the size of the bag, and they have differing texture to the threads. The tan pack is more or less an evenly-spaced mesh, while the green is more uneven, giving a tiger-stripe look. Both are quite transparent when used in a single layer, but this increases with layering, as you will hopefully be able to tell from the pictures. They could be used with 1:48 and above, but at smaller scales the threads may start to look overscale. You can add your own embellishments in the shape of tie-on squares or glued on mixed herbs for additional texture, and the colour can be varied further by airbrushing additional colour onto it.
Conclusion
A good starting point for any camouflage netting if you're looking to add some to the stowage of a vehicle or diorama. Watch out for stray fibres though!
Recommended.
Review sample courtesy of
