Nigel Heath Posted February 4, 2016 Share Posted February 4, 2016 Ouch indeed, that looks painful. I only use primers like Alclad or Tamiya, they contain solvents that bite into the plastic and hence give a very adherent bond. 3 Link to comment Share on other sites More sharing options...
bbudde Posted February 4, 2016 Share Posted February 4, 2016 Damned f**k. Happend to me once with a rattle can primer, but not that massive. I think this can be repaired, but is more than annoying. Yes, the primer has to be disposed into the bin. Good luck. Otherwise it looks cool in black & white undersides. Cheers 1 Link to comment Share on other sites More sharing options...
Cookenbacher Posted February 4, 2016 Share Posted February 4, 2016 That's a bummer Ced, but also an opportunity. Being in sunny NM, I have no choice but to see the bright side - all the time. It's very bright here. It's just my lot I suppose. 1. It's rare to get to make one build, but paint two schemes. 2. You've discovered a pretty sweet chipping technique, especially the bottom side. Hmm, I bet AK primer sticks to metalizer about as well as it does to plastic. 3. You've saved untold Britmodellers from the degradation of AK primer peal. 4. The Blenheim still looks pretty dang awesome. 2 Link to comment Share on other sites More sharing options...
CedB Posted February 4, 2016 Author Share Posted February 4, 2016 Gosh, thanks everyone, you ARE a supportive lot... I've been brush painting and Micromeshing the Blenheim on and off and decided I would brush paint the Hurri (and the Spit later) with H30 to avoid any de-masking problems later. Thinned with W&N flow improver she looks fine, just a 'different' green. I don't want to start the old VMA discussion again but look: What's green? by Ced Bufton, on Flickr Tomato, tomato (oh, that doesn't really work written down does it?) Then I decided I could treat myself and start trying the two-tone metal finish: That's as far as I got before shaky hands made me stop for a bit. Thanks to Cookie for the inspiration on his great P-47 build. 9 Link to comment Share on other sites More sharing options...
Spookytooth Posted February 4, 2016 Share Posted February 4, 2016 Capt. Sensible there Ced. Better to stop than to cock up sir. Still, who says that all planes must be A/B`d . Looking good mate. Simon. 1 Link to comment Share on other sites More sharing options...
Brandy Posted February 4, 2016 Share Posted February 4, 2016 (edited) Nice save. Thanks for the heads-up on that primer, I won't be investing in any! Ian Edited February 5, 2016 by limeypilot 1 Link to comment Share on other sites More sharing options...
Ascoteer Posted February 4, 2016 Share Posted February 4, 2016 Well saved Ced. 1 Link to comment Share on other sites More sharing options...
sean Posted February 4, 2016 Share Posted February 4, 2016 See...sorted...didn't I tell you. As for the greens, think yourself lucky you don't live in Ireland, we've got 40 shades of it. Sean 1 Link to comment Share on other sites More sharing options...
AlexN Posted February 4, 2016 Share Posted February 4, 2016 Just been looking at your link to Cookie's excellent NMF P-47 above - given the tenacity of the (AK ) metal paste in the face of the blue Scotch tape (my favourite), perhaps it's an alternative primer... But probably not, since acrylic top coats mightn't stick to it under the pressure of masking, and it would be too laborious and expensive. If the top coats *did* lift, however, you would have ready-made "metal" to explain the damage away as weathering. A somewhat Byzantine approach - I'll get back in my box now. Cheers, Alex. 1 Link to comment Share on other sites More sharing options...
jrlx Posted February 5, 2016 Share Posted February 5, 2016 Hi Ced, Not much time lately to follow threads but I see you made a good recovery from your troubles. The models are looking really good and I like the black-metal-white underside of the Hurri. Time allowing, I should be entering with that same model in the Hurri GB. You could try Alclad primers in a future build. They are really good and resistant. Cheers Jaime 1 Link to comment Share on other sites More sharing options...
CedB Posted February 5, 2016 Author Share Posted February 5, 2016 Thanks Simon, Ian and Debs Thanks Sean - shouldn't that be 50 shades of... oh, green, right. Thanks Alex and Jaime - I'm sticking to the Stynylrez in the future, lesson learned! I do think the idea of AK True Metal under acrylics might be good for chipping, although its waxy carrier might be too 'slippery'? Might give it a go sometime... So, I think the Blenheim needs one more pass and then some heavy(ish) weathering: The two-tone AK on the Hurri is progressing. A slow job but quite relaxing and satisfying. This stuff covers really well but you have to make sure that there are no blobs so best to start in the middle of a panel. I've also dry-brushed one of the gun panels as an experiment and dobbed some on the walkway: Two tone by Ced Bufton, on Flickr One needs to be a bit careful as trying to rub the stuff off actually just buffs it up. Hopefully the matt coat will cover all sins... 6 Link to comment Share on other sites More sharing options...
Cookenbacher Posted February 5, 2016 Share Posted February 5, 2016 Excellent recovery on the Blenheim Ced, and the metal panels on the Hurricane look awesome. 1 Link to comment Share on other sites More sharing options...
CedB Posted February 5, 2016 Author Share Posted February 5, 2016 Thanks Cookie I completed the 'metalling' today and also brushed some aluminium into the Blenheim (after checking the net that the wings were metal!). Here's the Hurri's bottom which I'm pleased to post: Done by Ced Bufton, on Flickr I'll Klear coat tonight and let it dry overnight then it's transfers on and time to get dirty!! 8 Link to comment Share on other sites More sharing options...
Spookytooth Posted February 5, 2016 Share Posted February 5, 2016 Steady going Ced. Fnar score 1 . Simon. 1 Link to comment Share on other sites More sharing options...
bbudde Posted February 5, 2016 Share Posted February 5, 2016 Looks great again. Go on further with rest. Cheers. 1 Link to comment Share on other sites More sharing options...
AlexN Posted February 5, 2016 Share Posted February 5, 2016 Excellent! 1 Link to comment Share on other sites More sharing options...
CedB Posted February 6, 2016 Author Share Posted February 6, 2016 Thanks Simon, bbudde and Alex Klear coated and waiting for transfers: Ready for transfers by Ced Bufton, on Flickr The Spit (obviously my favourite) has had the first coat of thinned DG applied: First coat by Ced Bufton, on Flickr I'm tempted to rip off carefully remove the masking and do the bottom this afternoon as it's just a second coat and touching up now and I DO enjoy using the AK True Metal... perhaps it's the smell but it's also the coverage. 7 Link to comment Share on other sites More sharing options...
jrlx Posted February 6, 2016 Share Posted February 6, 2016 Great progress and good recovery of the Blenheim, Ced! The Hurri looks really nice in Black-Silver-White underside. Looking forward to seeing the decals transfers on Cheers Jaime 1 Link to comment Share on other sites More sharing options...
Spookytooth Posted February 6, 2016 Share Posted February 6, 2016 Looking good Ced. All coming along quite nicely sir . Is that a H/S Evo S/L you have there mate? Simon. 1 Link to comment Share on other sites More sharing options...
CedB Posted February 6, 2016 Author Share Posted February 6, 2016 Thanks Jaime, not long to wait now, just waiting for some transfer mojo Thanks Simon Yep, it's the Evolution Silverline 2in1 recommended by Paul at modellingtools. Paul's great IMO... always happy to help you into a suitable purchase and, unusually, talk you out of an unsuitable one! The airbrush has certainly been good for me... Not that I've used it today. I think I cracked the seam on the Spit by clumsy drilling when I opened up the hole for the new stand support. It hasnt been solved by painting and can't be ignored any longer so I dabbed on some liquid green stuff and then brushed the AK on the bottom: Seam by Ced Bufton, on Flickr I've found that the AK thins nicely with white spirit (as suggested by AK), just dipping the brush in occasionally when it gets a bit thick / waxy. Nice stuff. 4 Link to comment Share on other sites More sharing options...
CedB Posted February 6, 2016 Author Share Posted February 6, 2016 ... and breathe. I have to hold my breath doing these, especially the tiny little stencils. And the ones on the black are WHITE! How the heck are you supposed to see those?: Done by Ced Bufton, on Flickr I've also realised that the lower nose windows on this one are painted. Did I mask them? Who can remember... too late now, the 'L' transfer is on. That's probably me done for tonight. I might sand and re-paint the Spit nose and Klear coat that but I won't bother with any pictures (unless there's something interesting to report). 6 Link to comment Share on other sites More sharing options...
Beard Posted February 6, 2016 Share Posted February 6, 2016 I've also realised that the lower nose windows on this one are painted. Did I mask them? Who can remember... too late now, the 'L' transfer is on. If you haven't painted the windows, let me know as I have some spare decals that you can have. 1 Link to comment Share on other sites More sharing options...
Biggles87 Posted February 6, 2016 Share Posted February 6, 2016 Great stuff Ced, I particularly like the Hurricane underside. Cheers John 1 Link to comment Share on other sites More sharing options...
Spookytooth Posted February 6, 2016 Share Posted February 6, 2016 Breathing life into her now Ced. With her decals on. Those small ones are a laugh, with our eyesight LOL. Looks good. Simon. 1 Link to comment Share on other sites More sharing options...
Cookenbacher Posted February 7, 2016 Share Posted February 7, 2016 Great progress on all three Ced. The metal undersides really look great in True Metal. Bummer about the seam on the Spitfire, but looks like you've got that sorted. Is it too early to ask what's next? 1 Link to comment Share on other sites More sharing options...
