Bandai Slave 1 painting help
Here's the link to the instructions for the Fine Molds version on the HobbySearch site, including the painting guide. If you squint you can just about make out the recommended colours from the Gunze Range. Tamiya equivalents are also provided in the accompanying table.
http://www.1999.co.jp/eng/image/10049184/10/0
cheers,
Jason
He uses magic Sam ;) Sorry - that was meant to be funny, but just came across condescending when I read it back :blush:
Look up paint chipping, and consider investing in AMMO chipping fluid, or something similar. You can also use liquid mask to protect portions of panels already painted metallic, and peel it off later, although it takes some skill to get the spots irregular and "in-scale". Last one I can think of at the moment is a small piece of sponge dusted with some paint, dabbed around the area. Again, difficult to make appear irregular, so it takes a bit of skill & practice :)
No I have looked at a lot of Andys build and I think he does use magic!
Yeah it's going to be hard getting the scale, the bandai models although really well detailed are crazily tiny! And I haven't painted any thing that detailed for a while.. Most my models lately end up being Lego with the little one
Not sure how I will paint the tiny Boba Fett that comes with the kit, is it possible to paint with a needle and microscope?
Get yourself an insanely small brush, and steady hands. Mine aren't too steady these days, so I brace them against eachother and/or a nearby part of the desk. Mounting the figure on a temporary base might also help, as it gives a larger point to hold it on, and you're less likely to muss up the paint with your (comparatively) giant fingers :)
