Sebastien 1,045 Posted January 6, 2016 Share Posted January 6, 2016 - Hi, I'm Sebastien and I'm a Tornadoholic - Hi Sebastien. This kit is lovely, and now I have two under my belt and a dozen or so to build, I thought I might do a WIP. My point isn't to build the ultimate Tornado. I couldn't, and the one and only General Melchett is doing a brilliant job about it. I'm just here to help average modellers like me to avoid the little troubles you can have building this kit. So I'll accept all pointers, kicks in the butt, subtle and not so subtle hints and bribes Lagavulin pieces of advice you'll throw my way, and be grateful about them. Now, on with the build. I started by more or less following the instructions (yeah, I know, who does that?), and assembled the cockpit to the fuselage bottow and front wheel well : I glued the WSO instrument panel and while the glue was setting, I dry fitted a nose wall to the fuselage. That way, the instrument panel took its intended position without fuss. I scrounged the IPs from a Tornado IDS and the console panels from the GR4 kit: Then it was time to install the air intakes, without gluing the front to the fuselage: Now, the intake ramps. On the left, how they should be for a Tornado sitting on the ground. On the right, how they are in the box. You have to remove the protruding bit. Shaun, thanks for the tip. The intake fronts are assembled and glued to the nose walls. The nose walls are dryfitted to the fuselage: The importance of not gluing the intake block front to the fuselage is there: now, you have some leeway to adjust everything. I don't remember who wrote about that here, and I'm sorry, but whoever you are, thanks a lot. To be continued. 9 Link to post Share on other sites
Marlin 2,592 Posted January 6, 2016 Share Posted January 6, 2016 Looks great so far Sebastien. I built a MFG1 Tornado awhile back using Hahen decals. Just be very careful putting the walkways on. I've never seen thinner decals before in my life. Good luck with the rest of your bulid. /Bosse 1 Link to post Share on other sites
SimonT 906 Posted January 6, 2016 Share Posted January 6, 2016 Excellent stuff, I have this kit so will enjoy watching you put it together! 1 Link to post Share on other sites
Sebastien 1,045 Posted January 8, 2016 Author Share Posted January 8, 2016 (edited) We're getting close to the mildly irritating bits, so... This bar will make the wing pivots align simultaneously with the airflow. As I'm a very serious modeler and I never will go around in my room with a model in my hand playing with the VG wing and making jet noises (especially if there are potential witnesses in a 2.73 mile radius), why is that important? Well, it'll help aligning the pylons in the position you choose. If you don't wident the holes a wee bit, friction will be such as nothing will ever move again, so I widened them holes with my trusty though dirty scalpel blade. The wings are glued in place with a smaller sweep than intended by Revell. That means I threw away the T-shaped part that goes over the wing pivots. It was the time I chose to install the intake ceiling/backbone part, and it was the time the kit was waiting for to bite me in the nether regions. I glued from port to starboard. Everything was OK-ish on the port side, but I had to remove plastic from the outer edge of the starboard intake ceiling for the part to go approximatively where I wanted it to go. So now it's Milliput time to correct the various trouble spots. More to come soon. Hoping you enjoy the build, S. Edited January 8, 2016 by Sebastien 2 Link to post Share on other sites
Uncle Tadhg 85 Posted January 8, 2016 Share Posted January 8, 2016 Great stuff! I have this kit and desperately want to pylons to swivel, the child inside me wants an in-flight Tornado with all that working. I'm currently trying to fabricate such a mechanism on a 1/72 Revell Tornado as well as an F-111 in the same scale but I have yet to succeed... 1 Link to post Share on other sites
Shaun 629 Posted January 8, 2016 Share Posted January 8, 2016 Looking good, but a bit late for some of my tips to help your build? I build the complete rear fuselage then add the nose section. http://www.britmodeller.com/forums/index.php?/topic/234993866-148th-tornado-gr1in-flight/ Shaun. 1 Link to post Share on other sites
Sebastien 1,045 Posted January 8, 2016 Author Share Posted January 8, 2016 Damn, I missed that one. I'll use this tip for my next Tornadoes. Thanks, S. 1 Link to post Share on other sites
Shaun 629 Posted January 8, 2016 Share Posted January 8, 2016 Damn, I missed that one. I'll use this tip for my next Tornadoes. Thanks, S. I think its a kit you learn something new every time you build another one? Shaun. 2 Link to post Share on other sites
Sebastien 1,045 Posted January 8, 2016 Author Share Posted January 8, 2016 I think its a kit you learn something new every time you build another one? Shaun. Something like that, yeah. S. Link to post Share on other sites
Sebastien 1,045 Posted January 11, 2016 Author Share Posted January 11, 2016 And I was indeed punished for not reading Shaun's excellent post regarding how to properly build a Revell Tornado: So, if I understood correctly what has be written here, the black line reprensents the correct radome rear end: So let's putty the radome joint: And after some filing, sanding, cursing, and various stuff ending with "ing": And now, with its glorious fin, and the wrong ECM suite cause the GR1/GR4 boxing only has the Brit ECM that I neglected to use on my previous GR1 build: To be continued... Link to post Share on other sites
Shaun 629 Posted January 11, 2016 Share Posted January 11, 2016 Looks like your having fun with the filler? Its might be too late,but do you want the fin ECM bar from my kit, I can pop it in the same packet as the seals? Shaun. 1 Link to post Share on other sites
Sebastien 1,045 Posted January 11, 2016 Author Share Posted January 11, 2016 Looks like your having fun with the filler? Its might be too late,but do you want the fin ECM bar from my kit, I can pop it in the same packet as the seals? Shaun. Filler is fun! And if you don't mind, thanks. Cheers, Sebastien 2 Link to post Share on other sites
Shaun 629 Posted January 11, 2016 Share Posted January 11, 2016 No problem glad to help. Shaun. 1 Link to post Share on other sites
Sebastien 1,045 Posted January 17, 2016 Author Share Posted January 17, 2016 Some Xtracolor RAL7012 and 7035 later (man these paints STINK!): The radome is painted (BTW, never ever use Gunze Mr Color lacquers on Xtracolor paint, don't ask). And the walkways decals are on: Now, the stencils (yay). Cheers, Sebastien 3 Link to post Share on other sites
Janremco 679 Posted January 18, 2016 Share Posted January 18, 2016 Looking great with the paint on. Jan Remco 1 Link to post Share on other sites
Col. 12,040 Posted January 18, 2016 Share Posted January 18, 2016 (edited) Good work there Sebastian. Only found this thread now so been enjoying your progress from the first post. Edited January 18, 2016 by Col. 1 Link to post Share on other sites
Sebastien 1,045 Posted January 19, 2016 Author Share Posted January 19, 2016 Looks great so far Sebastien. I built a MFG1 Tornado awhile back using Hahen decals. Just be very careful putting the walkways on. I've never seen thinner decals before in my life. Good luck with the rest of your bulid. /Bosse Hi Bosse, I've started stenciling the Tornado, and Hahen decals are not that thin. In fact, they even remind me of a Jethro Tull song. Cheers, S. 1 Link to post Share on other sites
At Sea 2,994 Posted January 19, 2016 Share Posted January 19, 2016 Very nice! 1 Link to post Share on other sites
Sebastien 1,045 Posted January 19, 2016 Author Share Posted January 19, 2016 Very nice! Yes, Thick As A Brick is really an excellent album... Thanks, S. 1 Link to post Share on other sites
Uncle Tadhg 85 Posted January 20, 2016 Share Posted January 20, 2016 A Marineflieger Tornado AND Jethro Tull? This just gets better. 1 Link to post Share on other sites
Sebastien 1,045 Posted January 21, 2016 Author Share Posted January 21, 2016 A Marineflieger Tornado AND Jethro Tull? This just gets better. I have interesting perversions. S. 1 Link to post Share on other sites
Sebastien 1,045 Posted January 24, 2016 Author Share Posted January 24, 2016 (edited) One side of the fuselage is decalled. I used HaHen decals, and I can't say I'm quite satisfied with them. I strongly dislike the whole sheet being covered in decal film, it makes stencilling even more a pain in the subequatorial regions it normally is. Then, there's the thickness of the decals themselves. It might be my sample, I don' know, but once they're set, you can feel them quite easily by running your fingerip on the model. And forget about decal setting solutions (BTW, anybody here know about something stronger than Daco strong that doesn't involve C4?). The flaps are glued on. On step 45 of the assembly, swap parts 106 and 108, or the assembly won't go that well... Now, on with the stencilling Cheers, Sebastien Edited January 24, 2016 by Sebastien Link to post Share on other sites
Marlin 2,592 Posted January 24, 2016 Share Posted January 24, 2016 Looking great Sebastien. My decal sheet was the other way around. I didn't use any decal solution at all. Guess the clearfilm varies in thickness. /Bosse Link to post Share on other sites
