HP Halifax BIII wings
thepureness
Looking really for a Halifax specialist here
I've got the latest Revell Halifax B III kit in 1/72 scale and something doesn't quite seem right with the wings, I am under the impression the Halfiax B III had clipped wings, like below in the Airfix painting diagram
http://www.model-making.eu/zdjecia/7/5/1/7286_rs_2_AFX06008A_4.jpg
But Revell show the longer wings for the same mark of aircraft
http://www.model-making.eu/zdjecia/2/0/1/9811_2_rev04936_7.jpg
This has me a little confused, i'm doing some research online, but if someone knows the answer here then great
You're right to some extent, B.III's originally had the square tipped wings but later in their production they changed over to the longer spanned, round wing tips.
This is Graham Boak's area of special interest, I'm sure he'll be along to clarify in a bit.
Wez
Wez has the answer for you. Original production was with the existing short-span wings and the various manufacturers introduced the longer span wing in later production, the first being in autumn 1943, with considerable overlap of both types in production even from the same manufacturer it seems.
A couple of points: not autumn 1943 as this preceded the entry into service. Perhaps autumn 1944? Merrick does have a photo of round wingtips on "Oscar" HX318, lost April 1944, which is an argument for an earlier introduction, but I think this is actually a later "Oscar". (The argument was made on an earlier Halifax thread, excuse me for not digging it out.) I don't know of any retrofits, but these can't have been common as postwar photos do show the square tips on aircraft - not that many Mk.IIIs lasted long postwar anyway.
Memory is slipping a cog here, but isn't one of the Revell examples actually a Mk.VI? If so, you'll need to swap one exhaust around to the other side of the nacelle.
Hello Graham, apparently not though. According to Ken Merrick (p110-111 of his 2009 book) the first Mk IIIs were issued to squadrons in November 1943 (some of the movement cards indicate October delivery to the initial recipients), which is correct because the first write off in squadron service happened that month on 466 Sq) and the extended wingtips entered the production line at Handley Page at around the same time.
However, this comment by Merrick is based upon his identifying of the aircraft on P116 as HX318, which was indeed an early Mk.III built late in 1943. However, as I wrote above, I don't believe that he has correctly identified the individual airframe and that this photo should be dated considerably later. The unit (424 Sq.) had the habit of retaining the aircraft names, which were linked to the individual aircraft identity letter, So there was more than one Oscar, and the number of missions shown on P116 is considerably greater than can have been flown by HX318, as shown by checking the missions flown by 424 Sq. in Middleton's Bomber Command War Diaries. (I also believe that a close study of the photo will show a serial beginning in L, but I haven't got my magnifying glass handy - and perhaps it was another printing of the photo anyway?)
Edited by Graham Boak
I wouldn't argue with your conclusion regarding HX318 Graham, that apparent misinformation is shared with Clarence Simonsen's nose art book. I must confess, I had always been under the impression that the extended wingtips came towards the end of the Mk III production, most definitive pictures appear to be dated from September 1944 onwards or show backgrounds consistent with winter or autumn. Victor Bingham's book is also non committal about dates. It would be interesting to know the number of the modification and its introduction and also the dates of the Boscombe Down tests. The confounding factors of course include that it is difficult to know if an aircraft has been retrofitted or not as some, e.g. LV920, which entered squadron service in March '44, might have them in a picture that is most probably autumn 1944. Also, the overwhelming number of 1944 dated photos have original wing tips so the introduction would have had to be very gradual.
This would seem to be a question for some further archival research to be certain, but yes, it would seem that the earliest positively dated photos are around September 1944 in squadron service.
Thinking in terms of production, I don't go with it being very gradual. Once the jigs have been set up to make the new wingtips then they'd have been put into use. The new tips would have replaced the earlier design in a fairly rapid change-over, on any particular production line. Yes, there may be the odd few "out of sequence" at the time of the change-over, but not a lot. There could then be delays as the other companies come into line, depending perhaps on just how their stocks of the old wingtips remained.
I don't have a date for their introduction - and I still don't know of evidence for retrofitting - but agree that photo evidence suggests widespread service not much sooner than summer 1944. One strong hint I can find is that the first B Mk.VII was delivered 16th June 1944. So if HP built any Mk.IIIs with the bigger tips, they must have been before this. We do have LV776 and LV838 from the last B Mk.III run built as Mk.VIs with the first flying 28.2.44., so it could be that the new tips were generally introduced that early - or these could simply have been hand-built examples for trials. It is always possible that a short batch was hand-built preceding the production jigs, and these ended up on the odd Mk.III ahead of the main batch ... but this is just guessing.
This is great info gentlemen.
Question if I may please regards these wings.
If I have the Revell kit with the longer, rounded wingtip wings, but need to build it with the earlier square tips, is it just a matter of removing plastic to achieve the correct profile, or are other changes required?
PR
Do you have a plan of the shape you want? Offhand, I'd say yes do just that, but then I am currently trimming a set of Mustang tailplanes down to replace a missing Ar.96 tailplane. The only problem I'd foresee is the precise shape of the light housings at the leading and trailing edges. This may need a little attention - hence the need for a plan (or an earlier Halifax kit part).
But on the other hand, why bother? The relevant short-wing parts are available on the runners for the Mk.III kit - look for parts 144-150
