Julien Posted January 2, 2016 Share Posted January 2, 2016 Fw 190A-8 Update sets 1:72 Eduard Brassin Eduard's latest profipack and Royal Class boxings of their 1/72 Fw 190A-8 are excellent in their own right, however if the modeller really wants to up the ante then the following sets are available.Fw 190A8 EngineThis set contains a complete resin engine for the Fw 190, along with the exhausts, engine bearers and cowlings. There are also photo-etch parts for the engine. The engine is a complete model in its own right. Engine Fw 190A8 Engine & Fuselage GunsThis set contains all the engine parts (and PE) in the above set, and also includes details for the fuselage guns, and their compartment. Additional PE is provided for the guns in this set. Engine & Fuselage Guns Fw 190A PropellerThis set consists of resin parts to replace the kit prop. There is a central control hub to which the three separate blades must be attached. In order to get this right a jig is provided. A new resin hub is provided as is the fan which site behind the prop. All together this set should provide a boost to the sharp end of your 190. Propeller Conclusion Given this is 1/72 scale the quality of the casting is first rate. Which ever set, or sets you use should enhance your model, particularly if doing any kind of diorama. Highly recommended.Review samples courtesy of Link to comment Share on other sites More sharing options...
