Borez 714 Posted January 26, 2016 Author Share Posted January 26, 2016 Nice work Borez, she is becoming very alluring sir. Hey, nice A/B mate, I have just got one myself (although SWMBO will use as well) Sometimes it takes a while to get use to the airbrush. I am using the .4 mm nozzle and needle, larger than the last A/b? I was using a .3 mm. Found I had to back the flow down to half what I normally used. Simon. Thanks Simon. I tried the .4mm this afternoon, it kicks out paint like a mule, even at 10psi. Had to do the same as you and back it right off. I primed with the .2mm without an issue. Loving this airbrush though, its so much nicer to use than the splatter stick 1 Link to post Share on other sites
Spookytooth 11,209 Posted January 26, 2016 Share Posted January 26, 2016 Thanks Simon. I tried the .4mm this afternoon, it kicks out paint like a mule, even at 10psi. Had to do the same as you and back it right off. I primed with the .2mm without an issue. Loving this airbrush though, its so much nicer to use than the splatter stick Yes mate , she is a bit of a beast to tame. As for the .2 mm nozzle and primer, it depends what primer you are using? Alcad 2 primer / micro filler is a bit dense for it, but lacquers go well. Simon. Link to post Share on other sites
Borez 714 Posted January 26, 2016 Author Share Posted January 26, 2016 Yes mate , she is a bit of a beast to tame. As for the .2 mm nozzle and primer, it depends what primer you are using? Alcad 2 primer / micro filler is a bit dense for it, but lacquers go well. Simon. I'll bear that in mind thanks. I got the 2 in 1 so I had a choice for primers. Just out of interest do you also own the H&S nozzle cleaner, is it worth the money? Link to post Share on other sites
Spookytooth 11,209 Posted January 26, 2016 Share Posted January 26, 2016 I'll bear that in mind thanks. I got the 2 in 1 so I had a choice for primers. Just out of interest do you also own the H&S nozzle cleaner, is it worth the money? No mate, I just got the A/B from Modelling tools site. Just the A/B plus larger cup, needle and nozzle. With being able to unscrew the cup when cleaning, it makes the whole job a lot easier. The nozzle assembly can be place in most thinners/cleaners. The seals are designed for that type of use, but I would not go to overboard though. I use IPA for acrylics, and cellulose for enamels/lacquers etc. I like to blow her through with some clean IPA after the cellulose though. I hope that is any use to you mate. Simon. 1 Link to post Share on other sites
Borez 714 Posted January 26, 2016 Author Share Posted January 26, 2016 No mate, I just got the A/B from Modelling tools site. Just the A/B plus larger cup, needle and nozzle. With being able to unscrew the cup when cleaning, it makes the whole job a lot easier. The nozzle assembly can be place in most thinners/cleaners. The seals are designed for that type of use, but I would not go to overboard though. I use IPA for acrylics, and cellulose for enamels/lacquers etc. I like to blow her through with some clean IPA after the cellulose though. I hope that is any use to you mate. Simon. That's basically what I'm already doing thanks apart from using Zero cleaner with the 2k. Link to post Share on other sites
keefr22 13,431 Posted January 26, 2016 Share Posted January 26, 2016 I've got a couple of those cr*p £20 things that got thrown into a drawer in the same sort of frustration you were feeling. Why on earth am I keeping the things, they're hardly likely to come in useful for anything...?! Looking forward to seeing the shell when it comes out from under cover. The GT40 is looking nice and smooth too! Keith Link to post Share on other sites
Borez 714 Posted January 26, 2016 Author Share Posted January 26, 2016 I've got a couple of those cr*p £20 things that got thrown into a drawer in the same sort of frustration you were feeling. Why on earth am I keeping the things, they're hardly likely to come in useful for anything...?! Looking forward to seeing the shell when it comes out from under cover. The GT40 is looking nice and smooth too! Keith Classic case of buy cheap, buy twice Keith. The one upside is that I now know what the major airbrush issues are and how to bloody solve them. 2 Link to post Share on other sites
imster 358 Posted January 27, 2016 Share Posted January 27, 2016 You've done the right thing Borez! Always a good idea to buy a cheapie so you can learn and make mistakes with the AB maintenance. The last thing you want to do is ruin an expensive airbrush due to lack of experience with maintenance. 1 Link to post Share on other sites
Borez 714 Posted January 27, 2016 Author Share Posted January 27, 2016 (edited) 2K done and I've dropped over the bodywork loosely to have a look. I must admit one thing I've really learnt here is to keep the model completely under cover when painting as a lot of dust has got into the paint for sure. It really shows once you 2K. Oh well, lesson learnt. And that's what this build was for. I must admit I've learnt a ton of stuff from this. And then some. So.. some pics. Sorry about the dodgy camera phone pics. I will break out the tripod and decent camera at some point to get some less grainy shots but this is more convenient as they upload straight to Google pics. Rear with engine cowl on. No spoiler attached yet and nothing really lined up. And with the cowl off More detailed look: Top view Side profile with cowl And naked Further out And a couple more random shots And so onto the last mile, the spoiler fitting, the body placement proper, the windscreen and side windows, getting the door on? Various detailing, the lights, the camera, the action, the stardom. And then the chequered flag. Thanks for looking. Edited January 27, 2016 by Borez 1 Link to post Share on other sites
Spookytooth 11,209 Posted January 27, 2016 Share Posted January 27, 2016 Looks fast Borez. Putting a cover over the freshly sprayed bits does stop a lot of dust spoiling the finish. Especially if you have spent hours preparing them first, I found out the hard way LOL. Still she is looking great . Simon. 1 Link to post Share on other sites
Borez 714 Posted January 27, 2016 Author Share Posted January 27, 2016 (edited) Looks fast Borez. Putting a cover over the freshly sprayed bits does stop a lot of dust spoiling the finish. Especially if you have spent hours preparing them first, I found out the hard way LOL. Still she is looking great . Simon. Indeed, lesson definitely learnt. Especially as this loft is quite dusty too. Building the Gulf GT40 MK11 and it's been permanently under cover as I've airbrushed it. Edited January 27, 2016 by Borez Link to post Share on other sites
Spookytooth 11,209 Posted January 27, 2016 Share Posted January 27, 2016 Looking forward to seeing the Gulf GT 40 MK 11 mate Simon. Link to post Share on other sites
keefr22 13,431 Posted January 27, 2016 Share Posted January 27, 2016 Looks good from here! 1 Link to post Share on other sites
Borez 714 Posted January 27, 2016 Author Share Posted January 27, 2016 Looking forward to seeing the Gulf GT 40 MK 11 mate Simon. The GT40 is a lot simpler build, there's no real engine detailing per se with this kit. It's all about how well I can paint it. 1 Link to post Share on other sites
Borez 714 Posted January 28, 2016 Author Share Posted January 28, 2016 (edited) So, last night I drilled and pinned my cutout door. Worked out quite nicely. A lot easier than I had anticipated. Also got the spoiler on and made some antenna by cutting up sewing pins and epoxying them in. Door paint needs a little touch up, mirrors need fixing in, bodywork needs attaching proper and I lost the damn window vent after it escaped the tweezers and shot out somewhere never to be found again. But all good really. Edited January 28, 2016 by Borez 3 Link to post Share on other sites
macgregor 252 Posted January 28, 2016 Share Posted January 28, 2016 Looking great & I'm sure many lessons being learned along the way. Well done. Mac 1 Link to post Share on other sites
Borez 714 Posted January 28, 2016 Author Share Posted January 28, 2016 Looking great & I'm sure many lessons being learned along the way. Well done. Mac Thanks Mac, appreciated. Link to post Share on other sites
Borez 714 Posted January 30, 2016 Author Share Posted January 30, 2016 Well she's nearly finished albeit a couple of adjustments. I'll break out the decent camera and do some proper shots over the weekend as these camera phone shots are pretty grainy and horrible. Been an interesting build, for sure. 5 Link to post Share on other sites
pau10wen 564 Posted May 11, 2018 Share Posted May 11, 2018 fantastic build! Really enjoyed looking through the build diary! Picked up the carbon decal tip too, thanks! Link to post Share on other sites
Borez 714 Posted May 11, 2018 Author Share Posted May 11, 2018 8 minutes ago, pau10wen said: fantastic build! Really enjoyed looking through the build diary! Picked up the carbon decal tip too, thanks! Thanks Paul, it was one of my first builds.   Link to post Share on other sites
pau10wen 564 Posted May 11, 2018 Share Posted May 11, 2018 Even better in that case, Very impressive mate! 1 Link to post Share on other sites
Borez 714 Posted May 11, 2018 Author Share Posted May 11, 2018 1 minute ago, pau10wen said: Even better in that case, Very impressive mate! Sadly I used photobucket to host my later builds so the pictures are now all gone Link to post Share on other sites
pau10wen 564 Posted May 11, 2018 Share Posted May 11, 2018 I've tried to upload some images from my current build (lancia stratos 1977 monte carlo rally) but quickly realised that I couldn't directly upload from my PC. How are you hosting your images currently if you don't mind me asking? Â I've got options like dropbox at hand, but wondered if you had any recommendations? Apart from photobucket obvs! Gutted for you to hear that bad news Link to post Share on other sites
PC2012 542 Posted May 11, 2018 Share Posted May 11, 2018 Borez, didn't to see you back!!!! Link to post Share on other sites
