At Sea Posted December 5, 2015 Share Posted December 5, 2015 I always finish my models in Klear for decalling and then seal the decals in Klear, this however leaves them looking a little 'shiny' which is letting down the overall quality of the work. I tried to use aerosol Humbrol Matt and Satin varnishes from a rattle can but these have left what can only be described as a sparkly finish. Luckily I tried this out on a 'victim' and not on a work in progress. My airbrushing skills are coming on but I am much happier with aerosols, especially for large areas. What do you guys use? Have I missed something with these aerosols? Link to comment Share on other sites More sharing options...
iainpeden Posted December 5, 2015 Share Posted December 5, 2015 I am experimenting with a mix of Klear and tamiya flat clear at the moment. Approx 4:1 mixed in a plastic top gave a dull satin effect on a Mustang I have just finished. Brushed on and done for fun not a competition standard. The mix went on consistenly and dried quickly. 1 Link to comment Share on other sites More sharing options...
dubster72 Posted December 5, 2015 Share Posted December 5, 2015 I use Humbrol Matt Coat, applied by airbrush. The important thing with all matting products is to mix them thoroughly - and I do mean THOROUGHLY!! Otherwise the matting agent (talc, mica etc) doesn't mix with the carrier liquid & leaves visible bits. These might account for your sparkly finish. Cheers Patrick 1 Link to comment Share on other sites More sharing options...
Knight_Flyer Posted December 5, 2015 Share Posted December 5, 2015 I have tried both Humbrol and Tamiya rattle cans. From my experience and using the same technique for both brands the Tamiya usually gives a noticeably better result. However, mixing matt and satin varnishes thoroughly is good advice because of the matting agent. 1 Link to comment Share on other sites More sharing options...
At Sea Posted December 5, 2015 Author Share Posted December 5, 2015 Thanks, I'll try some of the suggested tips, especially the Tamiya Flat Clear & Klear mix through my spray gun. As for mixing I not only keep my aerosols in the house to keep 'em warm but also rattle them for about 5 mins in any case, but agree the matting agent is almost certainly at fault. Link to comment Share on other sites More sharing options...
Jusjay Posted December 5, 2015 Share Posted December 5, 2015 (edited) I use humbrol satin cote and haven't had any problems. I did put a ball bearing in to help when mixing up and think it's helped tbh. Edit - should have added I use this thinned and airbrushed and had no issues. Edited December 5, 2015 by Jusjay 1 Link to comment Share on other sites More sharing options...
Max Headroom Posted December 5, 2015 Share Posted December 5, 2015 I've discovered Humbrol rattle cans and I like the results. It would eliminate your mixing problems I did this Spitfire for the BoB group build and was very pleased with the result. Trevor Link to comment Share on other sites More sharing options...
At Sea Posted December 5, 2015 Author Share Posted December 5, 2015 Humbrol rattle cans were the problem originally. :-) Link to comment Share on other sites More sharing options...
LaurieS Posted December 5, 2015 Share Posted December 5, 2015 I use Vallejo varnishes for matt finishes. It is remarkable as it produces a much more matt finish than their matt paint. The varnishes are produced in acrylic resin plus polyurethane. The polyurethane take longer to cure but is a lot hardier. I stick with the acrylic as it produces such a matt finish. For gloss for decals etc I stick with Humbrol Clear which I have found to be an excellent product. For me I use an airbrush as you have perfect control especially on hard to get to parts and were you want to control the thickness. Laurie 1 Link to comment Share on other sites More sharing options...
