Kinetic is to release a new (revised?) boxing from it's Fighting Falcon, the 1/48th Lockheed-Martin F-16A/B Fighting Falcon RoCAF 70th Tiger Wing (Hualien AB) - ref.48055
Source: https://www.facebook.com/Kineticmodel/photos/a.150625411771245.1073741825.129238860576567/529182953915487/?type=3&theater
Box art + decals
12348078_529182953915487_371751061869007
12342598_10156309856885052_6958582802335
12308330_10156309856845052_9221665999390
http://www.luckymodel.com/scale.aspx?item_no=KI-K48055
Or repackaging of ref.48011 with new decals?
V.P.
Edited by Homebee
I've always had a soft spot for the Hualien wing with it Aboriginal Sun on the tailplane.
The first Kinetic release is already in my stash, where this new one might join up, due mainly to the beautiful decal sheet.
But let's see what hasegawa will offer.
Might get both, then!
Well whatever else about the Kinetic kit with its slightly incorrect shape, that's certainly a very impressive decal sheet - is that what will be in the box?
IIRC the first corrected nose kit was the F-16I Sufa, all after that should be the newer nose.
Paul Harrison
Wasn't the nose problem solved
I'm almost certain it wasn't. They fudged it a bit to try to make it a little less visible, but it's not *fixed*.
  • 4 weeks later...
Is it possible to build a Norwegian F-16BM MLU of this kit?
Anyone knows?
if you have decals, it should be possible! the "bird slicers" IFF in front of the canopy are included, that is the main external feature of a current MLU...
others may know more (I am not sure about the undercarriage, Taiwan could use a stronger/ thicker version as they are later build machines )
Edited by exdraken
Kinetic should lay off the artist who produced the boxart though; compare the colour of the two warning triangles on the forward fuselage to the Hasegawa boxtop photo :D
Impressive decalsheet!
Edited by Pollie
  • 3 weeks later...
