Witold Jaworski Posted May 20, 2018 Author Share Posted May 20, 2018 Azgaron, NickD - thank you for following! Today I will deal with the complexity of the cylinder head fins: _________________________________________________________________________________ The fins of the air-cooled cylinder heads are a state-of-art piece of metallurgy: At the first glance, it is hard to believe that they were cast as a single piece. But when you look closer, you will discover that these fins “grow up” from the solid parts of the head as naturally, as the hair from the head: Try to imagine the shape of molds used in the production of these parts, and the challenges faced by their manufactures! (See an interesting post about this. It describes production of the R-1830 Twin Wasp cylinders). Basically, modern producers of the heads for the air-cooled aircraft engines use the same technology as eighty years ago. In my model I will recreate these fins in a somewhat simplified form, as a few separate Blender objects. I will also skip some fine details of their shape (for example the small features that I marked in the figure above). Such a simplification conforms the moderate level of details that I assumed for this model. It is always possible to make a more detailed version of this object later. I began by forming the “external boundary surface” of the fins. After revising many photos I decided that it has a circular base. This base is combined with a shape extruded from a perpendicular arc: The rocker covers, formed in the previous post, helped me in estimating the shape of this object. In general, the cylinder head fins are not symmetric, since the exhaust valve produces much more heat than the intake valve. Thus there are more fins around this area. Initially I formed the basic shape, leaving gaps around the rocker covers (as in figure above). In the next step I filled these gaps (figure "a", below): In fact, it was sometimes quite hard task that required careful analyzing the shape of the head fins in these areas. Note that fragments of the rocker pushrods were partially “sunken” in this object (as in figure "b", above). I cut out the areas around these pushrods using the Boolean (Difference) function. To do it, I placed along the rockers two simple “boxes” (figure "a", below). Then I used them as the “tools” in a Boolean modifier that cuts out from the boundary shape the difference of their volumes (figure "b", below): (Note that I rounded the original sharp edge of the “cutting box” using a multi-segment Bevel modifier). Then I “fixed” (applied) results of the Boolean modifier. After removing unnecessary vertices and edges from this area, I obtained the shape shown in figure "c", above. Finally I dynamically rounded the external edges of this cut out, using a multi-segment Bevel (Weight) modifier. In similar way I created the hollows for the spark plugs. First I created two objects that have the shape of these cutouts. (As you can see in figure "a", below, their shape was more complex than the pushrod “boxes”): I used these two objects in a Boolean modifier, which I applied to the boundary shape object. Figure "b", above, shows how this mesh looks like after “fixing” the results of this modifier. I also dynamically smoothed the resulting mesh using a moderate (level =1) Subdivision Surface modifier. Finally, when the boundary shape was formed, I started to add the head fins. In the simplest case the mesh of a single fin can be just a single square face (figure "a", below): Then I obtained the results shown in figure "b" (above) in a dynamic way, by adding to the fins object a stack of three modifiers: Boolean (Intersect) modifier, which uses the boundary object as the “cutting” tool; Solidify modifier, which gives the fins their thickness; Bevel (Angle) modifier, just to “round” the external edges of the resulting fins; As you can see above, their cumulative effect is quite interesting. All what I have to do now is to add to this “fins” object subsequent faces. The “L”-shaped upper fins have somewhat more complex topology: It is built from a dozen of elementary square faces. I crated the rounded edge in the middle of this fin by adding another multi-level Bevel modifier to the top of the modifier stack. It rounds selected edges – those, where I set the so-called Bevel Weight coefficient to a nonzero value. Sometimes the results generated by the Boolean and Solidify modifiers look strange. To fix these problems I had to be careful with the normal direction of the newly created mesh faces. Sometimes I even had to add an additional edge loop – because it alters the results of the tessellation that Blender performs for each face. The R-1820 cylinder head also contains some “M” – shaped fins (as in figure "a", below): I built such elements using an outer “U”-shaped surface combined with the inner, flat face (figure "b", above). The faces of the “U”-shaped surface have their normals directed outside, so the Solidify modifier generates the thick “walls” around it. The two edges at the “bottom” of this “U” are rounded (figure "b", above), as in the case of the “L”- shaped fin. The inner surface extends a little (by less than the fin thickness) outside the original faces of “U”-shaped surface. After applying the modifiers, this “overflow” creates an impression that both surfaces are joined. As you can see in figure "a", below, the final mesh of the head fins resembles somewhat a Minecraft object: However, when you switch into the Object Mode, in a split second the modifiers transform it into the desired shape (figure "b", above). Do not be mistaken by this “smooth” workflow description. In practice I often had to make minor adjustments to the boundary surface mesh, to correct some unexpected effects of the Boolean modifier. Fortunately, the mesh of each fin is disconnected from the others, so all these issues appeared gradually, and I was able to resolve them in a systematic way. I had also made other adjustments: for example, in the middle of the work I discovered that the spacing between the fins was 0.215” instead of 0.220”. (I know that this distance seems extremely small, but for the 30 fins in a row, it really makes a difference!). Thus I shifted - vertically or horizontally - about two dozen fins. Fortunately, the Boolean modifier took care for the resulting adjustments in their shapes. What’s more, it occurred that these dense, evenly spaced fins act as a kind of additional reference grid. While forming them, I found and corrected some inaccuracies between the fins and the valve and rocker covers. Quote For example: while forming these fins, I adjusted at least four times the angle, location and shape of the intake valve. And after each of these modifications, I had to fit anew the intake pipe. That’s why I prefer to keep such complex elements as this cylinder head split into various simpler objects as long as possible: you never know, when you have to modify them again! You can check details of these fins in this source *.blend file. The model starts to resemble the real cylinder, but it still lacks many details. I will describe them in the next post. 6 Link to comment Share on other sites More sharing options...
Witold Jaworski Posted June 6, 2018 Author Share Posted June 6, 2018 In this post I will finish the first cylinder of the R-1820 “Cyclone”. It will be the “template” object, which I will clone eight times around the crankcase when I finish the other parts of this engine. Although in my previous post the cylinder head received the full set of its cooling fins, it still lacks some details. One of them are the reinforcements of the valve covers: As you can see, these reinforcements break the symmetry of the left and right valve covers. Both of them resemble a thick plate, but one is oblique, while the other is vertical. They are not the most prominent features of this cylinder head, and it took me some hours to determine their probable shape. Finally I classified them as the secondary features of the covers, which I have to recreate, for the assumed level of details. First I formed the oblique reinforcement of the intake valve cover. I extruded it from the existing mesh: When you compare this mesh (in Figure "a", above) with the last picture in my last-previous post (its Figure 85‑11), you will clearly see that I had to remake this shape again. (I was wrong, then). At this moment I declined to create the last “block” that closes the array of the vertical fins at this cover (Figure "b", above), because it would be too difficult to merge such a feature within the current mesh. I will come back to this issue later in this post. In the case of the vertical reinforcement of the exhaust valve, I encountered similar problem: it would be quite difficult to extrude such a shape from the existing mesh. However, this time I decided to make it as a separate object: The next element that I recreated is the top cover of the rocker (Figure "b", below): After some initial trails, I decided that the previous, simplified version of this element that I made some weeks ago is useless. (You can still see it in Figure "b", below). Thus I started a new top cover from the scratch. I formed it using the same reference drawings that I used for the main rocker covers (Figure "a", above). The fillets of this shape (I marked them in yellow) are created using a multi-segment Bevel modifier. However I had some troubles with the radius of the upper fillet (Figure "c", above). It occurred that the Bevel modifier can alter the fillet radius along the rounded edge. What’s worse, I could not obtain the larger radius at the higher corner of this cover, because their proportions and sizes were restricted by the height of the cover shorter side (Figure "c", above). Well, the difference was not so big, thus I accepted it. In the next step I prepared four conical shapes in the places where this cover had recesses around the bolts (Figure "a", below): In the “old” object, still located on the top of the rocker cover, I also created a perpendicular “T-beam” (Figure "b", above). I formed it there, because I needed to use the outer, circular contour of this engine as the reference. It was just prepared for later. Then I started to create the recesses around the bolts. After applying each of the Boolean modifiers I had to “clean” this mesh by removing the extra vertices and edges (Figure "a", below): Then I spent significant amount of time on improving the shape of the fillets around these recesses (initially they were in a really bad shape). Basically, I had to disperse the fan-like edges from the forward recess along the mesh, and add some new “middle” edges (Figure "b", above). Finally, I placed this rocker top cover on the cylinder head and joined it with the “T-beam” object that I had prepared some steps before. Note that I left these two meshes disconnected – it looks quite good as it is (especially in black – see figure below). Joining faces of this “T-beam” and the rest of this cover would require significant amount of work. Quote These top rocker covers are examples of the parts that do not seem difficult at the beginning. Then, after many hours spent on their vertices and edges you are discovering their true nature . In this case I lost most of the time on fixing the various issues along the rounded edges of the bolt recesses. If I had to make this cover again, I would sculpt these fillets manually, then eventually smoothed them using a Subdivision Surface modifier. Comparing to these top covers, the details of the cylinder barrel were easy. In the real R-1820 its fins were made separately, from steel rings. I created them from a quarter of such a ring: I just used a Mirror modifier (along X and Y axis) to convert this mesh into a full ring, then multiplied it down along the barrel using an Array modifier. Finally I added the Solidify modifier, which gave these plates some thickness. I also used a large-radius multi-segment Bevel modifier to profile the cylinder base (as in figure above). Finally I added the first bolts to this engine. Each of these objects is a clone of the same mesh. Initially I prepared two such meshes: the classic nut for the rocker top covers, and the massive head for the bolts around the cylinder base (Figure "a", below): I also recreated recesses in the cylinder base around these bolts. I made it using an auxiliary object and a Boolean (difference) modifier (Figure "b", above). (In fact, to make the edges of these recesses more regular, I had to alter a little some faces of these auxiliary objects). The last element of the cylinder was its upper deflector. Basically, this is just a piece of the sheet metal, “wrapped” around the cylinder head: Although most of this deflector surface lies in the “invisible” back area of this engine, I decided to recreate it as a whole – just for the eventual future use. (In fact, the most difficult part was to determine the approximate shape of this part). It was made from a single smoothed (by the Subdivision modifier) mesh surface. The vertical reinforcements on its sides are created as separate objects, also made from a single surface. Additional Solidify modifier gives them a non-zero thickness. Because this is the “invisible” zone of my model, I did not recreate such minor details as the bolts and rivets, here. In general, this deflector was the last part of the cylinder. However, you never know when you find something new and will have to modify your model. I finished this cylinder about two months ago, and then worked on the other parts of this engine. (Yes, my reports are always a few weeks late). After a month I finally decided to recreate the closing block of the fin array at the intake cover (marked in red in Figure "a", below). This time I made it as a separate object, to avoid tedious work of rounding all of the eventual intersection edges. I also looked for more reference pictures. One day in May I found additional detailed photos of the R-1820 cylinder head in a certain e-bay auction. When I compared them to my model, I discovered that my cylinder is missing one fin at the intake cover: (There were three such fins in the photo, while my model had only two). The new photos quickly revealed my error: I have to shift the forward faces of nearly all existing vertical fins to the right! (To the next fin). Quote In this and next paragraphs I use the “left” and “right” directions as you can see them in figure above. The intake valve is on the left, while the exhaust valve is on the right side. Such a movement of the 26 fins will create space for additional “shorter” fin on the left and discard one fin on the right. It also will shift the central segment of these fins that contains the hollow for the forward spark plug. Fortunately, the structure of my model allows me to do such a modification in a relative easy way. (That’s why I hold myself in duplicating this cylinder to the latest stage of this project, and using in every of its objects as many modifiers as possible). I have introduced all these updates to the latest version of this R-1820 model, thus you will not find them in the example file that accompanies this post. (They will appear in the file that accompanies one of the future posts). How I did it? First, I modified the shape of the “fin boundary” object, which I use to the Boolean modifier to “cut” the fins (Figure "a", below): Then I shifted the “raw” faces of the fin mesh to the right by one “fin module” (0.215”). When I did it, I started switching these shifted faces to the adjacent fins (Figure "b", above). Finally I dropped the rightmost fin and added one fin segment on the left. Figure "a", below, shows my results, while Figure "b", below, is the picture of an authentic R-1820 head: The most obvious difference is the certain “angularity” of my model: it lacks many of the soft fillets and intermediate surfaces that you can see in the original head. This is the price for the relative simplicity and moderate polygon count. (The final model of this engine will have about 500 thousand faces). Making a more detailed version of this head would require much more time, and (at least) four times more faces in the final model. However, I can also see various minor differences in the area around the exhaust (I marked it in figure above using a dashed line). It seems that I should shift the exhaust base to the rear, because you can see it on the photo, while it is hidden under the fins in my model. This is strange because I read the precise location of the exhaust opening from the explicit dimensions on the original installation drawings. I have also found another minor difference between this photo and the original Curtiss-Wright drawing. Thinking about it, I realized that I am using reference drawings from 1942, while the head in this photo comes from a B-17G (according the e-bay auction). This means, that it was produced no earlier than in 1944. It may happen that I found minor differences between various R-1820 production series. All in all, they appear on the rear part of the engine, which will be invisible in my model. Thus I decided to continue without fixing these findings. Figure below shows the current state of the cylinder model: You can examine my model in this source *.blend file. Just remember that this is the earlier version, saved in March (before I shifted the forward fins). In the next post I describe my work on the crankcase details. After this I will recreate the spark plugs, ignition harness and the side deflectors (between the cylinders). 6 Link to comment Share on other sites More sharing options...
NickD Posted June 6, 2018 Share Posted June 6, 2018 Hi Witold, Managed to miss your previous post. As usual very impressive. When I have tried to do flanges in the past it has been very labour intensive. After you last post I wondered if modifiers would work. It is great to have a masterclass demonstration of exactly how to do this. Key points for me were: The Bevel modifier. For some reason I have not really mastered it - need to try harder clearly. Boolean, solidify and arrays I have used extensively. Though with issues around crashing my computer. My Core Duo Acer laptop struggles a bit. Bolts - how do you do positioning around arbitrary normals. Is there a trick or just a lot of patience. Discipline - set up a process and run it consistently I have wondered in the past about using Boolean to generate Female moulds from the model. As I said my computer struggles but see no reason why one couldn't. Of course it would just be easier to 3D print one and then cast from that. Thanks again for sharing Nick 1 Link to comment Share on other sites More sharing options...
Mike Posted June 6, 2018 Share Posted June 6, 2018 Mind boggled! Awsesome work, and very thoughtful of you to assist others by explaining your process 1 Link to comment Share on other sites More sharing options...
Witold Jaworski Posted July 13, 2018 Author Share Posted July 13, 2018 (edited) NickD, Mike - thank you for following this thread! On 6/6/2018 at 9:53 PM, NickD said: (...) Bolts - how do you do positioning around arbitrary normals. Is there a trick or just a lot of patience. (...) In fact position and direction of each bolt is usually aligned to at least one of the object they are attached. Thus all what I have to do is to set up position and direction the first clone. To set up the bolt in an arbitrary position, I place the 3D cursor in the target point, and from the [Snap] menu (Shift-S) invoke the "Selection to cursor" command. Then I just have to make two or three rotations, and voila - the first bolt is in place. In the next step I duplicate it into new set of the bolts, which I move into new positions along their local axes. During last months I started to think about writing script that aligns selected objects to the active one (it would speed up this process even more). Maybe I will wrote such a little, useful thing. (Of course, I will also publish it on my web page). Edited July 13, 2018 by Witold Jaworski 1 Link to comment Share on other sites More sharing options...
Witold Jaworski Posted July 13, 2018 Author Share Posted July 13, 2018 In my previous posts (published in May and June) I focused on the R-1820 cylinder. I think that it is the most difficult part of every air-cooled engine. Since that time I have made a significant progress, which I will report during nearest three weeks. Let’s start with the rear section of the crankcase (behind the cylinders). Do you know how difficult is to find a decent photo of this area? The original pictures from the “Cyclone” manual are of moderate quality: The modern photo (Figure "b", above) reveals more details. In general, it looks that the rear part of the crankcase is formed from two cylindrical segments. The intake pipes extend from the first (i.e. forward) of these segments. (There is a centrifugal supercharger inside). The upper part of the last segment contains rectangular air scoop, which also provides the mounting points for the carburetor (Figure "b", above). The rear wall of this segment forms the base for various auxiliary aggregates: magnetos, oil pump, starter, etc. As you can see in Figure "b" (above), aggregates from the R-1820 exposed in the Pima Air Museum differ from the manual photo (Figure "a", above). I think that such equipment could be used in the B-17s. On this photo I also finally determined an important feature of the R-1820 geometry: its mounting points. (They are dimensioned on the installation drawings, but I had to find them among all these nuts and bolts that you can see on the crankcase). I think that this rear part of this engine is much more complex than the forward section. Fortunately, it is invisible in my model (I am not going to open the engine cowling panels, at least not at this stage of the project). Thus I recreated them just as placeholder “blocks” (see figure below). In this simplified form they will allow me to determine the details of the SBD engine cowling geometry: Once I saw these details on the photos, I was able to properly interpret the original installation drawings from the Curtiss-Wright manual. I recreated in the simplified form the intake pipe base (Figure "a", above). I will repeat these blocks for every cylinder. (I built this crankcase section from nine identical parts). Note the hole for the mounting bolt on the left side of the intake pipe. I just placed it there as a reminder for myself. The last crankcase section is created as a single (mirrored) part (Figure "b", above). I placed the simplified magnetos and oil pump on its rear wall. In the next step I recreated there the details of the pushrod bases in the front of each cylinder: The rim of the forward crankcase is usually obscured by the ignition harness. I managed to find some photos that show this part. They reveal that there is a cylindrical “strip” around this rim (Figure "a", above), which forms the base for the pushrods. The outer diameter of this “strip” matches the rim diameter of the crankcase main section (the section that forms the cylinder bases). It is larger than the diameter of the conical part of the forward crankcase. The forward edge of this strip has characteristic “stair” shape (Figure "a", above). This shape repeats in the front of each cylinder. Every “step” of these “stairs” matches the base plate of one of the pushrods, or forms a bolt head base. As I described it in the first posts about the R-1820, I formed this forward section of the crankcase using nine identical segments (clones), placed in the front of each cylinder. Thus I just had to recreate this strip in the mesh of a single segment, and Blender automatically repeated it around the crankcase rim (Figure "b", above). In this mesh, I used a multi-segment Bevel (Weight) modifier to round some of the newly created edges. (I have some troubles with the intersecting beveled edges, here. Finally I decided to use the Bevel modifier for the “meridian” edges, only. I created the gentler, “parallel” fillets manually, placing 3 or 4 new edges at the rim strip base). When I reproduced the “stair” forward edge of the pushrod bases, I discovered that: For each cylinder, one of the pushrods is shifted forward. (This is a norm for every classic radial engine, because each of these two pushrods follows different cam. One of them uses the intake valve cam, while the other uses the exhaust valve cam); The pushrod bases were closer to each other than they depicted them in the original installation drawings from the Curtiss-Wright manual. (It could happen, because this was not any important, “dimensioned” element of these drawings); I moved accordingly the pushrod bases close to each other, and then I discovered that they no longer fit their troughs in the cylinder head (Figure "a", below): Fortunately, the shape of the head fins is still controlled by the surface object (via a Boolean modifier). All what I had to do was a minor adjustment of its mesh (Figure 88‑4b). Then Blender took care for the fin shapes (Figure "c", above). As you can see (Figure "b", "c", above), I also added to this model the pushrod seals and clamps. All of these details are clones (they share single mesh). These clamps will be useful in other places of this engine. Another engine element hides among the lower cylinders (5 and 6): this is the oil slump: While the forward part of the oil slump appears on many photos (as in Figure "a", above), all what I found about its overall shape were: two pictures from the manual (Figure "b", above), and the side contour on one of the blueprints. However, certain features became obvious, when you place this part into the model. The recesses on its sides fit the adjacent cylinders (Figure "c", above), while the Y-shaped “tail” bypasses the vertical intake pipe that belongs to cylinder 5. I formed oil slump using subdivision surfaces. To keep the shape of the front crankcase as simple as possible, I modeled the oil slum base as a separate object. Its external edges blend smoothly with the two adjacent crankcase segments. (These segments are separated along the engine centerline). On the forward part of the oil slump you can see a prominent engine data plate. I will recreate this detail later, together with similar elements that occur in the cockpit. (They will require a separate texture). On the opposite side of the crankcase there is a more exposed feature: propeller governor base: In general, its shape is a combination of symmetric cylinder and dome with an asymmetric “wedge” (Figure "b", "d", above). To find the proper proportions of these objects, first I prepared their simplified, conceptual model (the red blocks in Figure "c", "d", above). The most “sensitive” elements here are their intersection edges, especially on the oblique, left side of the “wedge”. I tried to obtain similar shapes of these curves to those visible on the photos. (However, in the real crankcase these edges are “soften” by the fillets. It is more difficult to determine their exact shape). Finally, when the conceptual model was close enough to the original, I used it as the base for the final version: First I joined the “cylinder” and “wedge” into single object, and added fillets (multi-segment Bevel modifier) along their intersection edges (Figure "a", above). Then I joined the three upper segments of the forward crankcase with this propeller governor base (Figure "b", above). It created additional intersection edges, which I also rounded using the same Bevel (Weight) modifier. Note that I did not “smooth” this surface with a Subdivision Surface modifier: it was dense enough without it. Quote There was also another reason: the optimal mesh topology for the beveled edges differs from the optimal topology for the subdivision surface. For the fillets created by the multi-segment Bevel modifier, the beveled edge has to be far away from the other parallel edges. To obtain similar effect using the Subdivision Surface modifier, you have to concentrate several parallel edges close to each other. Sometimes I use a mix of these two modifiers (Bevel + Subdivision Surface). However, for the more complex shapes, like this one, this combination can create certain artifacts by its own. The next element of the engine is the ignition harness. Figure below shows its rear part: In fact, this part will be invisible in the final Dauntless model. I recreated it because I just do not like to “suspend objects in the air”. Still, while fitting this engine into the airplane, the simplified versions of these invisible parts can give you a valuable hint about potential collision/intersection. The harness in the engine from the Jimmy Doolittle Air & Space Museum (Figure "a", above) seems to be rotated upward on the magnetos. I recreated in the reversed position (Figure "b", above), as in the manual (see the first photo in this post). Quote Note the carburetor details in Figure "a", above. The complexity of their shapes exceeds by a magnitude the rest of this engine. I am really glad that they are hidden under the cowling, so I do not have to recreate this “mess” of intersecting blocks and pipes, all smoothed with hundreds of fillets. (I think, that it reminds the densely packed Maya sculptures, or some instances of the modern art 😉). The manifold of the harness is a simple tube, bent along the curve that controls its shape. (I used here the Curve Deform modifier). The forward part forms a 300⁰ arc around the crankcase: I already placed along this manifold the bases for 18 individual spark plug cables (Figure "b", above). At this moment I recreated the first pair of these cables, for the topmost cylinder. Each of these two tubes has its own deforming curve. As you can see (Figure "c", above), I also recreated the spark plugs and the clamps that attach these cables to the pushrods. I will recreate the remaining 16 cables in the next post, when all of their cylinders will be in place. (Each of these cables will be bent along a slightly different shape). There are also four mounting brackets (Figure "d", above) that attach the ignition harness manifold to the crankcase. I also recreated the deflector plates, mounted between the cylinders: I decided to skip (simplify) some of their features that will be less visible under the NACA cowling. Thus I omitted the bolt holes at the cylinder sides, and various small holes in some of these plates. (The purpose of the two holes visible - in Figure "a", above - will become obvious in the next post). Figure below shows the current state of this R-1820 model: I will finish it in the next post. You can examine the model depicted above in this source *.blend file. Just remember that this is the earlier version, saved in May (before the correction of the the forward fins, which I described in my previous post). 6 Link to comment Share on other sites More sharing options...
Witold Jaworski Posted July 20, 2018 Author Share Posted July 20, 2018 (edited) In this post I will finish all the remaining details on the front of the R-1820 engine. (As I mentioned in earlier posts, this model is intended for the outdoor scenes, with closed cowlings. That’s why I recreated the more complex rear part in a simplified form, just to check if it fits properly to the airframe). One of the most exposed “Cyclone” details is the variable-pitch propeller governor: This is an additional unit that controls the pitch of the Hamilton-Standard propeller. (It controls the oil pressure, which determines the actual pitch of the propeller blades). You can find it in every aircraft, but it is often dismounted from the “standalone” engines, presented in the museums. The large wheel at its top is used as an actuator attachment. The actuator can be a pushrod or a cable from the cockpit. In the case of the SBD (and many other WWII aircraft) it was a control cable (Figure “b”, above). The engine depicted in Figure “a”, above is a standalone museum exposition, thus it lacks such a cable. Analyzing the photos, I slowly recognized that this governor was mounted differently in various Dauntless versions. In the later SBDs (SBD-5, -6) it is placed in the front of the topmost cylinder, and its actuator wheel is on the left side (as in Figure “a”, above). In the earlier versions (SBD-1, -2, -3, -4) it is mounted between cylinder 1 and 2 (as in Figure “b”, above). Let’s focus on the later versions first, because I have more its photos. I could even find the propeller governor base on one of the original installation drawings (Figure “a”, below): This drawing shows, that the governor was rotated by 18⁰. The reason for this unusual arrangement became obvious when I fit into the model the first, simplified version of this object. This rotation directs the control cables between cylinders 1 and 2 (Figure “b”, above). Do you remember the two small holes in the deflector depicted on the second-last photo from the previous post? They were made just for this cable. However, I could not determine the ultimate shape of the governor unit. Most of the photos that I had looked like those that I show in the first picture of this post. They were taken at unusual angles, or the object was in black, which obscured its details. I was only able to determine, that there are several versions of this part, which differ in important features (for example, they have different number of outlets). It seems that this is a third-party component, delivered by independent vendors. In desperation, I looked for it on the e-bay, where I ultimately found a decent photos: The version on the pictures above was widely used in the aircraft from the post-war period. It has two additional outlets, which did not exist in the propeller governors used during WWII (at least not on the photos that I have). Anyway, it still resembles the governors that you can find on the historical pictures. Using it, I was able to build a more detailed model: First I recreated the governor shape using a group of simple “blocks”: cylinders and boxes with cylindrical sections. Then I adjusted their proportions and positions, so that they resemble the original object. Finally I started to join these objects (using Boolean (Union) operator), and rounding their intersection edges using a multi-segment Bevel (Weight) modifier (Figure "a", above). I set up a large “nominal” radius of this Bevel modifier (1.3”). Then I controlled the radii of individual fillets by assigned fractional bevel weights to their intersection edges. Quote I practiced that you can set these fractional values in the Mean Bevel Weight field of the Edge Data section, at the top of the View>Properties region. (The region at the right edge of the 3D View window that Blender shows/hides when you press the [N] key). You can see the final result in Figure “b”, above. Note that I had to check the control cable clearance behind the deflector (it has to pass by the intake pipe of the cylinder 2 – as in Figure “c”, above). However, the fillets in Blender are far from the ideal: I gave up with the edge of the rear outlet (Figure “d”, above). To not spoil the previously rounded edges, I had to leave this cylinder as a separate object, just attached to the main body by the “parent” relation. (Fortunately, this is a less visible detail). Quote To round this edge, I should sculpt it in a mesh that is “dense” enough (i.e. has enough faces in this area). Such a labor-intensive solution does not match the level of detail assumed for this model. The next detail is the elevated edge around the valve timing inspection hole. You can see it on the front crankcase section (Figure “a”, below): As usual, I started with a simplified, conceptual object (Figure “b”, above). It allowed me to adjust the proportions and size of this feature, as well as the mesh topology. Then I joined it with the corresponding crankcase segment, and rounded the newly created intersection edge with a multi-segment Bevel (Weight) modifier (Figure “c”, above). You can see the final result in (Figure “d”, above). Finally, it is time to populate this engine with all nine cylinders. I delayed this operation to the end, because I was going to duplicate these objects as the clones (i.e. new objects that share the same mesh). After such a multiplication, if I discovered that these cylinders lack a certain detail, I would have to copy it nine times. That’s why it was better to wait with such a multiplication until it seemed that none of such modifications is needed. However, in May I received an invaluable suggestion from Jeff (pzzs7f, in this post) that I should try the so-called group instances. I did it in following way: First I placed all the cylinder elements on layers 13, 14, 15, then declared them as an object group (Figure “a”, above). (I did it using the Object>Group>Create New Group command. Blender highlights the objects that belong to the same group with a green outline, which you can see on this picture). I named this group G.G05.Cylinder. Note that it also contains the crankcase segments located around the cylinder (elements from layer 11). Beware that Blender assumes the center point ([0, 0, 0] in the global coordinate system) is the eventual origin point of an object group. Thus place your source objects accordingly in the space around this point. When this “group definition” was ready, I turned its source layers off, set the 3D cursor to the engine center point, and in the top view I inserted the first instance of this group (Add>Group Instance). You can see it in Figure “b”, above. (Accidentally, it is located in the same place in the space as the source objects, but you could insert it anywhere). When you examine this cylinder, you will discover that this is an Empty object, which contains reference to the G.G05.Cylinder object group. To “populate” this engine, just create clones of this first instance, and rotate them around the center point by 40⁰, 80⁰, 120⁰, and further angles. You are placing in this way the subsequent cylinders in their locations (and rebuilding the mid- and rear-crankcase, as well). Figure “c”, above, shows how it looks like. Note that I have placed all these cylinder instances on a different layer: 3. Such instances of an object group are a great tool in dealing with repeatable machine parts. When you add an additional object to this group, it immediately appears in all cylinders. When you remove an object from this group – it disappears from all instances (although it still exists on one of the source layers). This means that I could use these instances earlier, without worrying about adding the remaining details! Well, in my next model I will recreate the cylinders at least in the middle of the project. It is always better to see the whole engine. What’s more, Blender optimizes the way it displays and renders such instances: note that its Faces/Verts/Tris counters do not take into account their meshes! Figure “a”, below, shows all nine cylinders in place. Note, that each of them contains also the spark plugs. After this “multiplication”, I carefully examined each of these group instances, looking for eventual intersections with other objects: As you can see in Figures “b”, “c”, above, there are just few of such collisions, caused by the clamps on the pushrod seals. I have tried to rotate these clamps, hoping to find a universal “neutral” position that does not collide with anything. Finally I gave up: I excluded clamps from the object group and copied their clones around the engine. Then I could rotate each of them separately around the pushrod, fixing every collision that I had found. I also recreated the side deflector as another instance group: I named this group G.G10.Deflector. Its source objects are located on layer 16, while the group instances – on layer 6. At this moment all the deflectors are identical (for example, they were mounted in this way in the “Cyclones” used in the B-17s). For such an effect I could simply add the side deflector into the cylinder group (as I did for the cylinder top deflector). However, in the SBDs there were two gun troughs in the cowling, on both sides of the topmost cylinder. Thus I decided to define this deflector as another group, because in the future I will have to replace the two topmost deflector instances with modified clones. For the same reasons I “extracted” the side beam from the rocker cover into a separate object (Figure “b”, above). Looking at Figure “a”, above, you can find some additional parts: a few dozens of new bolts, as well as the scavenge oil pipe. (This pipe connects the bottom of the oil slump with the pump in the rear). Finally I added the last remaining detail: spark plug cables: As you can see, the cables occur in pairs. In each pair there is a longer and a shorter cable. The longer one connects the rear spark plug (Figure “c”, above). (I know that this is the “invisible” area, but I could not resist the temptation to recreate this detail). The shorter one connects the front spark plug (Figure “b”, above). All cables of the same length (short or long) and their terminating nuts share the same mesh (they are clones). However, each of them has its own shape, because their Curve Deform modifiers refer to their individual curves (Figure “b”, above). I copied these curves around the crankcase, and then introduced minor modifications to their shapes. Also the clamps that attach these cables to the pushrods are individual clones. I introduced some random variations to these shaping curves and the positions of the cable clamps that attaches them to the pushrods. In this way they resemble the original, manually connected cables. The only missing element in this model are the engine data plates. I will recreate them later, together with the cockpit details. (They require a dedicated, high-resolution texture). The engine seems to be complete. (Of course, for the assumed level of details: the rear crankcase sections and their equipment are recreated in the form of simplified blocks). I will fit it into the cowling, then cut out the deflectors below the gun troughs. I zoomed the data plate on one of my reference photos, and found that this is the R-1820-60 (the version used in the SBD-5: 1200hp for takeoff). All the manuals and blueprints that I have collected describe this or one of the later “Cyclone” versions. Thus I can conclude that the R-1820-66 (the version used in the SBD-6: 1350hp for takeoff) seems to be identical (at least as viewed from the front). I also expected just minor differences between this one and the earlier R-1820 versions, used in the SBD-1, -2, -3, -4. The first difference that I have found was in the propeller governor positions (at the beginning of this article). Then I started to analyze the other older photos: I quickly found another one: in the R-1820-52 the ignition manifold forms a full circle, while in the R-1820-60 it is a 300⁰, “U-shaped” arc). I decided to look closer at the differences between the R-1820-52 and -60. I will report my findings in the next post. You can download the model presented in this post (as in second-last figure in this post) from this source *.blend file. It is available under CC-BY license and can be useful for other aircraft, for example the B-17 or the F4F-4. Edited July 20, 2018 by Witold Jaworski 4 Link to comment Share on other sites More sharing options...
Witold Jaworski Posted July 29, 2018 Author Share Posted July 29, 2018 (edited) I decided to write a post about the first decade of the R-1820 “Cyclone” development (up to the R-1820-60 version, i.e. 1940). This engine was used in many designs from 1930s, and you can find the references to its various models in many technical specifications. However, sometimes it is difficult to determine how such a referenced version looked like! The early models of the “Cyclone” were produced in small batches, so there is less historical photos. Sometimes even the specialists from the museums are misguided: in one of them, you can find a SBD-3 fitted with the engine and the propeller from the SBD-5. My query, which resulted in this article, started with comparison of the R-1820-60 (used in the SBD-5) and the R-1820-52 (used in the SBD-3 and -4). I have found so many differences, that I started to wonder about the engine used in the pre-war SBD-1 and SBD-2. (They used the earlier “Cyclone” version: R-1820-32). The results presented below may be interesting to the modelers who recreate aircraft from this period (for example – the Curtiss “Hawk” biplanes, or the Grumman F3F-2 “Flying Barrel”). Let’s start from the beginning: below you can see the first model of the R-1820 family, designed in 1931: Frankly speaking, there is only a general resemblance to the later “Cyclone” versions. Note the small crankcase front section and the “archaic” cylinder heads. (They have different shape, and their fins are much shorter and widely spaced: these are indicators of a simpler casting technology). Another strange feature is the exhaust, which could be also mounted in the reversed (i.e. forward) direction. (Some of the aircraft from this era used front exhaust collectors). This engine used large spark plugs, mounted horizontally (in parallel to the centerline). It was rated at 575hp on takeoff, and used in some contemporary designs, like the Curtiss “Hawk” biplane. Before introducing the next “Cyclone” version, let’s try to decode its symbol. It seems that there are two parallel conventions: one used by the engine vendor (Wright Aeronautical), and another used by the US Air Corps and the Navy. Wright designated this engine as R-1820E. The “R” stands for “radial”, “1820” is the displacement (in cubic inch), and the “E” denotes the model. There were also other, 7-cylinder “Cyclones” produced by Wright during 1920s, as well as smaller 9-cylinder “Cyclone” (R-1750) produced before 1931. About 100 of these “Cyclones” were sold for the Navy flying boats. Technically, this “E” model, featuring 1820 in3, was an advancement. For the US military purposes, there was a similar convention, in which this engine was referred as the R-1820-1. The “R” stands for “radial”, “1820” is the displacement (in cubic inch), and the “-1” is the sequential version number. (I suppose, that this “sequential” suffix applies to the purchasing chronology, not to the engine development). Wright offered simultaneously two variants of the same engine: direct drive and geared. (“Direct drive” means that there was no reduction gear). The “geared” models had the “G” prefix: for example GR-1820E. According the “military” convention, each of these “parallel” versions could have a different sequential number (depending on the date of the first purchase?). The next development stage was the R-1820F. It featured larger cylinder heads (because of the deeper and closer cooling fins), simple supercharger, forged (and then machined) main crankcase, and many other important improvements. It was difficult to find a decent photos of this model. Finally I identified one (military designation: R-1820-19) in National Museum of the USAF. It was mounted in the only preserved Martin B-10: This particular airplane was built in 1938 for Argentina, as the export model Martin 139W. (In 1970 this only survived B-10 in the world was given to the US as a donation from the Government of Argentina. It was later restored by the National Museum of the United States Air Force). It seems that Martin used in this aircraft the R-1820-19 engines (rated at 665hp). It was the same “Cyclone” model as in the original US Army versions (YB-10 and B-10, delivered in 1934). Looking for the decent photos of the “F” model, I finally found a few pictures of the Soviet M-25 engine. (In 1933 the Soviet Union bought a license for one of the R-1820F variants. First Soviet “Cyclones” were built in 1934 from kits delivered by Wright Aeronautical. After conversion to the metric system, from 1935 they were produced in thousands by a dedicated factory in Perm). Below you can see photos of this engine: Wright licensed to the USSR the direct drive version named R-1820F3. Quote The last digit in this symbol (“3”) could indicate the blower (i.e. supercharger) gear ratio. Wright offered several variants of this engine, optimized for various flight altitudes. Each of these variants had different supercharger gear ratio. The suffix “2” means ratio of 7:1, “3” – 8.31:1, “4” – 10:1, “6” – 8.83:1. Similar engine was used in the DC-1, but its symbol had an additional “SG” prefix: SGR-1820F3. This “S” probably stands for an external supercharger, and “G” for the reduction gear. The direct drive versions of the “Cyclone” had much shorter crankcase front section than the geared models (compare the figure above and the B-10 picture). Their oil slump also lacked the “L”-shaped forward pipe. (I suppose that it was not needed in the much shorter crankcase, without the reduction gear inside). The deflectors, attached to the cylinder heads on the photo above, have circular shape. (They differ from the rectangular deflectors mounted in R-1820-19. I will come back to this issue in a moment, discussing the “G” model). It seems that they removed corresponding side deflectors from this museum exhibit. On the crankcase front section there is a small base for the governor of a variable-pitch propeller. The rocker covers differ from the “E” model, and Wright engineers added small attachment points at their ends. (These points were useful for mounting the large NACA cowlings). Note that most of the cooling fins concentrate around the exhaust valve. There are only few of them around the intake valve. The “F” model of the “Cyclone” was a commercial success, powering many aircraft in the first half of the 1930s (for example – the Douglas DC-2 airliner). The later versions of this engine had two-digit numerical suffixes, like “F52” or “F62”. (It seems that these middle “5” or “6” indicate an improved version). They were rated at about 745 – 785hp. The GR-1820-F52 reached 890hp for takeoff, but it was the upper limit of this design. (The F52 model had the lowest blower ratio: 7:1, and it was rated at 725hp at sea level and 775hp at 5800 ft. The next “Cyclone” model was the R-1820G. It had larger cylinder heads than the “F” version (as explained in this article, to get higher power from a cylinder, you need the larger area of its cooling fins). I have found some detailed pictures of an early, direct-drive “G” versions in the F3F-2s restored at Chino Planes of Fame. Comparing to the original photos, it seems that this is not the R-1820G5 (R-1820-22), but another “Cyclone” version. However, it seems to be nearly identical with the original engine: It is not clearly visible on these photos, but the intake duct in the heads is set at about 45⁰ to the centerline, as in the blueprints of my R-1820-60 version. (In the “E” and “F” models it was parallel to the centerline, as the exhaust duct). The intake valve is finally covered by short fins. The spark plugs are thinner, and placed in a less asymmetric way than in the “F” model (in fact, this head looks similar to the version that I recreated in the previous post). The top rocker covers received the new shape and four bolts around their rims. On the left photo you can see the attachment points on the rocker covers, introduced in the “F” version (they are more visible here than on the previous picture). The higher pressure produced in the combustion chambers of this engine increased the number of attaching bolts to 16 per cylinder (there were 12 in the “E” and “F” versions). On the left photo you can see the details of the “rectangular” deflectors. Note their elastic tips – I think that this brown material is the rubber (or leather?). The original R-1820-22 (GR-1820G5) engine, used in the F3F-2, was rated at 950hp for takeoff. (The same engine was used in the F2A-1 Buffalo, and the export version of this fighter, Brewster 239, delivered to Finland). Figure below shows the later, geared version of the “Cyclone” (it was rated at 930hp at 2200 rpm for takeoff): Note that its front crankcase section is larger than in the geared “F” model (compare it with the B-10 picture). Wright referred to these more powerful series as “Cyclone” GR-1820-G100. I studied many historical pictures of these “G” engines. It seems that in certain versions Wright placed the ignition harness in the front of the valve pushrods, while in the other versions - behind these pushrods. The semi-circular deflectors occur together with the latter variant of the ignition harness. In such a configuration every second cable goes between the cylinders to the rear spark plugs. The “rectangular” deflectors usually occurs in the engines withe ignition harness placed in the front of the pushrods: In such a configuration the cables go to the rear spark plug around the cylinder head (and across its deflector – as you can see in figure above). The picture above shows the later “Cyclone” G100 model, most probably one of the R-1820-5x series (I am not able to precisely determine this version). It is nearly identical with the R-1820-52 (used in the SBD-3 and -4). This photo also show us detailed fragment of the angular main crankcase section. (It was built from two symmetric, forged and machined aluminum parts). Similar crankcases appear in the “F” family. In this later model the base for the propeller governor was even more elevated than in the R-1820-45 (compare this photo with the previous illustration). I do not think that the engine from figure above uses a different version of the deflectors. I rather suppose that this particular museum exhibit uses their standard “rectangular” model with the flexible tips removed. I have just a few pictures of the engines used in the earlier Dauntless versions (SBD-1 … -4). Below you can see two of them (unfortunately, both are in low resolution): The engine depicted in figure “a”, above belongs to a restored SBD-1 (BuNo 1612). (When you can see the original wreck, you can be at least sure that this is the original piece). The engine in figure “b”, above, was attached to the SBD-4, restored in Chino. It seems that there are no external differences between these two engines (at least as viewed from the front). The “-32” is missing the ignition harness, but you can see in the attached miniature that the restored version of this harness is identical to the “-52” on the right. Both engines have the standard, “rectangular” deflectors with flexible tips. Note how Douglass engineers make use of these auxiliary attachment points on the valve covers (figure “b”, above). The cowling flaps bow was supported by the rear row of these points, while the supports of the NACA cowling use the forward attachments. Quote Why the R-1820-45 differs a little from the R-1820-52, while the R-1820-32 seems to be identical? There are two possibilities: 1. the military symbols do not correspond to the development chronology; 2. Wright run in parallel several development lines of this engine; Both engines – R-1820-32 and R-1820-52 – were rated at 1000hp for takeoff. I have no information if there were any differences in their blower or gear ratio. The most powerful “Cyclones” G were rated at 1200hp for takeoff (the geared R-1820G5E). The next “Cyclone” generation was a result of significant reengineering. Wright referred them as the GR-1820-G200 series (or, skipping the “G” suffix, as the R-1820-G200, because there were no direct drive versions in this family). It seems that the first of these models had military symbol R-1820-56. One of them is the R-1820-60 (the version that I already have recreated) and the R-1820-66 (version used in the SBD-6, presented in figure below): Frankly speaking, Wright has redesigned most of this engine, so it is easier to point out the elements that did not change between the G100 and G200 series: spark plugs and propeller governor (these two items were delivered by the third party vendors). While preserving the overall dimensions and mounting points, all of their external details are different. In the G200 the enlarged front section of the crankcase housed even bigger reduction gear and more efficient auxiliary shafts for the propeller governor. The pushrods became slightly shorter, thanks to the enlarged diameter of the front crankshaft. The cylinder heads grew bigger, because of the longer fins. (It was another increase of the cooling area - thus the shape of these heads is slightly different than in the G100 series). The deflectors are all-metal, without the flexible tips, and have different mounts among the cylinders. The cylinders are prepared for the high-octane fuel which means higher pressures, thus their bases feature 20 bolts (instead of 16 bolts in the G100 series). What is not visible on this photo, the main crankshaft section (under the cylinders) is a steel cast of gently curved shape. In this engine you can see different auxiliary attachment points: double bolts on each intake rocker cover (the exhaust rocker covers have none). (This “bolted” mount already appeared in the late G100s models, but not in the engines used in the SBD-1 …-4). The R-1820-60 was rated at 1200hp for takeoff. It was also used in the B-17C, D, E, and F. The R-1820-66 was rated ever higher: at 1350hp for takeoff. (Similar R-1820 version was used in the B-17G). Finally, to increase the overall confusion (hopefully of the Axis spies 😉), at the beginning of 1940s Wright Aeronautical altered its naming convention. Since this time: The R-1820G and GR-1820G series are referred as “Cyclone” 9GA (shortcut: C9GA); The R-1820-G100 series are referred as “Cyclone” 9GB (shortcut: C9GB); The R-1820-G200 series are referred as “Cyclone” 9GC (shortcut: C9GC); Thus you can find in various source documents and the books three different symbols for the same engine. For example – the full title of my Wright service manual from 1943 is: “Overhaul Manual/Wright Aircraft Engines Cyclone 9 GC”. This means that it applies to the R-1820-G200 series. In particular, this group includes the models named in the U.S. Army and Navy documents as the R-1820-60 and the R-1820-66. Well, all in all this means that I have to recreate another engine: R-1820-52 (late G100 series) for my earlier Dauntless models: SBD-1, SBD-2, SBD-3 and SBD-4. There are too many differences to adapt the R-1820-60 model that I have already created. I describe shortly this “subproject” in the two next posts. Bibliography: “Parts Catalog for Wright Cyclone Aircraft Engines Series GR-1820G-200”. Wright Aeronautical Corporation, 1940; “Wright Cyclone 9 Aircraft Engine, series C9-GC: Installation, Operation, and Service Maintenance”. Wright Aeronautical Corporation, 1942; “Overhaul Manual Wright Aircraft Engines Cyclone 9 GC”, Third Edition. Wright Aeronautical Corporation, 1943; “Operation and Service Manual: Wright Cyclone 9 Aircraft Engines Series C9GA, C9GB, C9GC”, First Edition. Wright Aeronautical Corporation, 1943; Francis H. Dean “America’s Hundred Thousand: The US Production Fighter Aircraft of World War II”, Schiffer Publishing, 1997 (ISBN: 0-7643-0072-5); Francis H. Dean, Dan Hagedron “Curtiss Fighter Aircraft – a Photographic History 1917-1948”, Schiffer Publishing, 2007 (ISBN: 978-0-7643-2580-9); Wawrzyniec Markowski “Boeing B-17 Flying Fortress”, parts 1 and 2, AJ-Press 2004, (ISBNs: 83-7237-143-1 and 83-7237-152-0); Barret Tillman “The Dauntless Dive Bomber of World War Two”, Naval Institute Press, 2006 (ISBN: 1-59114-867-7); Bert Kinzey “SBD Dauntless”, Detail & Scale, 2016 (ISBN: 978-0-9860677-5-4) Robert Pęczkowski “Douglas SBD Dauntless”, Stratus, 2007, (ISBN: 978-8389450-39-5); Kimble D. McCutcheon “Wright R-1820 ‘Cyclone’”. Aircraft Engine Historical Society, www.enginehistory.org, 1999, revised: 2014; Поршневой авиационный двигатель М-25 (Wright «Cyclone» R-1820 F3) (in Russian). Accessed 2018-07-10; The Wright R-1820 “Cyclone” Engine. Acessed 2018-07-02; Martin B-10. Accessed 2018-07-12; Photo collections of: National Museum of the USAF, Riverside; Muzey V. P. Chkalova (Музей В.П.Чкалова), Chkalovsk; Planes of Fame, Chino; National Naval Aviation Museum, Pensacola; Yanks Air Museum, Chino; Jimmy Doolittle Air & Space Museum, Travis AFB; “Life” magazine Edited July 29, 2018 by Witold Jaworski 4 Link to comment Share on other sites More sharing options...
hendie Posted July 29, 2018 Share Posted July 29, 2018 fascinating 1 Link to comment Share on other sites More sharing options...
NickD Posted July 30, 2018 Share Posted July 30, 2018 Mind-blowing - I thought I was good at this stuff. Not even close. Thanks again for sharing. I have seen the height of the hill in front of me. Nick 1 Link to comment Share on other sites More sharing options...
Witold Jaworski Posted August 17, 2018 Author Share Posted August 17, 2018 (edited) hendie, NickD, thank you for watching this thread! ___________________________________________________________________ Following the conclusion from my previous post, I have to recreate yet another “Cyclone” version: the R-1820-52, used in the SBD-3 and SBD-4. Fortunately, the R-1820-32, used in the SBD-1 and SBD-2, seems to be identical (at least – as viewed from the front), thus I do not need to recreate this “Cyclone” variant. I will describe the modeling process of the R-1820-52 in the “fast forward” mode, compressing the whole thing to two posts: this and the next one. Initially I identified just two differences: the shape of the front crankcase section and the different ignition harness. I assumed that I will be able to reuse most of the R-1820-60 components. I had discovered most of the issues described in my previous post while working on this R-1820-52 version. In fact, it occurs that such an attempt to create a 3D model of such an engine is like an scientific experiment: it verifies the initial hypothesis and reveals the new facts that otherwise would be overlooked. I started by renaming in the source Blender file the scene that contains the previously finished engine as “R-1820-60” (the “military” symbol of an engine belonging to the “Cyclone” G200 family). Then I created a new scene, named “R-1820-52” (the G100 family). This is my new “working place”. I copied there (precisely speaking: “linked”) some of the “R-1820-60” parts that were common for the G100 and G200 family. In this “*-52” version I followed the same “building path” which I used for the previous one. So I began with the crankcase and the basic cylinder elements: I assumed that all the key dimensions and bases are identical in both versions, just the details are different. This assumption allowed me to determine the shape of the forged, “angular” main section of the G100 engine crankcase using just a few photos of its fragment (as in Figure “a”, above). (This element is quite obscured on all the photos that I had). The nine side faces of this section had to fit the corresponding cylinder bases. The adjacent, oblique faces between the cylinders had to fit the space between cylinder bases and the front / rear plane of this central crankcase section. However, while fitting the crankcase and the cylinders, I also had found that the 16-bolt cylinder base used in the R-1820-52 had a longer straight side segment (Figure “b”, above) than the 20-bolt base used in the R-1820-60. Because most of the cylinder parts were assigned to the E.100.Cylinder Base object (the “bare” cylinder), I decided to split it into the upper and lower part. The mesh of the upper part is assigned to this original E.100.Cylinder Base object, and used in both engine versions (Blender scenes). Each of these engines has its own lower part of the cylinder (marked in red in Figure “b”, above). The 20-bolt version is used in the “R-1820-60” scene and named G.100.Cylinder Base, while the 16-bolt version is used in the R-1820-52 scene and named F.100.Cylinder Base. Quote To keep an order in this two-scene setup, I decided that the parts used in both versions (scenes) retained the “E” prefix in their names – for example “E.015.Disc”. The parts specific to the “-60” engine received the “G” prefix, while the parts of the “-52” engine received the “F” prefix. The crankcase front section in the R-1820-52 had smaller diameter than in the R-1820-60, and different side silhouette. Thus I had to model this fragment anew. I split it into 9 identical segments, as I did in the R-1820-60. However, after some measurements, I decided that the disc that closes this crankcase from the front is identical in both versions (Figure “b”, above). To avoid eventual “orphaned” objects in my further work, I used this disc the root object in the “parent-child” hierarchy of both models. In Figure “b”, above you can also see the initial versions of the pushrod bases, which I placed around the front crankcase section. They had characteristic “diamond” shapes. I recreated the “pattern” of these pushrod bases around the crankcase. This work led me to another small discovery: the G100s and the earlier “Cyclone” versions used different valve pushrod arrangement than in the G200s: Compare the a and b distances in Figures “a” and “b”, above. As you can see, there is wider space between the intake and exhaust valve pushrod (the b distance) in the earlier “Cyclone” G100 series (incudes the R-1820-52) than in the later G200 (includes the R-1820-60) series. The reverse proportion occurs between the pushrods of the adjacent cylinders (the a distance in Figure above). It seems that the pushrods in these earlier “Cyclones” were set along the radial directions, while in the later (G200) models they were set at a different angle. There is also another difference: Wright engineers reversed in the G200s the order of the pushrod cams. In the G100s and earlier engines the base of the intake valve pushrod was shifted forward (Figure “c”, above). In the G200s they set the exhaust valve pushrod first (Figure “d”, above). To match the rear rim of the front crankcase with the photos, I prepared its simplified, “block” version (Figure “a”, below): This “block” version is built of several simple elements, like the pushrod bases, the rear, flat elements, and so on. Once their shape matched the reference pictures, I joined these elements into the single, more complex object using temporary Boolean (Union) modifiers. Finally I joined it with the basic front crankcase segment (Figure “b”, above). I also rounded the new intersection edges with a multi-segment Bevel (Weight) modifier. In the G100s (incl. R-1820-52) and earlier “Cyclone” models the propeller governor was mounted at an oblique angle on a quite complex “shelf” extending from the crankcase: I applied here the same “approximation first” method, using intermediate simplified parts (Figure “b”, above). (As you probably observed, it became my usual approach to such complexities like this one). After the “fitting” phase I joined the bottom part of this “shelf” with the crankcase, and rounded the resulting edges (Figure “c”, above). On top of the “shelf” there was an additional, “stacked” part (I think that it was a kind of a cover). In the pictures above I marked it in red. In the final version I left it as a separate part, attached to the crankcase by the “parent” relation. In the background of figure above you can also see the first versions of the cylinder instances (I will modify them in the next steps), and the ignition harness manifold. (I preferred to fit it on this early stage of this the model, to avoid unwanted surprises later). When the “shelf” was ready, I put the propeller governor in place: I copied this governor from the R-1820-60 scene, then modified it a little (rotating the head with actuator wheel by 180⁰). Unlike in the R-1820-60, this object is set in the position parallel to the engine centerline. Looking from the front, it is mounted in an oblique position just to pass the control cable in the gap between Cylinder 1 and Cylinder 2. However, looking along this cable, I stumbled upon a new problem: it collided with the intake pipe! (Figure “b”, above). I quickly found a photo that explained me this puzzle (Figure “a”, below): As you can see in the picture above, the intake pipes in the G100s models formed large arcs, leaving the gap between the Cylinder 1 and Cylinder 2 open for the control cable. This means that I have to modify these pipes in my R-1820-52 model. Thinking about the altered angle of the valve pushrods (see the second figure in this post) I checked the clearance between them and the cylinder head. In the R-1820-60 they were placed in deep troughs, “cut out” in the cylinder fins. I was surprised by the photos showing that in the R-1820-52 these pushrods would not collide with the cylinder head, even if this head did not have the minimal, shallow troughs. I studied this cylinder head closer: the spark plug hollows also seemed to be shallower, and the upper contour of the fins (as viewed from the front) was lower in its middle section. I started to compare proportions of these cylinders. Finally I decided that the fins in the heads of the R-1820G and R-1820G100 series were shorter than in the R-1820G200 (i.e. in my R-1820-60). I estimated that the G100s cylinder heads had 10% smaller diameter than the G200s heads. (It means that cooling area of the G200 cylinders was about 30% larger than the cylinders used in the G100s. It matches the differences in their power). Well, now I had to apply these findings to my model: Fortunately, the “pattern” of the cylinder fins seems to be nearly identical in the G200s and G100s cylinder heads. (I have found just a single minor difference in their forward part). Thus all what I had to do was to prepare new, smaller “fin boundary surface” (Figure “a”, above), then apply it using Boolean (Intersection) modifier to the same mesh of the fin planes. I could reshape the intake pipe by altering the shape of its control curve (used in the Deform Curve modifier of the intake pipe). You can see the results in Figure “b”, above) Figure below shows the actual state of the R-1820-52 model: Cylinders 2-9 are instances of the object group named F.G05.Cylinder. The source of this group are the components of the Cylinder 1. When I modify the source Cylinder 1, Blender immediately updates the remaining eight cylinders. Components of Cylinder 1 lie on two layers: 3 and 13, while the group instances belong to the single layer: 3. I have found such an arrangement most useful for the constant work on the cylinder details – I often did it on layer 13. Note that I also modified the bases of the intake pipes (I had a single, poor quality photo of this area). In general, it seems that the rear crankcase section of the G200s that I roughly recreated in the R-1820-60 is similar in the R-1820-52. The same applies to the magnetos and oil pump. This engine still lacks the cylinder deflectors, oil slump, and spark plug cables. In the next post I will finish all these details and fit it into the NACA cowling. You can download the model presented in this post (as in figure above) from this source *.blend file. Edited August 17, 2018 by Witold Jaworski 2 Link to comment Share on other sites More sharing options...
NickD Posted August 23, 2018 Share Posted August 23, 2018 Excellent as always 1 Link to comment Share on other sites More sharing options...
Witold Jaworski Posted September 1, 2018 Author Share Posted September 1, 2018 (edited) In this post I will finish my model of the R-1820-52 “Cyclone”. (This is the continuation of the subproject that I started reporting in the previous post). Figure below shows the oil sump, used in this engine: Oil sump shape vary even within the same G100 family: I observed different proportions of the front “barrel” and its forward pipe in the early and the later of these “Cyclone” models. This particular oil sump (Figure “a”, above) was used in the later G100s engines, like the R-1820-52. Apart from the forward pipe, it was also attached to the front crankcase via a “chin” (Figure “c”, above). Quote To avoid eventual confusion, I would like to clarify the multiple naming conventions of the same engine: In the further text I will also use the internal Wright name for this “Cyclone” family: R-1820G100, or simply “G100”. The R-1820-52 engine is one of its members. (A month ago I finished a model of one of the later “Cyclone” versions: R-1820-60, which represents another, the “G200” family). I explained details of these nomenclature in this post. While I have a few photos of the forward part of the oil sump, I have not any evidence of the shape of its rear part. (Because of the different shape of the intake pipes, I do not think that it forms the “Y-shaped” fork, like in the G200 series). All what I had found is a single, poor quality photo of the damaged engine recovered from Lake Michigan (Figure “a”, below): There is “something” at the bottom of this crankcase: it has a trapezoidal shape and (probably) two inner (oil?) ducts inside. I decided that this is the rear base of the oil sump (Figure “b”, above). It is quite thin (no more than 1 in), fitted between the crankcase main section (cylinder bases) and the intake pipe (Figure “c”, above). Quote As you can see, I have made lot of various assumptions about the rear part of this oil sump. Well, in every model you can always find some elements that have such a “hypothetical shape”. However, this is the last resort, when all my photo queries brought nothing. As I described in the post about “Cyclone” versions, the R-1820G100 and R-1820G series used the same deflectors. Thus I recreated the upper deflector (the “rectangular” version) using photos of a restored R-1820G engine, from the F3F-2: I recreated the sheet metal frame and the flexible (rubber?) tip (Figure “a”, “c”, above). The photos from the recovered SBD-1 show, that there were some variations in the shape of the deflector rear part, around the spark plug. In the R-1820-32 from the SBD-1 I can see a kind of additional cut-out for the ignition cable, which is missing in this F3F-2. (F3F-2 had a different ignition harness – compare the deflectors in Figure “b” and “d”, above). The top cylinder in the SBD-2…-4 had the elastic tip removed. (Because of the fitting the engine to the “Duntless” NACA cowling – I will show it later n this post). Thus I defined this deflector as another group instance, named F.G11.Deflector. (In the R-1820-60 model the top deflector is the part of the cylinder group). In similar way I modeled the side deflector: This deflector also has a flexible tip. As you can see, I skipped here some details (Figure “a”, above) that do not appear on every object instance. Note the characteristic “bat-like” fitting in the front of this deflector (Figure “b”, above). (The R-1820-60 deflectors had different fittings). The last remaining details are the spark plug harness and the oil scavenge pipe: As in the previous case, I am leaving the invisible, rear part of this engine in the simplified, “block” form. Finally, I imported the NACA cowling from the main model and placed the engine inside. Fortunately, it fits very well: In the R-1820-52 (and -32 in the SBD-2) the deflector on the cylinder 1 top was mounted without the flexible tip, to fit below the air intake duct of the upper cowling (Figure “b”, above). Both of the cylinder 1 side deflectors also had their flexible tips removed, to fit below the gun troughs. In the R-1820-60 and -66 (used in the SBD-5 and 6) the cylinder 1 featured the full top deflector. (It was possible, because, as I explained in this post, SBD-5 and -6 had two filtered air intakes, used for takeoffs. For the higher airspeeds there was enough “fresh” air for the air intake hidden behind the cylinder row). The R-1820-60 had different fittings on the cylinder 1 side deflectors that fit the gun troughs (Figure “c”, above). The R-1820-52 is now complete, for the assumed level of details. You can download the model presented in this post from this source *.blend file. I think that it can be also useful for the models of the other aircraft that featured the geared R-1820G or R-1820G100 engines. (Like Brewster “Buffalo”, DC-2 and some versions of the DC-3, or Curtiss “Hawk” 75). The exhaust stacks are not included, because this is an aircraft-specific detail (as the eventual air intake filters in the SBD-5 and SBD-6). I will recreate these details in the next post, for both of my ‘Cyclone” models. Edited September 1, 2018 by Witold Jaworski 3 Link to comment Share on other sites More sharing options...
Witold Jaworski Posted October 27, 2018 Author Share Posted October 27, 2018 In my previous post I have finished the second variant of the R-1820-52 “Cyclone” engine, which was used in the SBD-3 and -4. (It looks like the earlier R-1820-32 model, mounted in the SBD-1 and -2). In the resulting Blender file linked at the end of that post you will find two “Cyclone” versions: the R-1820-52 (for the earlier SBD versions, up to SBD-4) and the R-1820-60 (for the SBD-5 and -6). Each of these engines has its own “scene”. To “mount” these engines into my SBD models, I imported both scenes to the main Blender file. I defined each engine variant as a group, to facilitate placing them in the aircraft models as the group instances. I also added the firewall bulkhead and updated the shape of the cowling behind the cylinder row. (I will refer to this piece as the “inner cowling”). So far I did not especially care for the shape of its central part, hidden below the NACA ring. Now I updated it for the real size and shape of the engine mounting ring (as in figure “a”, below): On the photos I noticed a kind of bulges, extruding from the both sides of the inner cowling (figure “b”, above). I assumed that they are shaped around small triangle plates welded on the sides of the mounting ring. (I have no photo to proof this assumption). Anyway, I modified the shape of the inner cowling in the SBD-5 to match this feature. I assumed that the inner cowling in the earlier SBD versions (SBD-4, SBD-3,…) also had such “bulges”. In Figure “b”, above, you can see three openings for the intake air in the SBD-5 and SBD-6: a rectangular one in the middle and two round holes on the sides. These side openings are for the air filters, intended mainly for the takeoff and landing: The idea is that the during the dusty conditions on the airfield the direct intake door (1) is closed, while the doors for the filtered air: (2) and (3) are open. When the aircraft climbs higher, its pilot flips positions of these doors, closing the filtered air input (2), (3) and opening the direct input (1). Quote There was no such a thing in the earlier SBD versions. It seems that the alternate filtered air input was introduced to many US aircraft in the same time: between 1942 and 1943. (You can also see the filter intakes in the P-40 starting from the M version, and in the P-51, starting from the B version). Maybe it was a general suggestion from the Army, after several months of the airfield war experience? I added these two filters and their intakes to the R-1820-60 engine: As you can see, these intakes are tightly fitted between cylinders 2-3 and 8-9 (Figure “a”, above), so they have a quite complex shape (Figure “b”, above). I do not have a photo for such an obscure detail, but the location of the filter determines, that the mixture intake pipes of Cylinder 3 and Cylinder 9 went through the corresponding intake body. (In principle, it is technically possible). I did not make holes in the deflectors between cylinders 2-3 and 8-9. (They would not be visible anyway, because both elements: the deflector and the intake are covered with black enamel). The next aircraft-specific element is the exhaust collector. In the SBD-4 and earlier versions its outer contour had a circular shape (Figure “a”, below). However, in the SBD-5 (and -6) it went around the air filters, so it had a slightly different shape around this area (Figure “b”, below): I built these collectors from simple tubular segments. Each of these segments is first tapered by the Simple Deform modifier (1), then bent along its shaping curve by the Curve modifier (2): The offset of the original tube object from the curve object determines the origin of the resulting shape on the curve. Small gaps between subsequent tubular segments are hidden under the joining rings (as in the real collector). 95% of this collector is closed inside the NACA ring, so I decided to not recreate the fillets along the edges of the individual outlet pipes. (Joining all these tubular meshes would be a time-consuming task). I used some photos to compare proportions of the exhaust collector, circular reinforcement and the cross section behind the NACA cowling in the SBD-3. The findings led me to the conclusion that I should modify the bottom part of the engine cowling: Many months ago I found that the cross-section of the lower inner cowling in the SBD-5/SBD-6 had a non-elliptic shape (shown in Figure “b”, below). I also assumed, that such a cross-section also occurs in the earlier SBD versions. Now I can see that I was wrong: the photo above shows that in the SBD-1… SBD-4 it was a regular ellipse (as in Figure “a”, below): It seems now that Douglas designers modified a little the bottom part of the engine cowling in the SBD-5, shaping its circular “chin” (Figure “b”, above). Maybe they did it because of the larger oil cooler used in this version? (It was required by the more powerful engine). If in the SBD-5 they shifted whole engine 3.5” forward, such an additional modification is also possible. (There was no any bulkhead at this station, and this cowling piece was already shaped anew). To determine the exact location of the engine along the fuselage centerline, I used the high-resolution reference photo of the SBD-5 (Figure “a”, below): I shifted the engine along the fuselage centerline, until its crankcase matched the crankcase visible on the photo. Then I measured the f distance (Figure “a”, abve) and applied it to the SBD-3 and SBD-1 models. (In the SBD-5 the engine together with the NACA cowling was shifted forward, thus in the SBD-1 and SBD-3 I could not simply apply the absolute location of the engine origin). Finally, I applied the materials to the engine models, copied the environments from the SBDs to the R-1820-52 and R-1820-60 scenes, and made test renders: On these renders I placed the engines “in the middle of the air” just to be able to evaluate all their materials in the full light conditions. Due to relatively small size of most of the engine elements, I used here only the procedural textures. I did not apply to this engine models any oils stains or other dirt. The historical photos show that the blue enamel on the crankcase was kept surprisingly clear, even in the worn-out aircraft. The other parts of the engine are obscured under the NACA cowling, so there is no need for additional “dirt” textures. You can see it in the test render of the R-1820-60 “Cyclone” inside the SBD-5 NACA cowling: You can download the model presented in this post from this source *.blend file. In the next two posts I will work on the details of the cowling behind the cylinder row. 6 Link to comment Share on other sites More sharing options...
Pete in Lincs Posted October 27, 2018 Share Posted October 27, 2018 This has come on very well since I last looked in. Some incredible detail and the picture above is amazing. Link to comment Share on other sites More sharing options...
Learstang Posted October 27, 2018 Share Posted October 27, 2018 As always, superb computer modelling. I wish I had your skills and patience. I wonder how your engine would come out if I tried to print it out on my 3D printer? I may just have to find out. Regards, Jason Link to comment Share on other sites More sharing options...
NickD Posted October 27, 2018 Share Posted October 27, 2018 Utterly magnificent. Thanks for sharing. NIck Link to comment Share on other sites More sharing options...
Witold Jaworski Posted October 28, 2018 Author Share Posted October 28, 2018 Pete in Lincs, Learstang, NickD: thank you for following! 14 hours ago, Learstang said: (..) I wonder how your engine would come out if I tried to print it out on my 3D printer? (...) Unfortunately, I created this engine model for the visualization purposes. This means that its elements are not "watertight". This model would need some major updates to be reproduced as the real model on a 3D printer. In such a case you should also consider some optimizations, depending on the ultimate scale of the printed objectl. For example, the width of the real R-1820 cylinder head fins was less 0.1" (about 0.08" - so it is in my model). In the 1:25 scale it would produce so thin layer of the plastic that most probably it would melt with the previous layers. Similar problems applies to other small elements... 1 Link to comment Share on other sites More sharing options...
Witold Jaworski Posted November 10, 2018 Author Share Posted November 10, 2018 (edited) This time just about some minor details: After “mounting” the R-1820 engines into my SBD models, I decided to recreate some details of the inner cowling (the cowling panels placed behind the cylinder row). In this post I will form the missing parts of the carburetor air ducts, hidden under the NACA ring. There are significant differences in this area between various SBD versions, which never appeared in any scale plans, or in any popular monograph of this aircraft. I think that the pictures presented below highlight these differences. They can be useful for all those scale modelers who are going to build the SBD “Dauntless” models with the engine cowlings opened. (Sometimes you can encounter such advanced pieces of work on the various scale model contests). Let’s start with the SBD-5s (and -6s), which are better documented (because they were produced in much larger quantities). They had a dual intake system, of the filtered/non-filtered air, which I discussed it in the previous post. I already recreated the two intakes of the filtered air, placed between the engine cylinders. Now I have to create the central, direct air duct and its opening at the top of the internal cowling. Figure below shows the initial state of my SBD-5 model: As you can see in Figure “b” and “c” above, initially the carburetor protruded from the simplified shape of the internal cowling. On this stage of work I was sure that the engine is at the proper location (I matched it against the reference photo in the previous post). Thus, I concluded that the shape of the internal cowling requires an update. To determine its real form, I reviewed the available photos. Unfortunately, I have only few pictures of this obscured area: Figure “a” above shows an archival photo, taken at the Douglas factory. I can see there that edges of the cowling around the central air intake are shifted forward. Unfortunately, the closing, top element of this cowling is not attached here. I can see it in Figure “b”, above, taken from the front (which makes it less usable). On this picture I noted that the edges of the air intake are elevated above the cowling (by less than inch). It was confirmed by the pictures of the restored SBD-5 from the Pacific Aviation Museum Pearl Harbor (Figure “c”, “d”, below): In Figure “c” above you can see the side contour of the inner cowling. I can see that the central area is shifted forward (marked in blue in Figure “b”, above), and side segments around air filters are shifted back (marked in brown in Figure “b”, above). Figure “a” below shows these faces on the updated mesh of the inner cowling: You can also see there the top of the air duct (this is a separate object). Figure “b”, above, shows its simple, “box-like” mesh. When both elements were in place, I used a Boolean modifier to cut out the central opening in the cowling (Figure “c”, above). Let’s look at the corresponding area in the earlier SBD versions. Figure below shows the rear side of the SBD-3 engine cowling: This case is quite different. It seems that the upper part of the inner cowling in the SBD-3 forms a “box” around the carburetor air duct. It was quite difficult to find any photo of this area taken from above (you know, in 99% cases the photographer stays below, on the ground). All what I have are the photos of the SBD-3 wreck, salvaged from Lake Michigan: I learned from them that this “niche” had flanges around its edges, and the air duct stood inside it like a “statue”. (There was a lot of space around this duct). The designers even formed a kind of “pedestal” at the base of this “niche” (I marked it on the right photo). Using all this information, I reproduced this “box”/“niche” in my SBD-3 model: I started with a simple box, then I fitted it into the elliptical contour of the inner cowling. Finally I joined these two meshes, and rounded their edges using the Bevel (Weight) modifier. I also extruded the flange around its rear edge. I also tried to determine the shape of the air duct. In this case the only available references were the photos of the SBD wrecks: It seems that this part of the air duct had a “jug-like” shape. Its upper edges fitted the horizontal air duct mounted in the NACA cowling. (That’s why the forward edge of this intake is lowered a little – just as the bottom of the air duct in the NACA ring). Figure below shows my attempt to recreate this part in the SBD-3 model: I had some doubts about the forward edge of the upper cowling that overlaps the flange behind the air intake. Finally, I wrapped it around the topmost edge of the “niche” (see Figure “b”, above). I also improved the shape of the “pedestal” in the inner cowling. (It covers the front section of the carburetor – see Figure “a”, above). I assumed that the air intake looked like that in the SBD-2, -3 and -4, because they share the same air duct design. I have not any reference materials about the internal air duct in the SBD-1. I assumed identical shape of the inner cowling as in the SBD-2, -3, and -4. Figure below shows other assumptions: I assumed that the general shape of the internal, vertical air duct segment was as in the later versions. The only difference are the simpler upper edges, fitting the opening in the NACA cowling. (There was no “lower” part of the external air duct under the NACA cowling, which you can see in the SBD-2, -3 and -4). In the next post I will add the last details to the inner cowling, finishing my work on the engine compartment. You can download the model presented in this post from this source *.blend file. To reduce its size, it is stripped from the texture images. (During the last year the size of this source file has significantly increased, reaching 40 MB in the compressed form. More than 35MB of this amount is used by the texture images. Thus, I will preserve the texture images in the source file only when they are relevant to the topic of the post) Edited November 10, 2018 by Witold Jaworski Link to comment Share on other sites More sharing options...
NickD Posted November 10, 2018 Share Posted November 10, 2018 Withold, It is impressive that the tools, (in expert hands) allow such detective work. I'm also surprised that such details are so difficult to pin down for such a familiar subject. Fascinating as always Nick Link to comment Share on other sites More sharing options...
Witold Jaworski Posted December 29, 2018 Author Share Posted December 29, 2018 (edited) NickD - thank you for following! This winter I am busy with my daily business project, so you will see the further progress in this model in the spring 2019. However, I have just found a little unpublished tutorial that I made in November, so I decided to publish during this break: _____________________________________________ This post is dedicated to a minor feature, which I have found surprisingly demanding: modeling the grooves pressed in the curved surfaces of the aircraft panels. In the SBD you can see some of such reinforcements on the inner cowling, behind the cylinder row: They are 0.7-1.0” wide (Figure "a", above) and span over the inner cowling along its radial directions (Figure "b", "c", above). In the SBD-5 and -6 these reinforcing grooves occur only on the lower part of the cowling (Figure "b", above), while in the earlier versions (SBD-1, -2, -3, and -4) they are also present on the upper part (Figure "c", above). Even when the flaps on the NACA cowling are closed, you can still see rounded endings of these grooves around the cowling rear edge: In the earlier versions (SBD-1..SBD-4) they appear on the narrow strip behind the NACA cowling (Figure "a", above). You can see more of the upper grooves when the NACA cowling flaps are set wide open. In the SBD-5 and -6 the engine and the NACA cowling were shifted forward by 3.5”, and the gap between the NACA ring and the inner cowling is wider. Thus, in these versions you can see even longer fragments of the grooves behind the NACA cowling (Figure "b", above). Such grooves appear on many sheet metal elements, so I decided to write this post as a small tutorial that teaches how to recreate these elements. Thus, do not be surprised when I list the detailed Blender commands in the text below. Usually I would recreate such a feature using bump map. However, this is a special case: it may happen that in the future I will also recreate most of the inner details inside this NACA cowling (for a cutaway picture). This means that in the future I will have to render some close pictures of this area. That’s why I decided to model these groves in the mesh geometry. (It seemed that this addition did not require any substantial retopology, due to the radial direction of these groves. Their layout matched the general “spider web” mesh layout of this inner cowling). There are two methods to reshape the mesh in Blender: Classic, manual modification of the faces, edges and vertices; Displace modifier, which uses a texture image (a kind of bump map) to shift (displace) the mesh faces along their normal directions; The Displace modifier is a great tool for the cloth wrinkles and similar effects. However, for the relatively sharp edges as in these grooves, it would require an extremely dense mesh (subdivided 4 or 5 times). Because the Displace modifier required significant increase of the polygon count in my model, I decided to recreate this feature using the basic modeling techniques. Figure below shows the initial stage of this work. For each groove I created an auxiliary “plate” (Figure "a", below) and adjusted their thickness and locations to the reference photo (Figure "b", below): Each of these plates is a simple, four-vertex plane. Its thickness is created by the Solidify modifier, and the rounded edges – by a multi-segment Bevel modifier. As you can see in Figure "b", above, I set their locations and rotations, so each of their cross-sections with the cowling fits the edge of a groove visible on the reference photo. It occurs that the distances between the grooves are not uniform – as you can see, comparing the distances (1) and (2) in Figure "b", above. (Note that there is a panel seam within range (2) – I think that this is the reason of this additional “spacing”). I also thought about the mesh topology. In the optimal case: each plate should cross only the perpendicular edges of the cowling panel. Eventual single radial edge along the middle of the plate is also acceptable; there should be at least single “radial” edge on the cowling panel between two subsequent plates; To fulfill requirement 2, I had to make the initial mesh of the cowling panel denser (subdividing each face once, by applying the Subdivision Surface modifier). You can see the resulting mesh in Figure "a", above. I also marked there the potential “trouble area”, where the plate is crossed by the skew edges. It is always better to know such a thing in advance. (Before applying the Subdivision Surface modifier, I also had to apply the original Bevel modifier, which rounded the gun throughs edges. Thus, at this moment this cowling object has just a Mirror modifier in its modifier stack). In the next step I modified the cowling mesh, creating some space for the grooves: I redirected the edges in the “trouble area” marked on the picture. I also rotated by a fraction of degree many of the other radial edges, so that they go straight in the middle of the plate, or run along its side, far enough for the rounded edges of the groove. It is hard to notice these results at first glance, but this is the key work which determines the quality of the final effect. Once the mesh of the cowling was updated, I removed from the plates their Bevel modifiers and applied the Solid modifiers, converting their meshes to “boxes” of fixed width (0.7”). (The only purpose of the Bevel modifiers was to round the plate edges for comparison with the grooves on the reference photo). Before I started “chiseling the grooves”, I added to this cowling panel a new Bevel (weight) modifier, and a Subdivision Surface (1) modifier. Figure below shows the current state of the modifier stack of this model part: These two new modifiers will round the edges of the grooves. The size of the Bevel (0.2”) is appropriate for the width of these grooves (0.7”). Of course, in your case you have scale these dimensions proportionally for your groove width. To cut out a groove contour, I joined (Object:Join, or [Ctrl]-[J]) the plate object with the cowling, and selected all of its six faces (Figure "a", below): Then I invoked the Mesh:Faces:Intersect (Knife) command, obtaining the initial edges of the groove (Figure "b", above). The Intersect (Knife) command produces some overlapping vertices, which I quickly fixed, selecting all of them and invoking the Mesh:Vertices:Remove Doubles command. I also removed the “cutting box” (I do not need it anymore). In the last step I adjusted the ends of this “strip”. I created four additional vertices (two of them at each end), to add four additional edges (Figure "c", above). (I created these new vertices by selecting the corresponding edges and invoking the Mesh:Edge:Subdivide command). Finally I shifted the corner vertices of this strip inside, using Mesh:Vertices:Slide command ([Shift]-[V]). Then I use the Mesh:Transform:Shrink/Fatten command ([Alt]-S) to move the central vertices of this groove down, each along its original normal direction: This groove has width of 0.7”, so I shifted its vertices downward by 0.4” (I found this proportion optimal). Then I assigned the Bevel weights to round the edges of this groove. I set the weight = 1.0 to the central edge, and weight = 0.5 to the side edges (Figure "a", below): Figure "b", above, shows the resulting surface. I repeated this sequence of operations for each groove. When the intersection produced a contour without the central edge, I used the Mesh:Edges:Subdivide command to create a new one: Figure below shows the finished grooves on the SBD-5 and SBD-3 cowlings: (The SBD-1 uses the same inner cowling as the SBD-3). After this work, I had to refresh the UV maps of the modified elements. Figure below shows my test render of the SBD-5 cowling: As you can see, I removed the NACA cowling from this model, so that you can evaluate the ultimate result of my work. Quote Conclusion: as long as you can, use bump maps to recreate such grooves. Recreating this feature by pure modeling requires much more work (by an order of magnitude). You can download the model presented in this post from this source *.blend file. To reduce its size, it is stripped from the texture images. Edited December 29, 2018 by Witold Jaworski 3 Link to comment Share on other sites More sharing options...
Witold Jaworski Posted April 27, 2019 Author Share Posted April 27, 2019 A small off-topic note: this winter I was busy with my daily business and took a break from the SBD model. However, in February and March I spent few Sundays helping in another project: recreating the Fokker D.V biplane, used in 1917 as an “advanced trainer” by German Air Corps: My part was recreating the geometry of this aircraft, especially its fuselage frame made of steel tubes. All what we had was a dozen of various archival photos, a poor general drawing, and the landing gear dimensions. In this case I had to turn the available photos into the precise reference, as I did for the SBD, then use them to determine the required geometry details: Doing it, I also made a "discovery" about wing geometry of this airplane. See details in this post. 2 Link to comment Share on other sites More sharing options...
Putty Animal Posted April 28, 2019 Share Posted April 28, 2019 You really are a master of your craft. I just read the full article on the D.V, and my mind was properly blown. I am full of admiration and gratitude to you for bringing the shape of this beautiful and extinct aircraft back from the dead. 1 Link to comment Share on other sites More sharing options...
Witold Jaworski Posted August 4, 2019 Author Share Posted August 4, 2019 Important update about this SBD project: thanks to C West help, I identified a microfilm roll set of the original Douglas documentation for the SBD/A-24. In June I ordered its copy from NASM and now I am waiting for these materials. When I got them, they will be scanned by a local service company which scans various museum archives. This is not cheap, because the only possibility is to scan all microfilm frames (and pay for each frame, of course - I estimate that this set of seven microfilm rolls contain about 5500-6000 frames). Then I will organize these scans for quick use as the reference materials. In the meantime, I am going to update my P-40 model, also using original blueprints. I already bought their scans. See the other thread on this forum about my experiences on this subject. 1 Link to comment Share on other sites More sharing options...
shark 64 Posted August 5, 2019 Share Posted August 5, 2019 is this for a game or it will actually been done in styrene? Link to comment Share on other sites More sharing options...
