Sign in to follow this
Viking
Vickers Mk.1 WW1 Guns. 1:32 Eduard Brassin
1:32 Eduard Brassin.
Developed from the Maxim Machine gum, Vickers improved the basic design by lightening it and using high strength alloys on key components. The ground based weapon had a water cooling system, but this was not found necessary when mounted on aircraft as the slipstream kept the gun cool, although the water cooling jacket was retained. It was very suitable for for use with synchronising system that enabled rounds to be fired through the spinning propeller, and thus widely used on British and French aircraft from 1916 onwards.
The Brassin set provides 2 guns, with the main parts cast in resin with beautifully defined detail. Etched brass supplies brackets, sights, and a choice of 2 different cocking levers.
The obvious place to use these will be on Wingnut Wings kits, where they will add that extra touch of detail to already beautiful models. Given that the gun was used well beyond the end of the First World War, and into the Second on the Gladiator and Swordfish, there are plenty of subjects that will benefit from a set of these.
Highly Recommended.
Review sample courtesy of
