simmerit
Trumpeter 1/35 British Heli - Its a Chinook
7 hours ago, TheBaron said:
Amended later: hmmm...having read p.1 again I realize them seats were an AM set. I've only a couple to do so looks like the wine bottle foil will be coming out imminently...
What a perfect excuse, should one be needed, for cracking a bottle of plonk!
Ian
Ian
Never a bad time to crack a bottle of wine is what I say!
On 4/26/2017 at 8:10 AM, TheBaron said:
Handsome work as ever Si. :thumbsup2:
Sorry to have to admit that I'm nicking your perspex pole mounting idea so that my C-119 has enough clearance to catch a parachute. I'm also going to read back in here to see how you built your cabin seating as I've a couple of them to knock up as well from scratch....
Keep it up!
Tony
Thank you.  You'll have to let me know how you get on with those perspex pole mounts as at this rate, I'll be another 4 years............................
Right.  I have had a mahoosive mental block on these for some reason, which is bonkers as they proved to be pretty easy in the end and the solution was staring me in the face the whole time.
just got the big one to do at the front now.  Also had a crack at these
Bit of filling to do - over enthusiastic cutting.
Last one fitted and them filed down to the correct angle for the antenna.
I may dig out those sheets of rivets today and assess how may more I need to buy!
On 5/9/2017 at 3:26 PM, phildagreek said:
Getting there. Looks good.
Thanks Phil.
Just on with the antenna now.  I bought the profimodeller brass antenna - I need 5 and there are 18 in the pack, so I'm good for another 2 Chinook.........
A few issues to correct, like they are about 5.. too long, and the brass is drilled, which aint any use as the cable/tube sits on top, rather than through the centre.  Other than that the Profimodeller brass antenna are spot on for accuracy..................................
My trusty dremel should sort the problem:lol:
Looking very good indeed, huge respect. Just one quick question.....'enough for another 2' WHAT!?!?!? Really???? Another 2 Chinooks of this size?????? Have you been sniffing a certain brand of paint (that will remain nameless for the good of all on here) and, more to the point, how on earth will you get them past the other half?????
Deffo a joke!  I've got the Pinz and 105 to do after this.  They should take about 10 minutes in comparison.  I've got a whole bunch of other stuff stacked up as well.  |Not the least of which is a Fly Wessex.  This Wokka will be the last piece of model engineering I ever do I think.  I just want to build the bloody things and chill out now!
4 to go.  I cant decide if this is impatience or not, but I want to get the antenna pylons on.  At least I'll feel like I've achieved something and its another line through on the snag list.  I'm actually hoping to nail the entire list this weekend.
Are you sure those are aerials and not hand holds for the RAF Regiment?
Ian
Ian
Well I suppose they do call them Rockapes :D
managed to crack on a teeny bit.  Its the little bits that make the difference
InAccurate Armour carbon aerial comes in useful, does it not
I'd be afraid to pick it up now for fear of knocking something off!  Looks great
Its a bit scary I have to say.......... and thank you by the way.  On the finishing touches now before I prime it
Fabulous.  Can't wait to see it under some paint
I did..................... its the Peroni.  That's my excuse anyway........
20 hours ago, viper-30 said:
Finishing touches that's phrase we don't often hear from you ............lol..
you good mate...
hahahaha (as they say).  Hello Terry mate - yep I'm good, and close!!
Just struggling with this at the minute.  Not convinced.  Views????????
and got these on just by the armour plate
So apart from the Doplar and where the other sand filter where it is attached to the fuel feedline covers, I'm REAL close.  I am
Looking at the picture of the original engine mounting; is there an additional narrow strengthening plate (?) on the horizontal panel on the engine pylon.
There is - I've got it, but I'm not sure if it goes all the way round.  I hadnt spotted that by the way!
I've also got the back of that plastic strip to trim off .  I' not sure how much I can do on this as I'v got hardly any piccies - that's the best one I've got really.  Someone.  Somewhere, will be reading this saying 'that's wrong'.........
Edited by simmerit
fantastic detailing.  Can't beat a good dose of greeblies to make things look realistic
This is the problem with the hinterweb - one of the lads on ARRSE provided some input
The steel ballistic panels used to be a **** as they were so heavy, one on the inside of the bottom of each cockpit "door", two smaller ones on the floor either side of the cyclic stick, the companionway floor (turned it into an ice rink when wet), the door plug externally armoured (you've done) and three panels across the floor between station 120 and 160 (between the escape hatch LH and the door RH); these were half inch ish armour plate with cut outs for the cargo tie downs and bolted down in each corner.
And the door panels were painted black on both sides, so they don't show up well in pictures (as the whole cockpit is black), as were the cockpit floor panels and the companionway. I can't recall off the top of my head what colour the cabin floor ones were - kind of rusty looking I seem to remember so might have been a red oxide like primer colour.
ai-Chinook-air-crew-armour-pla_zpsaghmll
This is what an armour package for a Chinook looks like, and
bang goes some of that lovely detail of my air crews lovely Oakley desert boots that I spent so much time on................ see lower door for ballistic plate.
Another one for the snag list, but it wont stop me priming it!!
